Question about Dryers
Dryer won't start
Maytag Performa dryer
  • 1 more comment
  • Gearsofwar Jan 10, 2008
    Mine is Maytag performa dryer PDET910AYW. It doesn't start. I tried to look for the fuse on top rear panel but can't find it. Where is it located and how to access it?
  • Anonymous Jan 08, 2009
    thermo fuse blown on mine
  • j_spencer85 Mar 16, 2009
    My husband went down stairs to change out loads and the dryer stopped half way through cycle, checked fuse box, checked dryer for clog, and the door switch looks to be fine.
  • 240 Answers
Just a few things before the for sure thing. Make sure the dryer door is closed very good, and its plugged in (I hate doing that, but have a lot of calls with just that same thing). More than likely, it is the thermal fuse that has went bad. This fuse causes us more problems than any other item on the Performa. Unplug the unit, and take a putty knife and shove it into the top removing clips between the top and cabinet, around 1-2 inches in from the sides. Lift up and prop the lid against the wall, being sure it wont clunk you in the head (happens to me about once a week). In the left rear of the unit, you will see the element box. On (your facing side) the right hand side down about halfway, you will see two wires going to a small button shaped fuse. Remove the screw at the top of the element box (1/4") slide the fuse holder up and out (with wires still connected in case you drop it), and remove the fuse. The parts (LA-1053) will contain two fuses and a thermostat. Be sure to remove and replace the old thermostat when replacing the fuse. Follow instructions for which fuse to use, one is for gas, one is for electric. Reassemble is opposite disassembly. Let me know if you need further help. Jim
Posted on Nov 06, 2007
I have a Performa dryer (electric) that would not start. It was a heat sencer located on the exhaust duct that failed.
Posted on Nov 20, 2008
My Maytag Performa Model # PYE4500AYW has quit. I press the start button and it won't start.
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Jun 27, 2011 | Maytag Dryers
My Maytag Performa dryer makes a loud scratchy noise while drying. What is the noise and how do I fix it?
My Maytag Performa gas clothes dryer makes a scratching noise for the first few minutes when turned on, then it goes away.
Jun 01, 2010 | Maytag Performa PAV2200
Dryer noise and no motor action
If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer Troubleshooting2_bing.gif Electric2_bing.gif Dryer won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
May 03, 2010 | Maytag PYE2300AY Electric Dryer
I have a Maytag Performa electric dryer that won't start
you have an open thermal fuse.part no. la-1053,its kinda tough to install,i would recommend a qualified servicer
Mar 06, 2010 | Maytag Dryers
Maytag washer tub leans to the right
I have a Mayag Washer and dryer The washer someimes spins of balance. the dryer has no heat, this just started. would it be the element?
Oct 23, 2009 | Maytag Performa PAV2200
Maytag Performa Dryer won't start.
I would suggest checking and probly replacing especially if you cant hear the timer motor.
Mar 28, 2009 | Zanussi TD4112W Electric Dryer
Maytag performa dryer vent got clogged and quit working
maytag performa dryer quit in middle of drying.
Dec 01, 2008 | Maytag Performa PAV2200
My Maytag Performa Oversize Capacity Dryer stopped working without a warning. It dried a load on the week-end without a problem. I put a load in on Wednesday, turned the dail to on
but there was no movement or sound.
HELP!
Jul 02, 2008 | Dryers
Maytag performa dryer assistance
Hello, My name is Juan. I will need help to find the problem with some suggestions. My dryer won't start at all, even when I open the door the light bulb inside the drum did not turn on. I check the power source it is ok. Please help with alternatives for a solution. Maytag electric dryer Mod # PYET344AYW
Thanks,
Juan J.
Jun 07, 2008 | Dryers
Dryer will not turn on
i've had my maytag dryer since 2002. it just stopped in the middle of a cycle. i think it's the motor. isn't maytag guaranteed for life???
Dec 22, 2007 | Maytag Dryers
Dryers Logo
726 people viewed this question
Top Dryers Experts
