Question about Brother IntelliFAX 2800 Laser Fax
What does fax reserved #53 mean - Brother IntelliFAX 2800 Laser Fax
    President:
  • 3,085 Answers
Fax number 53 never went through. Watch your machine, when it starts to REDIAL press STOP
Posted on Jun 28, 2009
What does it mean when the fax is in Sleep mode?
This means that is has gone into power reserve mode and is consuming less energy, however, the machine should still receive faxes without error. If you would like to change this setting, you can go into the options menu and turn sleep mode off.
-David.
Nov 02, 2010 | Brother Office Equipment & Supplies
The fax machine says "Fax Reserved" followed by a #. It will not allow me to send a fax. What does this mean and how do we fix it.
Turn off the main power, then hold down the Clear/Stop button and continue holding down for a few seconds after turning the power back on. This is the procedure for clearing anything that is stuck in memory and will not process which happens sometimes on these Brother machines.
Good Luck and Thank You for using Fixya.
Aug 25, 2010 | Brother IntelliFAX 4750 Plain Paper Laser...
How can i install the ink film?
Hello :
If you mean change then :
1: Turn the power off on your fax machine.
2: Open the front or top control panel Make sure not to force the door open.
3:Locate the ink cartridge. Gently pull the cartridge out. Set the cartridge aside.
4:Take the new cartridge out of the package and reserve the packaging. Remove the protective covers over the copper connectors.
5:Insert the new cartridge into the fax machine with the brand label toward you. Now place the old cartridge into the plastic wrapping and box that you reserved from the new cartridge. Recycle the old cartridge or dispose of it in the garbage.
6:Close the fax machine's access panel. Turn the fax machine's power back on.
Warning:
1:Touching the copper connectors on the ink cartridge could damage the cartridge. 2:Make sure that you purchase the correct cartridge for your fax machine. Purchasing the wrong one could damage the cartridge or your fax machine. good luck . please don't forget to rate !
Apr 04, 2010 | Panasonic KX-FHD331 Plain Paper Thermal...
Job Reservation Full
It means that the number of reserved jobs has exceeded 100. You can either wait for the reserved jobs to be completed, or check the jobs and delete the reserved jobs
Nov 11, 2009 | Toshiba E-Studio 3511 Color Copier
Fuel Reserve switch
Typically there are three positions to choose from. On means you are using the main tank. Reserve means reserve tank and off means no fuel available from either tank. the off setting is used when trailering your bike.
Aug 13, 2009 | 2000 Yamaha V Star 1100 Classic
Printer not receiving information from computer
I guess you mean the c350 is not printing while Windows said the job has been sent? If so, it may have changed IP Address from the time you first install the Printer on Windows. Check the Ports setting of the c350 printer! e.g. d53b002.jpg
Network Pritners should have Static IP address or at least a reserved DHCP IP Address. Logon to your Router, check the MAC Address of the c350 and reserve/assign it a IP Address near the end of the DHCP range. Save the Router configuration and power cycle the c350. Confirm IP Address changed to the reserved IP.
Then you have to change all the PC's Printer Configuration of the c350's Port to update the reserved/assigned IP. Or remove the c350 from Printers and Faxes, then run the printer setup software again.
May 23, 2009 | Konica Minolta bizhub 350 All-In-One Laser...
Fax Reserved
try unpluging the machine and the replug and let the machine reboot. brother tech
Jan 07, 2009 | Brother MFC-8440 All-In-One Laser Printer
Brother IntelliFAX 2800 Laser Fax Logo
847 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
