Question about Toshiba 62HM95 62" HDTV
Loud noise When I turn the tv on there is a loud noise when the color wheel of fan is starting (not sure which one). After it gets going there is a slight hum, but not as bad as when I first turned the tv on. The hum continues for a couple minutes after the tv is turned off. I may need a new lamp soon. Could a new lamp solve the problem? The humming noise seems to be coming from the same area as the lamp. Or is this the color wheel or a fan? If it is the color wheel or the fan, what are the average repair costs for those things? Thank you for any insight.
  • skonrad Feb 02, 2008
    We have had this same model for 17 mos. I was told sfter severla bul replacements that it is the the color wheel and another chip in it that is for the mirrors( sorry do not remember the name of part). We were told that it will cost almost as much to fix as we pd. If someone knows something I have missed.... My pic also has weird colors and rolls and the noise is horrible!
    Genius:
  • 1,139 Answers
I believe it is the color wheel. The motor might be going bad or it has dirt or dust in it.
I hope this helps
Shuttle83
Posted on Dec 21, 2007
Noisy sounds like a fan and the picture starts to flickers multiple colors and picture is scambled.
This tv have a colors wheel.The colors wheel is dead.The colors wheel is dying,going to be dead.The tv make loud humming,noisy sounds like a loud fans or motors noises.Also the tv colors flashes black&white or multiple colors pictures and scrambled.Colors wheel replacement is difficult,never done tv repair before.Hire a tv Tech. to replaced the tv colors wheel.
Nov 16, 2010 | Samsung HLN5065W 50" Rear Projection...
I'm experiencing a loud buzzing (fan?) sound that just started recently while watching my HLP5674W. The picture is fine, but the sound of what may be a fan or something like that is very loud and will...
Loud sound would be coming from defective color wheel that is mounted i light engine, next to lamp housing. Replacement of color wheel is required expertise/ experience and professional will do that for you in correct and in safe manner.
Contact local tv repair shop to get color wheel replaced in tv.
Thanks.
Oct 19, 2010 | Samsung HLP5674W 56" Rear Projection...
I have a rubbling noise when the TV is on. The picutre and the the souind is clear although you hear this loud rubbling (bad bearing noise) fromtheback of the TV. When you turn the TV of, the noise is...
This DLP tv have a colors wheel.No,the colors wheel is dying,just not dead yet.It spinning off of it motor axis,when it total dead it will have black&white pics,very loud squiling motor noises.Ur tv need a new colors wheel.Call the tv repair tech for this job,require take out many machanicals parts,before even can take the colors wheel to replaced.Never done this before,don't atemp to replaced the colors wheels ur self.
Jun 14, 2010 | Samsung DLP HL-P5663W 56" TV
Model 5063W - loud noise
The picture is pink, that would point more toward the color wheel, and you can see the fan through the vents in the back and you can go from there. It sounds more like the color wheel since you have a picture malfunction.
Jun 24, 2009 | Samsung HL-P5063W 50" Rear Projection HDTV
Loud Humming Noise
Samsung is notorious for having the motor on the color wheel burn out. If the color on the tv starts to fade or shift tones when the rev'ing or noise is happening then you'll know its the color wheel. There are only two moving parts in this set, the color wheel and the fans. If you're smelling something, it could be either. Take the back off the set and put a piece of tape on the lamp door switch and turn the set on. Try to pinpoint the source of the noise. If its a fan, no big deal, Radio shack should have a replacement. If it sounds like its comming from under the set, dig a little deeper and try unhooking the color wheel motor, not as easy as I am making it sound but either way the fan is about $20 to fix and the color wheel is about $100. Sure beats a $400 tech bill. If you get stuck, comment back and I'll send pictures of the dismantle.
Nov 28, 2008 | Samsung HL-P5063W 50" Rear Projection HDTV
Loud noise when Tv comes on souns like fan.
The loud noise is the color wheel winding down when you turn the TV off. You need to replace the color wheel.
Nov 15, 2008 | Samsung HLP4663W 46" Rear Projection HDTV
Loud buzzing noise
sounds like the color wheel needs to be replaced very easy repair on that model Samsung.
Jul 05, 2008 | Samsung HLR5067WX 50" Rear Projection HDTV
Big Screen gets loud, mad and turns off
without a model number, i can't be much help. if this is a newer dlp or similar tv, the fan is probably going out. some newer tv's have a fan that is part of the light assembly, some have a separate fan.. the loud whirring noise is usually caused by bad bearings or the blades of the fan may have become unbalanced, either way, the fan making the noise will need replacing. the color going is usually caused by the lcd or dlp overheating and/or the lamp overheating.
if the tv is out of warranty, remove the back panel, locate the fan making the noise, and search for a replacement. if you have a model number, i can check around and see if i can find the part number for you.
hope this helps,
trin
Nov 19, 2007 | Televison & Video
Loud buzzing noise
Yes,it sounds like the color wheel motor is going,and yes it satais on untill lamp cools down
Oct 13, 2007 | Toshiba 62HM95 62" HDTV
Toshiba 62HM95 62" HDTV Logo
437 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
