Question about Hotpoint NWXR473EV Dryer
Hotpoint reversomatic 9318-keeps tripping the rcd ring main breakers-why?
    Problem Solver:
  • 12 Answers
Could be anything timer motor heater .. have you checked if bearings are gone ? most likely spider has collapsed and dropped drum onto heater and cut through it
Posted on Sep 15, 2009
Advice on RCD tripping
yes
an accredited electrician can test the circuits for insulation failure , vermin shorting across active / neutral/ earth points and the rcd itself
it is not a diy job
May 12, 2017 | Ovens
Keeps tripping the electric mains replaced element but still does it HOTPOINT
Try increasing the ampere rating of your breaker or remove other load(i.e. aircon unit, water heater, washing machine etc.) when dryer is connected so as not to overload your breaker that is causing mains to trip. If previously you are using the dryer with the same setup and loads maybe the breaker is the problem.
Jan 19, 2015 | Hotpoint Dryers
Hob on my hotpoint oven trips my RCD
It is either a faulty ring, or the regulator that controls it is faulty.
You really need a meter to test the ring with to be certain which part is faulty.
Hope this helps.
Feb 21, 2010 | Ovens
Taking an amoured cable off the downstairs ring
Yes a 30mA RCD is required for any 240v outdoor use. Check if there is an RCD on the house main switch breaker first tho'.
Dec 15, 2009 | Electronics - Others
The main rcd keeps tripping off round about the same time everyday
do you have a fridge with a defrosting cycle? quite often when a fridge goes into defrosting mode it can dump some voltage to earth which trips the RCD. The other possibility is an electric pump turning on doing the same thing. or it could be a trouble with your power source. if you give me more information i could possibly help you more.
Oct 27, 2009 | Electrical Supplies
Hotpoint Aquarius SDW60 is tripping the mains power
is the circuit protected by an rcd/rcbo or a standard mcb as this may be a neutral to earth fault/insulation breaking down...try and get the machine portable appliance tested
Sep 05, 2009 | Hotpoint 24 in. FDW60 Free-standing...
Hotpoint washing machine keeps tripping electric
First unplug your washer. Check the ground on the washer and make sure it isn't loose; this would be a good time to inspect the wiring harness for any problems. Next check the outlet (turn off the electric to that breaker first) make sure all the wires are tight and are making good contact; pay special attention to the neutral (white) wire. If that seems fine, and you are comfortable with going into you breaker panel, turn off that breaker and check the hot (the wire on the breaker) to make sure it isn't loose and then check the neutral wire. If either of these wires seem loose tighten them down....a loose wire will move when a load is put on it and cause the breaker to trip. If all seems normal and washer is still tripping the breaker you might want to replace the breaker.....they can go bad. Good luck!
Aug 26, 2009 | Hotpoint Washing Machines
Neff U1421 main oven trips the circuit breaker.
It might be that the breaker is overloaded and it's no longer supporting the load of all the appliances together.If you do not want to change your breaker you can still use your oven by switching off other appliances that is running while you are using the oven
Feb 04, 2009 | Neff U1421 Double circotherm Electric Oven
I plugged in a vacum on the same outlet and the alarm went off what do i do
if the alarm went off when you plugged in your vacum it must be on the same circuit or on the rcd side of the consumer unit which must have tripped when you plugged in the vacum if you rewire the fuse or just turn on the trip on the breaker or on the rcd then reset your alarm and this doesnt sort it out or it keeps repeating then then ring a local electrician
Nov 29, 2008 | Televison & Video
Dryers Logo
200 people viewed this question
Top Hotpoint Dryers Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hotpoint Dryer Expert? Answer questions, earn points and help others
