Question about Whirlpool Washing Machines
Whirlpool Duet Model GHW9460. Code ''FH'' flashes during cycle. It is intermittent on all cycles. Some loads run to completion. All procedures in the service technician guide have been done. WL switch was replaced. Diagnostic test shows no problem. Should the CCU be replaced? What is the part number? Thanks Dan
the dr
  • 447 Answers
SOURCE: Whirlpool washing machine model GHW9460PWO, error code 11F
Yes it may be in the MCU but I had one do this and it was in the CCU. Has it ever thrown a Fdl ??? Door lock code?? Thats another sign its in the CCU
Posted on Jan 04, 2008
SOURCE: Whirlpool Duet Sport Front loading washer and dryer with error code
An easy Fix. Take off the kick panel, 3 screws 1/4 inch. Make sure you have a shop vac ready or a lot of towels as there will be some water. Always disconnect power to washer and dryer, and turn off water to washer. Your filter most likely is clogged with change, screws, lint, and other household stuff that we leave in our pockets! Unscrew the cap on the filter, easy to find, since you have the kick panel off! Take everything out of the filter. Take your shop vac and **** out remaining stuff in hose. Also, **** up any water that has leaked in and around the washer. Screw the cap back on hand tight, put the kick panel back on, turn your water back on, plug it in and there you go! Maybe takes an hour and saves you a repair bill. If you are not comfortable with this procedure then call a maintenance person that is qualified. 775f844.jpg
Posted on Jan 06, 2009
aborcass
  • 2651 Answers
SOURCE: whirlpool duet FH code
its possible you have the correct number, but yes the FH is a "no waterdetected" fault, are you sure you rehooked all wires in the rightt location and in the right position(it possible to put a harnes sin the wrong slot or even upside down, the only 2 CCU's out there for this model and of you had the wrong one you would get wrong cycle selections, not anything to do with the intake waster, i would really recheck your connections
Posted on Jan 16, 2009
rcalorisian
  • 313 Answers
SOURCE: Whirlpool Front Load - Code F 32 - Cannot open door
F32 is the code for Pressure Switch Failure. Which is only found on a tech computer. Remove the top panel from the washer by removing the three screws in the top back of the washer. Inside the back right corner is a round plastic box, either black or white, that is the pressure switch box. Check to make sure all the quick connect wires are connected and tight. Unplug washer to reset it. If the cycle fails still with the F32, you'll need to get a new Pressure switch box. If that doesn't fix it then it could be the control box( the bigger rectangular box in the front right that the wires connect to.) Good Luck and Happy Washing
Posted on Sep 14, 2009
Macmarkus
  • 2605 Answers
SOURCE: Kenmore HE2 Plus Washer CCU
Welcome to Fixya.
The central control unit, aka "CCU" is the control located to the right of the main console when you remove the top. ( approaching from the front )
The part number you want is W10205848 as listed by "searspartsdirect.com". ( Also available at many on-line vendors such as "repairclinic.com" which use there own stock number 1547531 )
I do see a fair bit of these since I am presently a Sears service technician ( after being independent for over 15 yrs. it`s an adjustment...but that`s another story :P ).
It should look like the image I`ve attached to help you identify it more easily...
Hope this answers your question. Thank you for choosing "FixYa" for your repair needs.
Please take a moment to rate the info I provided for you here and a testimony if you feel it warranted.
Thanks again and good luck.
macmarkus :)
Posted on Jul 11, 2010
Fh error code wirpool duet washer
Display shows F20 or FH - Front-load washer ' Whirlpool ...
https://www.whirlpool.com/...fh-front-load-...
Whirlpool Home AppliancesQuestion: Display shows F20 or FH - Front-load washer. Answer. Image. or. Image. or. Image. This error code indicates a water supply problem. Are both the hot ...
whirlpool duet error code FH - Appliance Repair Forum
forum.appliancepartspros.com > Appliance Repair Help > Washer Repair
Jan 5, 2009 - 10 posts - ‎1 author
... Repair Help > Washer Repair » whirlpool duet error code FH .... FH No water detected entering machine or Pressure switch trip not detected. Whirlpool Duet diagnostic code C:03 error code FH
1 post
Dec 5, 2014
Whirlpool Duet Washer HF Error Code
Jun 10, 2013
FH Error Code on Whirlpool Duet Washer
Mar 11, 2013
FH error code
Sep 13, 2008
More results from forum.appliancepartspros.com
Stumped on error code FH for Whirlpool Duet front load washer .
Jan 08, 2016 | Washing Machines
Whirlpool Duet washer FH code "sometimes"
well..based on what you're stating here..sounds more like a sensor, based on the duty cycle.
Jun 04, 2008 | Whirlpool Duet GHW9150P Front Load Washer
During a normal wash cycle, the error code FH occurs. The owners manual says inlet problem. All water pressure is good and inlet screens are clear. Drain function appears to work well. Repair guy came...
If the flow meter does not register 10 and 1/2 gallons of water in 8 minutes the FH code appears.
Could be a bad flow meter, sensor, wiring harness is loose or a bad CCU Central Control Unit.
At the RINSE cycle if water enters the machine you must time the water fill for 8 minutes or less.
If water does not enter the machine suspect the CCU as bad.
Jan 06, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Error code F H keeps being displayed about 8 minutes into a cycle. What do I do? Please help laundry is mounding up!!!!
flashes if the washer loses power during a running cycle. The washer does not flash FH" when it is first plugged in.
Press START to continue the cycle from the moment that power was lost
-OR-
Press STOP/CANCEL to clear the display and completely cancel the cycle.
Mar 09, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Drain
kathy..theres three screws at the bottom panel...remove them,,always unplug first...and you will see your pump claen your filter,,ok onthejob,,just screw it out
Jan 08, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet model GHW9150PW3
I cleaned my drain pump fiter (F02 ). When I put everything back together and tried a cycle, there is no water flow resulting in FH. I did not touch the water supply. Help!
Aug 11, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
151 people viewed this question
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
