Question about Cisco 7940 IP Phone
Phone is stuck on Ethernet Disconnected. I all keys such as settings are unresponsive. I can and have already done the *6Settings to reset using the # followed by 123456789*0# and resettting network config. It still remains stuck at ethernet disconnected.
    President:
  • 2,923 Answers
You mentioned that all keys are unresponsive? How about the 'Menu', is it included? If the 'Menu' is still responding, you may want to try the following:
1. Menu > Phone Settings > Factory Default.
* the phone displays 'Restore to Default'
2. Press OK.
3. Menu > Network Config...then configure the network settings.
If even the Menu is not responding, disconnect all the cables connected to the phone and make sure that it's turned OFF. Leave the phone off for about 5 minutes and reconnect every cables.
Posted on Jun 26, 2009
Samsung galaxy ace duos S6802 incoming call always busy. I try to hard reset nothing happens. Call forwarding are disabled. Please help me to fix.it
When a Samsung cell phone becomes unresponsive or when the device slows to a crawl, a reset may be in order. There are two primary methods used to reset the phone. Users should always start with the soft reset when the phone locks up or programs slow down due to memory or software response issues. A soft reset is akin to a reboot of the machine and usually solves most problems without any loss of user data. A hard, or master, reset is required when the phone completely locks up and becomes unresponsive to any cellular signals. This second and more drastic reset deletes all personal data, preferences and settings so that the device is restored to the original factory configuration.
Perform a Soft Reset
Step 1 Press and hold the power button for 10 to 20 seconds.
Step 2 Release the power button and tap the "Power Off" option under the "Device Options" menu that appears. Tap "OK" to initiate the shutdown.
Step 3 Press the power button again to restart the device.
Perform a Hard (Master) Reset
Step 1 Tap the "Menu" key from the home screen and then tap "Settings."
Step 2 Go to "Privacy" and tap "Factory Data Reset" to review the Factory Data Reset information.
Step 3 Review the Factory Reset options. Place a check next to "Format USB Storage" to clear your device of user data, such as music, pictures and other account settings.
Step 4 Review the disclaimer and verify your changes before tapping "Reset phone."
Step 5 Tap the "Erase Everything" or "Yes" buttons to confirm the reset the phone to factory settings. The device initiates the restoration process to the original factory configuration.
Perform an Alternative Soft Reset
Step 1 Power off the phone. If the phone does not turn off, remove the back cover of the phone and take out the battery. Wait between 10 and 30 seconds and then replace both the battery and the cover to restart the device.
Step 2 Simultaneously hold down the power/lock keys.
Step 3 Release the keys when the Android screen appears.
Tips
  • The ATT Samsung SII models have an alternative hard reset that requires you to simultaneously hold down the "Volume Down" and power keys after an alternative soft reset, and then release the power button, bringing up the menu titled "Fastbook, Recovery, Clear Storage, and Simlock." Use the "Volume Down" key to navigate to "Clear Storage" and then press the power button. Press" Volume Up" for "Yes" and "Volume Down" for "No." This will reset your device to its original factory setting.
  • A soft reset on a Galaxy S phone involves pressing the "Volume Up" key simultaneously with the power button.
  • Some older Samsung models have a reset button located behind the battery cover. Press the reset button using a small, blunt object.
Warnings
  • A factory data reset removes all user data and settings associated with the current account. Make a backup of all data on your device before starting a hard reset.
May 12, 2014 | Cell Phones
STARTING UP PROBLEM WITH MY SAMSUNG GT19100
Hi Adil,
Do you happen to know when this issue started? Usually restarting or shutting down phone resolve the issue. If not you may want to do reset ( soft or hard ).
Apr 29, 2014 | Samsung Cell Phones
SAMSUNG GT19100 STARTING UP PROBLEM
Hi Adil,
Apr 29, 2014 | Cell Phones
My Samsung intercept won't load past the flashing Samsung so I was trying to factory hard reset it and it won't even do that I attached a photo of what it says
Hi Latonya,
Apr 28, 2014 | Cell Phones
How to reset my phone password easily?
Hi Ronquillo,
Apr 28, 2014 | Samsung Galaxy Y Gt-s5360 Pink Factory...
I forget my security code of nokia 710
Master reset with hardware keys A master reset restores the original factory settings and may delete your personal data on the internal storage, such as downloaded content, ringtones, images, apps, and contacts. It does not delete data stored on the SIM card or SD card.
If the device menus are frozen or unresponsive, you can master reset using hardware keys. To perform a master reset, follow these steps:
  1. Power the phone off.
  2. With the phone off, press and hold the volume down, power, and camera keys.
  3. When the phone vibrates, release the Power key.
  4. Continue to hold the volume and camera keys for another five seconds and then release.
  5. The phone will reset and restart automatically.
Jan 26, 2014 | Nokia Lumia 710
Set up for Blue Tooth
Please specify your phone make or model
Jan 17, 2014 | 2013 Toyota Venza
MVP V Model CMV1000ADW
From the description it is the keypad control board problem, membrane "shorts" replacement only option.
Apr 04, 2012 | Maytag Appliances Over-the-Range Microwave...
Master reset htc phone
Hard or master reset
A hard reset restores the original factory settings and may erase all downloaded content, including ringtones, images, programs, and contacts stored in the internal memory. To perform a hard reset, follow these steps:
  1. Back up all necessary data by copying any files you want to save from your phone to your computer.
  2. From the Start screen, swipe left.
  3. Tap Settings.
  4. Tap about.
  5. Tap reset your phone.
  6. Tap yes.
Hard or master reset using hardware buttons
If the phone is locked, frozen, or unresponsive, you can hard reset it using the hardware keys instead of the menu. A hard reset restores the original factory settings and may erase all downloaded content, including ringtones, images, programs, and contacts stored in the internal memory. To perform a hard reset using hardware keys, follow these steps:
  2. With the phone turned off, press and hold the Volume Up and Volume Down keys.
  3. While still pressing the Volume keys, quickly press the Power/Lock key.
  4. When the device displays 'This operation will delete all your personal data, and reset all settings to manufacturer default. Press Vol Down to restore manufacturer default, or press other keys to cancel.', release the Volume keys.
  5. Press the Volume Down key to reset the device.
Dec 08, 2011 | HTC HD Windows Phone 7
Open Questions:
See all Cisco 7940 IP Phone Questions
Cisco 7940 IP Phone Logo
470 people viewed this question
Top Cisco Computers & Internet Experts
Gopi Venkatesan
Gopi Venkatesan
Prashant M
Prashant M
Are you a Cisco Computer and Internet Expert? Answer questions, earn points and help others
