Question about Sharp 25N-M100 25" TV
Trouble in sharp t.v.
When i turn on the power switch of t.v. it does not flow to the cicuit and did not produce picture or sound.
  • 1,694 Answers
Check horiz output transistor and solder any / all bad connects,
Check fuses.......T.
Posted on Nov 07, 2007
Replaced turn signal switch and still no rear lights,gauges cluster not working, no power to the radio, heating and cooling control has no power, no turn signals, no brake lights but the head lights w
disconnect the switch you put in and try it, sounds like there could be a short, did you work near anything that might have got bumped? turn on the vehicle and see which cicuit the problem is in by using your test light or multimeter on each cicuit untill you can find the one giving you the trouble, sometimes wiring harnesses wear and you get an open short, start at your battery and check every connection all the way to the back noting condition of the wires, no easy fix on this sorry, check the second fuse box under the hood along the firewall as well if yours has this
Jan 02, 2015 | 1995 Nissan Pickup
I have a power supply and sound but no picture when i switch the television on i get a picture for a split second then just a black screen with sound
This problems is 100% of those 2 long LCD inverter boards in the tv sides left and right.Those 2 long LCD inverter boards to the lelf and to the right are dead.Those 2 long LCD inverter boards help the LCD screen panel to have a backlight to produced a picture.Tries websites like, to buy those 2 long LCD inverter boards for the replacement.
Nov 25, 2010 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Sound good, no picture
Now turn on the tv? Have a flickers of picture a few sec. than dies have sound left only?Yes,than the long LCD inverter board it dead.This long LCD inverter board help the LCD screen panel to have a backlight to produced a picture.Tries websites like, to buy a refurbish long LCD inverter board for the replacement.
Aug 03, 2010 | Sharp LC-19SB25U 19 in. LCD HDTV
The tv screen is black and wont turn off no sound no picture can only turn it off by unpluging
Good day sir, hi, as i see it, there is a problem with the tv's power board. this board produce stable power to the main board that controls the sound, and picture. Replacing the board is highly technical, you need to get the exact board replacement which you can only get on your dealer, call them for service. Check first the warranty.
Jan 19, 2010 | Sharp Aquos LC-32G4U 32 in. HD-Ready LCD...
Sharp 2DR-S100S Ticking sound, will not turn on
does it tick all the time are just a few minutes and can you turn it off and back real qiuck and see or hear high voltage come on are see a flash is sounds like you have what is know as startup are shutdown circuit trouble
Feb 22, 2009 | Sharp 25R-S100 25" TV
Lost of power
sounds like you need to refit carburator w/ a larger main jet to richen that cicuit at approx.7/8 to wide open throttle. this is very often necessary when switching from stock to aftermarket hi- flow exhaust system.
Feb 16, 2009 | 2002 Suzuki VL 800 Volusia
i have problem in Sharp AR 200,and i dont know haw to fix,error code F5
Jan 21, 2008 | Sharp AR-160 Copier
Good day.
Try to check if the fuse of your tv is busted. Also, try to look for any burnt parts.
Nov 06, 2007 | Sharp 32C-240 32" TV
Sharp 25N-M100 25" TV Logo
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
