Question about MSI K7N2 Delta-ILSR (MS-6570-030) Motherboard
USB port problems
2 things, i got a custom cmputer case and the top of the case has two usb ports a microphone port and a speaker output port, i dont know where to plug in the extra cables to the mother board,2: only controlers work in the usb ports. No usb flash drive or thumb drive works, how can i fix this?
    New Friend:
If can't work than you can use font usb port.
Thank you.
Full Version Software
Posted on Nov 25, 2013
  • 2,019 Answers
You need the motherboard specs, which you can look up on the internet, based on the maker.
With the USB ports, the front ones often don't include power.
So plug a powered 4 port hub into the front port, and then the hub will supply the power after that.
Posted on Jun 26, 2009
Schematics compaq cq5210y x2
1 - PS/2 mouse port (green)
2 - PS/2 keyboard port (purple)
3 - Video Graphics Adapter port
4 - USB 2.0 ports 4
5 - RJ45 Network (LAN)
6 - Line In port (light blue)
7 - Line Out port (lime)
8 - Microphone port (pink)
Apr 10, 2014 | Dell Audio Players & Recorders
Bad sound quality
You cannot connect the turntable via a microphone port. You need to connect via a USB port. If you have not got a USB port to connect it as the others are in use, you can buy an extension USB socket which, will allow you to put more devices via one USB port.
Sep 04, 2013 | ION Audio Vinyl Recording Turntable
I have xpod speaker i dont no wich lade is audio input and output
u have not described ur problem completely....i.e. the model or name of xpod speaker. and a speaker has only one lead and that is for output.however , if u have more than one leads that may be for microphone. the microphone lead end is pink (in some cases) and the speaker lead is green and it is the same colr for mic and speaker at the back of computer. simply play any media file in any media player and plug any of the lead in the green port at the back side of system unit(cpu).(if voice comes insert the other lead in pink port).otherwise insert the other lead in the green port and speaker will work
May 04, 2011 | Computers & Internet
The speakers quit working/what do I do?
Make sure that it is the speakers that stopped working by unplugging them from your computer (or whatever you have them plugged into), and plugging headphones into the same jack that the speakers were plugged into.If the headphones work, you have confirmed that the problem is with the speakers. If the speakers use an AC adapter (black plastic cubical thing that plugs into the wall), then you might try getting a replacement AC adapter with the same output (AC or DC), voltage, polarity (which side is positive, and which is negative), and connector. If the speakers plugged into a USB port for power, your USB port may have turned itself off. In that case, reboot the computer to see if the USB port will turn back on.
If none of this works, you have to buy new speakers.
Apr 18, 2011 | HP JBL Platinum Computer Speakers
New pair of La Cie speakers. Dell pc. Not sure whee o plug in varous leads, but it now does the beefs etc on Windows. But when I put a CD in there is no sound at all
I think you were disconnected from our conversation. Anyway, the LaCie speaker is USB powered so you dont have to plug it into a power source because they will be powered by the USB port. You dont need to plug them into a speaker output on the computer as well. Just plug the USB cable of the speaker into your computer's usb port. As for the other speaker, there is a cord that used to connect the speakers together. Just plug it underneath the first speaker, that says "speaker" source. Then go to your Control panel >> Multimedia >> Audio and choose them as your Audio Output device.
Mar 04, 2010 | Computers & Internet
Emachine t1840 wiring diagram power switch wire to mother board ?
Because there are so many different case and motherboard combinations sometimes it can be difficult following the instructions for connecting the front panel, USB header and audio header.
Below is a few generic guide that should stop some of the confusion with the labels on the wires.
Front Panel Audio
***Please note this is a generic wiring guide and we can not guarantee it will work with every motherboard. Please check your motherboard manual first. Wiring the headers wrong can cause damage to the motherboard and case, this damage is not covered by the warranty***
another handy USB wiring guide can be found here http://www.directron.com/installusb.html
this maybe easier to follow
FRONT PANEL AUDIO
2________10
__
1________9
Pin Wire
1) Mic In
2) GND (ground) or if 2xGND available, it’s the GND for the headphones, NOT the Mic
3) Mic BIAS
4) n/c
5) Speaker Right Out
6) Speaker Right Return
7) n/c
8) no pin (n/c)
9) Speaker Left Out
10) Speaker Left Return
n/c = not connected
USB (F_USB1 and also F_USB2)
2________10
 x
1________9
Top row of pins
2 = USB port 2 : VCC/Power/+5V
4 = USB port 2 : Data -/D-
6 = USB port 2 : Data +/D+
8 = USB port 2 : Ground/GND
10 = USB port 2 : pin present, but not connected to anything.
Bottom row of pins
1 = USB port 1 : VCC/Power/+5V
3 = USB port 1 : Data -/D-
5 = USB port 1 : Data +/D+
7 = USB port 1 : Ground/GND
9 = USB port 1 : no pin present
Front Panel Connector (FP1)
1 2
x 
9 10
1 = no pin present
3 & 5 = Power Switch
7 & 9 = Power LED (light)
2 = pin present, but not connected to anything.
4 & 6 = Reset Switch
8 = 10 = Hard Drive LED (light)
Jul 30, 2009 | Computers & Internet
Front panel connector J16 dell dimension 2350
Visit http://support.dell.com select your product and download user manual and maintenance manual. It may solve your problem.
Jul 15, 2009 | Computers & Internet
Pluging in extra usb ports/Mic and headphone jacks from the tower
Answer me this. You're case is an Antec tower? The motherboard is the Asus P4P800 SE ? Is this correct?
If you have you're manual you can see what goes where on the board for front panel connector page. 2-31. (This diagram shows you how to connect the front mic & speaker).
To connect the Antec's front USB ports plug the case USB front connectors onto USB56 & USB78 shown on page. 2-30. Most case wires are already set within their USB connectors & the Antec's front USB connector should fit right on the mother board's pin's. If you need you're user manual, download from Asus by clicking on this link. http://support.asus.com/download/download.aspx?modelname=P4P800%20SE&SLanguage=en-us
Good Luck!
Mike
May 19, 2008 | ASUS P4P800SE Motherboard
NO SOUND ON PLAY-BACK
I had a similar problem but I just plugged in some heaphones into the mic and I got everything in the DAW to play back through them.
May 18, 2008 | Samson G-TRACK USB RECORDING MICROPHONE...
I get no sound and my my microphone doesnt work.
man this is all **** i got same problem no one knows how to fix !!!
Jul 22, 2007 | Logitech 250 Headset
MSI K7N2 Delta-ILSR (MS-6570-030) Motherboard Logo
231 people viewed this question
Top MSI Computers & Internet Experts
vsri9
Alun Cox
David
David
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
