Question about Singer CE-200 Quantum Futura Computerized Sewing Machine
Bobbin case The entire bobbin case in my Singer CE-200 jammed and tilted while doing embroidery. How can I solve this problem. I have tried over and over to fit the case back into the slot, but in the middle of a project it jams and tilts again. Could the case be damaged or what has happened? I cannot continue to stop fix the case and it constantly jump out of place.... Any suggestions....Thanks Barb
  • MbroidRR Nov 13, 2007
    Same problem as AuntB's -- mine will also break the needle at times when the bobbin case shifts. I've tried everything I can think of and it still does the same thing.
  • Sharon Nunnnally Jun 07, 2013
    I have a brand new Singer xl 550 that does the same thing.
    Scholar:
  • 110 Answers
If your machine is older than 18 months, it needs a free upgrade from your dealer. The plastic see through needle plate needs to be replaced by a newer version that will keep the bobbin down. Further more a bobbin case position finger needs to be installed.
Posted on Nov 13, 2007
Unfortunately, they are made of plastic, and wear out and become chipped when this happens. You have to buy a new bobbin case. The cheapest I found online is $17.00. A new one will be smooth around the edge. A worn one, will have what looks like a large groove, or any type of groove. You will know when you purchase a new one what it should look like, and compare it. They you will know when it is time to replace. I try to keep one on hand at all times because of this problem.
Posted on Nov 18, 2010
When I embroidery bobbin jams
Please you buy a new model embroidery machine.
Jan 01, 2014 | Singer 5050 Mechanical Sewing Machine
My Singer Futura sewing/embroidery CE-200 machine is malfunctioning. It will sew a few stitches and then make this horrible sound and doesn't move. Once stopped, the needle feels like it is boun
try changing the needle--make sure the needle is correct for the fabric
clean under the needle plate & in the bobbin area for lint or loose threads
if it keeps jamming up & making noises I suggest to have the machine
serviced
Apr 12, 2012 | Singer CE-200 Quantum Futura Computerized...
When I go to fill my bobbin spool, the machine just beeps at me. I've tried everything. Please help!
If you try to wind the bobbin with the embroidery unit on, you need to send a design to the machine before trying to wind the bobbin. If the embroidery unit is off, you should wind the bobbins without any problems
Aug 22, 2011 | Singer CE-200 Quantum Futura Computerized...
Bobbin case is popping out, and machine is birdnesting
Usually when this happens the bobbin is in wrong, replace it make sure the thread is going out the right way, make sure there is no lint or small pieces of thread around or underneath the bobbin area. Make sure you thread it with the foot up. Also make sure you are usng the right bobbin for the machine. They can easy get mxed up.
Jun 16, 2009 | Singer CE-100 Futura Computerized Sewing...
A brand new Singer Quantum Futura CE 200 Sewing/Embroidery machine, have not been able to embroider or sew a single stich, all I have been able to do is wind the bobbin. When I'm going to start...
Dear Magarita, The safety device is activated when thread gets entangled around the bobbin case. First check by removing the plastic see-through plate. If necessary remove the 2 scews on the metal needle plate and remove the bobbin case completely. Put it back and test by turning the handwheel. It should turn freely.
Hope this solves your problem.
Dec 08, 2008 | Singer CE-200 Quantum Futura Computerized...
Futura ce-100(Singer)
Sounds like a tension problem. Email the singer company at talktous@singerco.com They should be able to help!
They responded back to me the same day.
Nov 17, 2008 | Singer CE-100 Futura Computerized Sewing...
BOBBIN SLIPPING AND STOP EMBROIDERY
First,call the technician and see if he will honor a warranty on his repair work. Next, sew on the machine until it messes up again. Do NOT take all the stuff loose. Take the machine, the garment, the thread,everything just as it is to the technician. Don't even lift the presser foot. He will probably find the problem.
Usually, on a problem such as this, it is the wrong bobbin, the bobbin inserted the wrong way, the tension not working , not threaded correctly, a rough spot on the bobbin case or the bobbin case is not properly positioned.Some times the thread jumps out of the thread take up lever.
sewman7
Aug 25, 2008 | Singer CE-200 Quantum Futura Computerized...
Singer futura CE-200 Can not wind the bobbin thread
In embroidery mode, you have to send a design to the machine before the bobbin winder will work.
Jan 30, 2008 | Singer CE-200 Quantum Futura Computerized...
Problem with bobbin case - new machine Singer CE 100
My problem is solved (I think...that is a knock on wood kind of thing). Upon recommendation from another Futura user, I remove and clean my bobbin case and I put a drop of oil in the little hole under my bobbin case about every 5th or 6th monogram use. AND, I pitched all of my bobbins that were 15 and not 15J (I had some that were 15 and they were the culprit as well.) I have had no more problem. It seemed the least bit of lint caused me a lot of birdnesting. I also stopped using rayon thread and use only polyester and bobbin fill in the bobbin. I have got to say I am thoroughly enjoying my machine these days. Please try these things before giving up on this so user friendly machine.
Nov 22, 2007 | Singer CE-100 Futura Computerized Sewing...
Singer futura ce-100 embroidery machine
Under the embroidery attachement (on the front side) is a lever to engage or disengage the "feed dog control." When embroidering, you need to move the lever to the level to disengage. The feed dog control should only be at the righe side position, or raised when you are not using the embroidery attatchment.
Jan 31, 2007 | Singer CE-100 Futura Computerized Sewing...
Singer CE-200 Quantum Futura Computerized Sewing Machine Logo
383 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
