Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
Hissing noise from flyback transformer
Picture plays but there is a hissing noise from flyback transformer. Where can I get clear instructions to replace it I decide to do it myself?
  • 119 Answers
SOURCE: 56" RCA projection TV (FLYBACK related problem)
the base to emitter of the hot will read short on a diode checker/test on ohms it vairies but typically about 50 ohms.e to c, or b to c should have very high resistance. unsolder the collector of the hot. make sure all solder is gone. now test the ohm between your tuner ground & the pad of the hot collector it should read open.
Posted on Jan 16, 2007
  • 317 Answers
SOURCE: Flyback Transformer replacement instructions?
remove solder from all pins and squeeze clips to remove...
Posted on Oct 19, 2007
premtech
  • 934 Answers
SOURCE: RCA P52937 Flyback Transformer question
The lead going from the flyback to that other device is a voltage divider or splitter as they're incorrectly referred to... To remove the leads press down firmly, twist and then pull up...
Bill
Posted on Dec 16, 2007
Slinteriors
  • 8617 Answers
Yes you can get the replacement flyback which is flyback 259296 at the following link and they provide free tech support to do the repair . Its a very easy repair takes about 20 minutes and requires the very basic soldering skills. heres the link.
http://servicemanuals.vstore.ca/
Posted on May 19, 2008
SOURCE: I am replacing the flyback transformer
The wires don't come off the flyback. You have to take the front cover off where the speakers are. Trace them and unplug them.
Posted on Nov 08, 2008
Samsung CRT flyback problem
When fly-back transformer gets damaged, there is a chance to a leak to its horizontal output transistor too. Replace this too. If you wish to get some details, check the site linked here.Pull up older posts.
Dec 07, 2013 | Televison & Video
Keeps turing itself off making a hissing sound and turns off, also have a problem with the converange, will not go thur the auto converence picture concave
Resolders the FBT,the flyback transformer.Change the FL231 fuse cap the one in the middle out three near the flyback transformer.
Dec 13, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Flyback transformer
A flyback transformer is one of the more expensive components in a projection TV. If there is no clear reason, such as a known power surge, you could well replace the flyback transformer again soon because the root problem was elsewhere.
An OEM transformer is not necessary but you might have trouble convincing an authorized factory service technician to use anything but the original manufacturer's parts.
As with many of today's electronic devices, if it is more than a year or two old, you will find the new products cheaper and with more features. The next generation of projection TVs will use lasers and scanning will be done with optically controlled micro-mirrors - no flyback transformer required.
Oct 07, 2009 | Toshiba Televison & Video
There is a hissing noise in back of tv and picture goes on and off zenith d36d51
Hissing noise and picture on and off means faulty flyback transformer, it has a small crack and voltage is leaking out, replace the flyback, if tv still not working replace horizontal output transistor (broken flyback could blow the transistor).
Aug 09, 2009 | Zenith D36D51 36" TV
No picture no sound just a whistling noise
maybe the flyback transformer or horizontal output ic
Jun 01, 2009 | RCA 27R411T 27" TV
TV Just Started Making a Humming/Buzzing sound
Replacing a flyback is not something I would suggest for anyone with no electronics experience. Second, lets see where the noise is coming from first. Take off the back and listen to the noise. The flyback will be at one end of the large red wires that go to the tubes. Sometimes the connection at the tube is not 100% and the noise comes from there. BE CAREFUL - there are high voltages going through this red wire that can be dangerous even with the set UNPLUGGED!! IF the noise is coming from the connection at the tube, with the set unplugged, carefully turn the rubber cap back and forth touching only the rubber part with one hand. Put the other hand in you pocket while doing this.
If the noise comes from the flyback side, if you can solder, again with the set unplugged, try resoldering the pins on the transformers. That may resolve the problem.
Keep me posted.
Dan
Feb 13, 2009 | Samsung HCL5515W 55" Rear Projection...
Wont turn on smell burning
Can you remove the rear panel and check if the hissing is coming from the flyback? Which is a large transformer with a large red wire coming from the top of it? If so can post a link where you can get a replacement their not exspensive and their easy to replace. If its not coming from the flyback post a picture of where the hissing is coming from and I will identify the parts for you, But I feel its the flyback due to the hissing. respond to this same post so I have your correct model number when you reply.
Jun 25, 2008 | Zenith R57W46 57" Rear Projection...
Oct 12, 2007 | RCA D52W20 52" Rear Projection HDTV-Ready...
Scrambled Picture/Snow Screen, has sound, can play DVDs through colorstream
I had this with a rca once. Can you hear a crackeling noise coming from the flyback transformer? My problem was just the wire was loose
Sep 27, 2007 | Toshiba TP50H50 50" Rear Projection...
Jan 16, 2007 | RCA P52921 52" Rear Projection Television
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
784 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
