Question about Lexmark C510 Laser Printer
A Lexmark C510 printer prints horizontal 1 1/2 blk and mag lines
A Lexmark C510 printer prints horizontal black and magenta 1 1/2 inch lines on two-thirds of paper while the rest of the paper is blank. The display does not show any error messages (e.g. replace toner or fuser exhausted.
    President:
  • Lexmark Master
  • 1,447 Answers
It is the problem your copier drum unite
Posted on Jun 28, 2009
Hi, can Lexmark C510 printer print black and white only?
YOU CAN GO TO THE PRINTER PRINT PREFERENCES AND CHECK THE BOX FOR GREYSCALE ONLY.
Jun 04, 2012 | Lexmark C510 Laser Printer
Lexmark C510 is making grinding noises while printing large jobs
I found another posting stating that the culprit was the black toner cartridge. Sure enough I changed our black cartridge and the grinding noise has stopped. No wonder the grinding noise was not happening all the time only when the black cartridge got low. Thanks for the help!
Oct 15, 2009 | Lexmark C510 Laser Printer
ON Lexmark C510: On left edge of paper, I have small lines
your copier scaner mirror is dust over clean it then solve it
Jun 25, 2009 | Lexmark C510 Laser Printer
Can't print in color
A technique to improve print quality is to try and clean the cartridge nozzles. You may clean the cartridge by following the steps given below:
1. Go to the "Lexmark solution center." This can be done by clicking on "Start," go to "Programs" and Lexmark printer group. Click on the "Lexmark Solution center." Next click on the "Maintenance" Tab.  2. Select "Clean and Fix Horizontal streaks."  Click on "Print". This will produce a printed page.
The colors that you should see here are black, yellow, magenta (a reddish purple) and cyan (a dark sky blue). You should notice the diagonal lines above and below the solid horizontal lines. These diagonal lines should be solid from left to right with no gaps.
If there are gaps in the lines or the print diminishes across the page, you should run the "Clean Print Nozzle" page a couple more times to try and clear it up. If you still have gaps at the top and bottom, you should "wick" the cartridges by following the steps given below:
1. Please open the "Solution center" again and go to the "Maintenance" Tab.  2. Select "Install color/black cartridge" and remove the cartridge or cartridges from the printer.  3. Get a damp paper towel.  4. Set the ink cartridge right side up on the damp paper towel so that the ink nozzles are against the towel and hold the cartridge in this position for about 15 seconds.  5. Now wipe the print head (on the bottom where the ink comes out) across in one direction only (left to right) until it looks clean.  6. Next dab the cartridge on the towel to make sure that the ink is flowing.  7. Snap the cartridges back into the printer.  8. On your computer, select "Old Cartridge install."  9. Repeat the "Clean Nozzle Page" one more time. If this fails to address the problem the entire procedure may need repeating.
May 26, 2009 | Lexmark JetPrinter Z11 InkJet Color...
How to clean Lexmark Z1320 printer.
hi..
You can clean the cartridge using the following steps:
Click on "Start," go to "All Programs," and down to the Lexmark. Click on the "Solution Center." Next, click on the "Maintenance" tab. Select "Clean to fix horizontal strips." This will produce a printed page.
If there are gaps in the lines or the print diminishes across the page, you should run the "Clean to fix horizontal strips" page a couple more times to try and clear it up. If you still have gaps at the top and bottom, you should "wick" the cartridges by following the steps given below:
1. Please open the "Solution Center" again and go to the "Maintenance" Tab.
2. Select "Install color/black cartridge" and remove the cartridge (or cartridges) from the printer.
5. Now wipe the print head (on the bottom where the ink comes out) across in one direction only (left to right) until it looks clean. Also, wipe the contacts inside the printer (on cartridge carrier).
9. Repeat the "Clean to fix horizontal strips" one more time. If this fails to address the problem, the entire procedure may need repeating.
try out..
Apr 23, 2009 | Lexmark Z1320 InkJet Printer
C912 horizontal lines in print
change your magenta led it sounds like that may be faulty big job if not theat then its a new rip baord which is under the cover
Mar 12, 2008 | Lexmark C912 Led Printer
Lexmark C510 printing problem
goto menu "1" -- find black and white lock and set to off. I almost threw out a printer that was given to me because of a menu setting.
Feb 22, 2008 | Lexmark C510 Laser Printer
Lexmark C510
try to clean the toner from tissue paper or if you want good quality you replace the toner or copen the cover of printer toner and clean is there any ink powder is there. bye
Sep 21, 2007 | Lexmark C510 Laser Printer
Lexmark C510 Laser Printer Logo
281 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
