Question about Bryant 462AJC021BA Air Conditioner
Bryant outdoor model # 567A-018E it humms like
Bryant outdoor model # 567A-018E it humms like the thurmostat is sending a signal but nothing happens
  • 146 Answers
Open up it is probably the contractors. and easy fix you can push them down manually but be careful they are HOT- LIVE.if not sure call someone who does!
Posted on Jun 26, 2009
Bryant 4 ton outdoor unit coils got hot fan works Is it repairable. Thx
That's means the coils is dirty .just shut unit off and washed coil with water until clean
Jun 28, 2017 | Bryant Heating & Cooling
Why doesn't the GPS pick up a current GPS signal?
You may need to do it outdoors; a building may interrupt enough satellite signal that it (the GPS) won't lock to it (the signal).
If it always says "GPS SIGNAL NOT DETECTED" when it's outdoors, I don't think you're going to get it to ever work. It may have been dropped & the internal antenna damaged.
Jul 26, 2014 | InVion GPS
I am trouble shooting a Bryant Hi-bred system that uses an air cooled heat pump with high efficiency gas furnace for backup and low ambient operation. How does the system decide whether to use the air...
Your t-stat should be set up so that the furnace is the second stage heat and also emergency heat. First stage (heat Pump comes on) sometimes they use Time to start 2nd stage, sometimes they use outdoor temp and this all bepends how bryant has set it up, without a model # I cannot tell you but send it and i will look in somebooks i have to tell you.
Mar 01, 2011 | Bryant Heating & Cooling
I am replacing a four year old Bryant thermostat (7 wire) that runs a Bryant heat pump and gas furnace. I connected the Honeywell EIM to the old wires using the same colort codes: W = W (o/b); Orange =...
Well you are naming 6 colors, where is 7?? I'm guessing you don't have a constant 24 going to the heat pump and there is no transformer outside. Send model number of indoor and outdoor, double check your wiring, double check your setup.
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
Aug 13, 2017 | Heating & Cooling
My intertherm electric furnace in mobile home will not come on. could it be the seqencer
yep,could be,if fan is on.if nothing is comeing on,it is probbaly the low voltage.buuuuut first things first.you could get a big shock checking them.is there 220 getting to furnace?.is there 24 volts at transformer secondary?I check to see if coils are open first because you can do this with power off.is signal from thurmostat ok? I went on a call recently where they just needed new battery in thurmostat.good luck and don't get electrocuted.
Dec 24, 2010 | Heating & Cooling
What is the seer rating and tonnage of a bryant model fb4anf030
The Tonnage appears to be 2 1/2 ton,
024=24,000 BTU=2ton
030=30,000 BTU=2 1/2ton
036=36,000 BTU= 3ton
I dont think you have the correct Model Number, Look
on the outdoor unit, the model number might start with a 38. Hint Carrier and Bryant Products are the Same, just different nametag
Feb 17, 2010 | Heating & Cooling
The outdoor fan on my central a/c is suddenly making a lot of noise. I have a Bryant - model #697CNO36. Thanks
Depending on the age and usage of the motor. And whether or not the motor is an oil-free motor or not will help to determine the problem.
Most times, a loud noise coming from a motor itself is contributed to the bearings going bad in the motor. This can be cause by lack of maintenance, blades out of balance, or the blade too far down the shaft and creating unusual wear on the motor.
You will most likely need to replace the motor and run capacitor in order to get rid of the noise. But only finding out how and why the noise started will allow you to prevent it from happening again.
Jan 12, 2010 | Bryant 463AAC008BA Air Conditioner
What is the part number for the outdoor fan motor?
as old as this unit is you probably cannot read the label on the motor it is either a 1/4 or 1/3 horse power 230 volt motor. a generic motor will work fine, use a 1/3 to be sure. also replace the capacitor so it matches the new motor. if you can read the label the part number is on it, should be an HK # with about 7 more digits
Aug 03, 2009 | Carrier Heating & Cooling
Bryant Legacy Line air conditioning not blowing cool air..
Your outdoor condenser is in heat mode. Check the wires on the thermostat. Sounds like a small wiring problem and nothing else. Good luck. Please keep me posted as to you progress.
Apr 27, 2009 | Bryant 462AJC021BA Air Conditioner
Bryant 462AJC021BA Air Conditioner Logo
348 people viewed this question
Top Bryant Heating & Cooling Experts
christian nielsen
Bill Long
Mike Squire
Are you a Bryant Heating and Cooling Expert? Answer questions, earn points and help others
