Question about Palm AT&T C/PHONE PALM CENTRO S64801
I got my Palm Centro wet. I took the screws out
I got my Palm Centro wet. I took the screws out and gently pryed it open a little and then put the blow dryer on it with the setting on low, cool, and then let it dry out for a couple days. It turns on fine and the touchscreen and everything seems to be working fine. The only problem is that I get no service now. Any solutions? Thank you!
    Problem Solver:
  • 9 Answers
Do not put your phone in ANY liquid, even rubbing alcohol! any liquid puts your phone at risk of corrosion in places you cannot see. even if it works fine now, that is no guarantee that there is not still small amounts of moisture inside that may still cause damage later. take your phone apart, put all the pieces of your phone in a ziploc bag of uncooked rice, and LEAVE IT IN THERE for at least 24 hours. having the battery in at all when there may be moisture inside puts your phone at risk for more damage. save yourself trouble later by leaving it alone in the rice for as long as you can. two days would be better.
Posted on Jul 02, 2009
  • 508 Answers
Submerse unit in rubbing alcohol(make sure battery is out)let soak for hour shake out excess alcohol and let dry for a day then try!!Best of Luck to You!!!!
Posted on Jun 26, 2009
Hi my palm centro keeps over syncing over and over again. i would like to know how to fix it please.
Hello elmorenocali,
The hotsync information in the Centro User Guide is very thorough and is mainly in chapters 2, 10 and 12. I hope the user guide helps with the hotsync problem. Here is a download link for the Palm Centro User Guide:
http://www.palm.com/us/support/handbooks/centro/centrorow_ug.pdf
If this solution is helpful please click a thumbs-up rating below.
Have a great day,
martyshaw152
May 08, 2010 | Palm AT&T C/PHONE PALM CENTRO S64801
My cingular palm centro wont stop hot sync
I had the same problem with my phone a few months back. I took the battery and sim card out of my phone for a few days and then put them back in and it worked. I still have problems with my phone but not with the hotsync feature.
Oct 25, 2009 | Palm AT&T C/PHONE PALM CENTRO S64801
Palm Centro. got it wet. screen is blank on start up.
Contact nearest Mobile service center immediately.They will repair it or else they will replace some minor damaged parts if any.
Sep 09, 2009 | Palm Treo 500 Centro
Palm Centro - continous Syncing problem, now phone is dead
This happened to my palm centro and i fixed it myself. :) Maybe it will work for you. What i did was take out the battery and so the phone is completely off.. then take a tooth brush with rubbing alchohol on it and scrubbed the bottom part of it that the hotsync cord goes into.. I thought this may just mess up my phone more but i plugged it back into the power cord, turned it on and it worked just fine!! Seriously, try this out. It brought me so much relief!! And chances are you either got some **** stuck up inside there, or you got the botton part wet. Hope i helped!!
Aug 24, 2009 | Palm Treo 500 Centro
Replace the keypad on a palm centro
first off you need a t6 screwdriver. this is a special screwdriver with a star shaped bit specifically used for the screws in your centro. if you don't have one, you can buy one off ebay cheap or maybe even borrow one if you go into your local cell phone shop. they probably could even help you replace it if they're nice, even if you didn't buy the keypad from them.
start by taking out your stylus, your battery, and the little rubber plug thing on the opposite corner from your stylus. it just kinda pops out if you get under it with something pointy like your nail. set these things aside somewhere safe. there are six screws to take out, one under where the stylus was, one under where the rubber bit was (there are three holes here, the middle one is the screw hole), and four more that are super easy to see with the battery cover off. take out all six screws and put them somewhere safe too. then gently pry the back housing up from the bottom and pull it downward with a little wiggle and it will come right off. there is a smaller separate piece that surrounds the hotsync cable port and charger port and this comes out too. set these aside.
the next piece we will take out is the motherboard. you will need to disconnect the screen and the keyboard. they are actually under the motherboard but connect to the top side. lay your phone facing down on the surface in front of you and there will be two pieces of black tape toward the bottom of the exposed motherboard, one on either side. gently pry them up, folding them back toward the edges of the phone but do not remove them completely. this makes it easier to replace them later. under the tape are connectors for the ribbon cables that connect the screen and the keypad. there is a small grey bar that locks the ribbon cable in place. gently pry them up, flipping them toward the center of the phone. then gently pull the end pieces of the cables out of the connectors. they will kind of just point up toward you, not flop back over the edge of the phone.
lift up the motherboard by the bottom, like where the hotsync cable goes. pull the motherboard down toward the bottom of the phone while gently (or it will break off) lifting up the part of the housing that covers the speaker and the camera. set the motherboard aside.
now there is a kind of sticker that looks like gray mesh covering the back of the screen and the keypad. pull this up gently from the bottom wherever you can get an edge started to pull it up. you can stop pulling when you get to the part where it's just covering the back of the screen because you won't need to get under there. the flat ribbon cable that goes to the screen might stick to the mesh, and that's ok, just push the whole thing up out of the way.
now you can lift up your phone and gently push the keyboard back through from the front. it will kind of pop out. it helps if you hold the phone facing down still and use your thumbs to kind of push the sides of the phone out a little so the keypad can just pop back. at this point you should have the part that is the keyboard with the cable sticking out of it, and if this is the part you need to replace, ignore the next paragraph. if it's the actual arrow and power keys, read on.
the green and red buttons (or power and talk) and the 5-way navigation button are all connected together and you can replace this whole piece by just pushing it out from the front, and setting the new one in it's place. it's easy to get mixed up, so just in case, the green button is on the left front and the red button is on the right front.
now there's just putting the phone back together. pop the keypad back in (check the front to make sure it looks right and it's popped in all the way). re-stick the mesh back down over top of it. make sure you have both cables showing and they didn't get stuck under there. take the motherboard and slide it back under the speaker cover (lift it up and wiggle), and make sure the cables don't get caught under it. it takes a fair bit of wiggling to get it sitting in there flat. reattach the cables by sliding the ends into the little slot. if you look carefully, there are little guide lines on the keypad cable that come just to the edge of the connector when it's all the way in. flip the little gray bars down to lock the connectors in place and restick the tape. put the little plastic piece from the bottom back on (it only fits one way) and then put the back housing on and push on it until it kind of clicks into place. replace all the screws, the stylus, the battery and the cover. you're done!
May 13, 2009 | Palm AT&T C/PHONE PALM CENTRO S64801
Palm Centro AT&T got wet;
http://www.fixya.com/support/r3771170-phone_water_damage
Jan 24, 2009 | Palm Treo 500 Centro
PALm CeNTro
The last thing you need to do is doing a hardreset.
This will erase all the data in your phone but usually fix the problem.
If the problem persist, bring your phone to the nearest store to fix it.
Oct 17, 2008 | Palm Treo 500 Centro
Palm AT&T C/PHONE PALM CENTRO S64801 Logo
307 people viewed this question
Top Palm Cell Phones Experts
fhonwizards
wayne chamberlain
Marvin
Marvin
Are you a Palm Cell Phone Expert? Answer questions, earn points and help others
