Question about Motorola Mobility H700 Wireless Headset
My headset does not ring to let me know i have a call. The only way I can tell I have an incoming call is if my phone rings or i feel it vibrating. I have to have it on my person in order feel it vibrating otherwise I'd never know I had a call. Ive looked at my settings on my phone to see if there is an option to have a ring tone for my headset and I cannot find one. I have a Motorola Razor. If anyone has any solutions or have had this experience, let me know of any ideas
  • juanc Nov 13, 2007
    my blutooth hesd set does not ring but my phone does
Ok,i have the same problem and it was i was using a ringtone i downloaded, try with the ringtones in your phone,..the original ones and see what happens, in my case i got a medium two beep tone in the headset as the phone rang
Posted on Nov 13, 2007
How do you adjust the volume on the Samsung T255 StraightTalk phone?
Sound Settings
You can customize various sound settings.
Incoming call
Note: When downloading MegaTones® or HiFi RingersTM, charges may apply.
Ringtone.
This menu allows you to select a ring melody. Highlight Ringtone and press . Use the Up or Down key to highlight a ring tone or press the Left or Right key to select a file from either the Default Melodies, Voice list, or Sounds folders. Press the Select soft key.
Volume
This menu allows you to adjust the ring volume to one of 7 levels plus Silent mode and Vibration mode.
  • Use the Right or Left key to increase or decrease the volume.
Alert type
This menu allows you to specify how inform you of incoming calls. Use the Right or Left key to select an Alert type.
The following options are available:
- Melody: the phone rings using the ring melody selected in the Ringtone menu.
- Vibration: the phone vibrates but does not ring.
- Melody and vibration: the phone rings and vibrates simultaneously.
- Vibration then melody: the phone vibrates three times and then starts ringing.
- Melody then vibration: the phone rings using the ring melody selected in the Ringtone menu and then vibrates.
Message tone
This menu allows you to set up the ringer for incoming messages. You can set the Tone, Alert type, and Repetition.
  • Use the Up or Down Navigation keys to make your selections.
Keypad tone
This menu allows you to select a Beep or a Xylophone for your Keytone and to select the Volume (0-7) that the
phone sounds when you press a key.
Jan 25, 2011 | Samsung T239 Cell Phone
PHONE DOES NOT RING
This might be due to the settings....
Ringer settings
To change the ring type and ring tone
1.
On the Phone screen, tap Menu > Options > Phone tab.
2. In the Ring type list, choose whether to be notified of incoming calls by a ring, a vibration, or a combination of both.
3. In the Ring tone list, tap the sound you want to use
You can find more information at the manual located at the below location.
http://www.htc.com/support/pdf/htctouchdual/NIKE_HTC_English_Manual_16-KEY.pdf
Refer the pages 33 & 83
I hope it will resolve your problem...
With Regards,
TPV
Feb 03, 2008 | HTC TYTN GSM Phone
I use the handset lifter for the phone I have (Polycom SE-225). When am sitting at my desk neat the phone, I speak anything above a low normal into the bluetooth headset, like when I am laughing or people...
Unfortunately no. The phone ringer has to be a certain volume for the lifter microphone to pick up the ringing vibrations. If you put it to low, you will not be alerted to the incoming calls. When you're at your desk and can see the incoming calls, maybe then you can lower the telephone ringer volume for some relief.
Good luck from Headsets Direct!
Jan 03, 2011 | Plantronics Voyager 500A Deskphone Adapter...
Droid X phone won't ring for incoming calls.
Found on Motorola Support:
1. Make sure that the "Smart Profile: Face Down" feature is enabled.
2. Hold the phone face up in your palm.
3. Call your Droid X from another phone.
4. As the phone is vibrating, DO NOT ANSWER.
5. Still holding the phone, flip the phone face down as it vibrates.
6. Still holding it face down, hit your volume key to silence the phone.
7. Flip the phone back over so it's face up. You should feel a quick vibrating jolt indicating the ringer is back on.
8. End the call. It shouldn't matter which phone you end the call from, as feeling the jolt is the key.
9. Leave phone face up and call yourself again. If the ringer is now working again, turn OFF "Smart Profile: Face Down" until there's a true fix.
10. If it does not work initially, try all of the steps again a few more times and hope you get lucky.
Jul 29, 2010 | Google Android
My phone won't ring aloud. It is recieving the
software fault, read here so you know what will cure it http://forums.se-nse.net/topic/39748-tutorial-flashing-a2-phones-with-a2uploader/
Mar 31, 2010 | Sony Ericsson W890i Cellular Phone
Won't Ring
check the settings in your phone book. this happened to my phone and all of the personal ring tones were set to vibrate. I don't know how this happened. I went into each contact and changed the ring tone to none and I am back in business
Sep 15, 2008 | Motorola Mobility W385 Cellular Phone
How to turn vibrate on?
You can change the settings of the selected active profile.
Select Menu > Settings > Tones > Incoming call alert, Ringing tone,
Ringing volume, Vibrating alert, Push to talk settings, Message alert
tone
, Instant msg. alert tone, Keypad tones, or Warning tones. You can
find the same settings in the Profiles menu.
Jan 16, 2008 | Nokia 6288 Cellular Phone
Motorola Mobility H700 Wireless Headset Logo
77 people viewed this question
Top Motorola Mobility Radio Communications Experts
Lawrence Oravetz
Dennis
Are you a Motorola Mobility Radio Communication Expert? Answer questions, earn points and help others
