Question about GE Profile JT912 Electric Single Oven
BEEPING F7 beeps constantly on my GE Profile XL44
  • GE Master
  • 1,262 Answers
Http://www.geappliances.com/service_and_support/literature/
Go to this web site. You have to enter the entire model number in order to get your manual.
Good luck and hope this gets it done for you
Posted on Jun 27, 2009
F7 error code
Hi
On a GE range oven F7 indicates either a function pad button is stuck or the clock on the oven is malfunctioning
On the 99 Range oven F7 indicates a shorted Clear/Off Key due to membrane switch or a shorted control or connector
On the GE XL44 Self Clean Oven F7 is Stuck keypad or control relay malfunction
check out more detail here
http://www.fixya.com/howto/h155060-dreaded_f7_error
hope this helps
Aug 14, 2009 | GE Profile JTP56 Electric Double Oven
GE double oven is flashing F7 and beeping
F7 means a stuck button on the membrane pad. You may have to replace the membrane switch pad
Aug 06, 2009 | GE Profile JT955 Electric Double Oven
326B1230P001 GE Double oven that displays ?F7? and beeps
I have a GE JT950 double oven that just did the same thing: F7 and beeps like crazy. I found solution on another post: an engineer figured out how to solve the issue without calling GE or buying parts. I just did it tonight and it worked fine. Here is a copy of the post:
Send an e-mail to Charlie at hutchipop@yahoo.com for a fix-it that you can try. He explains a possible solution fully with his 'The Dreaded "F7" Error' solution. I actually found his information on another website when I did a web search for "GE Profile Oven F7 Issue". I sent an e-mail to him and he replied with free fix-it information. I am not a repair person myself, but, his instructions are very clear and simple to follow. I did the fix-it at no cost in approximately 10 minutes and it has solved my problem
Jul 30, 2009 | GE JTP20 Electric Single Oven
F7 Code on my GE Profile Oven
F7 A = Function pad button stuck or
B = Bad clock Unstick button or
Replace Electronic Range Control (ERC)
Jun 17, 2009 | GE Profile JTP18 Electric Single Oven
I have a GE Profile JTP18. F7 is shown on the
Hi. this F-7 code is referring to a Shorted Clear/Off Key due to membrane switch, control or connector. unfortunately, this is an integrated control assembly and, the entire control board must be replaced in this case.
Replacing the control(ERC,EOC) will fix this issue.
Jun 16, 2009 | GE Profile JTP18 Electric Single Oven
Oven emitted black smoke and F7 beeping on display
F7 stuck keypad
Stuck keypad may mean relay is turned on.
Determine if problem is with the Key Panel or Control by:
1. Pushing CLEAR/OFF pad.
2. Disconnecting Ribbon Cable from control and waiting at least 32 seconds to see if Code recurs
If code recurs, problem is in the control. Replace control.
If code does not recur, problem is with the Key Panel.
Mar 30, 2009 | GE Profile JK915 Electric Single Oven
Ge profile double overn
This is a common problem. I made this fix 2 years ago and it works like a charm.
Jul 19, 2008 | GE Profile JTP56 Electric Double Oven
GE Profile Stove
I used what Charlie recommended ...” post-it” as insulation
And works PERFECTLY….
I have a Kenmore oven Clock…( built in the wall)
Thanks Charlie…you are a Genius!!!!
Jul 15, 2008 | GE JKP15 Electric Single Oven
F7 on the display with constant beeping
F7 for GE is either a stuck button on keypad or bad EOC. Try shutting breaker off 20-30mins and see if it resets itself.
Jul 12, 2008 | GE JKP15 Electric Single Oven
GE Profile JT912 Electric Single Oven Logo
170 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Oloyede Monsuru
Are you a GE Oven Expert? Answer questions, earn points and help others
