Question about SanDisk Sansa e250 MP3 Player
I was locked up and my MP3 player was set for the institution computer and now it won't play what I do
How do I get my MP3 player off locked mode
2 Suggested Answers
SOURCE:
ThaMp3Doctor
  • 8596 Answers
SOURCE: my mp3 player won?t start
Download and use the Sansa Recovery Tool from Sandisk's website.
-Tha Mp3 Doctor
Posted on Jan 18, 2009
I have an mp3 player that I purchased while locked up in a Federal prison, I am now at home and want to find out how to remove the security device.
Can you force it to do a "factory reset" ?
This would reset it to a state BEFORE the prison's I.T. team installed any software.
Mar 13, 2014 | Audio Players & Recorders
My mp3 only plays 10 seconds of each song. how do i fix this?
Your player's play mode has been set to "intro" mode. You can fix it if you select the settings from the menu and change the play mode to "normal".
Thanks.
gylacz
Aug 04, 2011 | Jwin MP3 Player
I have a coby 610-8g. It won't play
Please reset the unit (disconnect the player if it is connected to a computer), use a paper clip to gently press the "RESET" button located on the rear of the player.
If the symptoms still persist follow the steps below.
1. Enter the settings mode to set your player's system option.
2. To enter the settings mode, select "Settings" in the main menu.
3. Scroll down and select "Reset" to restore all of the player's setting to factory default state.
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
Jul 27, 2011 | Coby MP-610 MP3 Player
My mp3 player says that it doesn't have any files but I did put songs on it. What's wrong with it?
look at the settings option.See what it says under usb mode.Try msc mode.If it doesn't work try mtp mode.
Will the files play on your computer
When you look at the properties are the files protected-this would stop them playing unless you have bought the files and your player is compatible
Dec 21, 2009 | RCA Pearl TH1102 MP3 Player
SONG ONLY PLAYS FOR 30-40 SECONDS
pure,
Most probably you accidentally switch the play mode to " INTRO" check your display if it does indicate Letter " I" in it. if does any music you play will be in "INTRO" mode. IF you still have the manual for your player check the 'PLAY MODE" setting. From this setting you can choose play mode from "FOLDER" "NORMAL" "INTRO""REPEAT 1" REPEAT ALL" to play in continuously select "NORMAL" mode.
I'm not sure if your player do have the same procedure in changing play mode . But try this , while on play mode . Press menu and a dialogue box will appear scroll and select "NORMAL"
cheers,
mark
Feb 04, 2009 | GPX MW3836 MP3 Player
Downloads
1. Downloads must be on your computer.
2. Turn on Mp3 player, go to settings, make sure USB mode is set to MSC.
3. Connect MP3 player to the computer.
4. If using Windows operating system, click the Start button, go to 'My Computer'
5. There should be a drive labeled 'Removable Disk', drag your music files to this location.
6. Disconnect MP3 player from the computer
7. Play audio files
*Note - Audio files must be MP3 or Unprotected Windows Media Audio files (that is all this unit will play).
Jun 08, 2008 | Coby MP-C7085 MP3 Player
Deleting demo songs
For Windows XPTM users, you are connecting the device in MTP mode to the computer by default. You will need to set the device to MSC mode, so go to the device menu\Settings\Advanced\Protocol = > Press Play/Pause key to select MSC mode which will appear as such on the screen. Reconnect the device to the computer, and you can now see those files and delete them.
DO NOT forget to set the device back to MTP mode when finished, so go to device menu\Setting\Advanced = > Select MTP mode.
Apr 20, 2008 | RCA S1000 MP3 Player
Messed Up.
hi what you need to do is put the mp3 into recovery mode to do this follow these instructions
1 with mp3 player off push hold/lock button to lock position(this is what you press to stop you pressing buttons when its playing it locks the buttons out) switch this to lock
2 press and hold rec button on left hand side keep holding down
3 whilst holding rec switch mp3 player on keep holding rec button untill it comes on it should now say recovery mode.
Dont do this whilst plugged into computer and dont plug into computer after its in recovery mode untill told to
once its in recovery mode got sandisk website and download the latest firmware once you have downloaded it onto your computer then open the file on your computer it will then talk you through the rest of the procedure this will solve your problem.
Let me know how you get on or if you need further assistance ok
Apr 09, 2008 | SanDisk Sansa e250 MP3 Player
Deleting
If your listening to your mp3 player on the computer, then you can't delete any songs. Exit out of the music player and then delete all of your songs.
Dec 03, 2007 | RCA S1000 MP3 Player
Device not connected
The Sansa Media Converter will only detect the device in MSC mode, or Plays For Sure (e250R) mode.
Change the mode in the Settings>MODE or USB MODE on the device and re-connect.
Best of Luck,
Nov 15, 2007 | SanDisk Sansa e250 MP3 Player
SanDisk Sansa e250 MP3 Player Logo
Top SanDisk Audio Players & Recorders Experts
Joe Negus
Joe Negus
Gyula Lacz
 Ben
Ben
Level 1 Expert
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
