Question about HP OfficeJet 7110 All-In-One Thermal Printer
Just replaced two printheads as instructed by printer. When I tried to calibrate the message is that the two printheads I just replaced are still seen as bad.
    Problem Solver:
  • 14 Answers
you can try this it will work.
let me tell you that the issue will be with the printer hardware but you can try this:
Take a cloth and put little bit of water.
Clean copper contact of the printhead slot and on the printhead...now try to put the printhead but make sure that the conacts has dried up.
>>Do a pwr drain(take out the powr cord and press and hold the power button for 20 sec and release it and plug in the cord back.
>>>>To get detail info of the printer.....log on to HP.com >>support and driver >>select the support radio button.>>put the product name and the os and then you will find manuals and user guide will as information with the pictures.
Let me Know.
Best wishes,
Suvrajit
Posted on Oct 04, 2009
  • 19 Answers
SOURCE: replacing printhead in Kodak 5300 All in One Printer
Greetings Ladyediona,
Sorry to hear about your trouble. Sounds to me as though the issue is related to your print head and it needing replacement. The best way to do this is to call Kodak at 800 421 6699. The team there will help you get a new print head for your system.
You can also go to the following web site to get the help you need and a new print head sent to you. Just complete the requested information and at the end of the review a screen is offered which will send a print head. Try visiting:
http://www.kodak.com/go/itg
Once you complete that process you can also ask the system for details on how to install the print head once it is delivered. There are instructions in the box as well. It is quite a simple process.
Good Luck Lady, you should be back printing in no time if you haven't already.
Ron Baird the friendly Kodak guy
Posted on Nov 20, 2008
websnail
  • 419 Answers
SOURCE: HP L7590 cannot locate printhead latch...don't think there is one
Ok...
The printheads are located in the internals of the printer. To get to them you need to gently lift the control panel up and you'll find this hinges up showing the inside of the printer.
You should then see on the printers LED that you can press and hold the OK button for 5 seconds to change the printheads. Do this until you see the printhead carriage moving out of the parking bay over towards the left.
IMPORTANT: Let the printhead carriage get over to the left and sit for at least 10 seconds before you do anything else as sometimes the printer opts to move the thing after a couple of seconds. Annoying but it can cause damage.. So wait a few.
Once the printhead is all the way over to the left, lift the blue plastic latch/cover from the front and this will reveal the two printheads.
You can now change and/or install your printheads before closing the blue plastic latch/cover and closing the printer lid.
Hope that helps.
Posted on Feb 19, 2009
SOURCE: HP D135 - replaced printhead - still doesn't print in that color
try this link : I followed the directions and fixed the problem. the instructions that came with the new printhead weren't really complete.
Here's essentially all I did for my fix - Opened the printer top, turned the printer off. Removed the "bad" printhead, cleaned the metal contacts on the printhead and printer with windex. Closed the printer. Turned it on. waited for it to reset. Opened the printer. Turned the printer off again. Installed the printhead. Closed the lid. Plugged the printer in again. When it was ready I accessed the HP toolbox and alligned the printheads and cleaned the printheads. It worked. Here's a link with photos.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=bpa02107&lc=en&cc=ca&dlc=&product=64986
Posted on May 01, 2009
  • 285 Answers
SOURCE: how do I remove and replace printhead esp3
cartriges Take them out, push the button on the top left of ph and install new one, pushing on the thumb picture. then install cartriges.
Posted on Jul 03, 2009
SOURCE: Officejet Pro L7590 printhead message (printheads only 2m. old)!
Good advice, but HP refused to replace the printhead despite the fact that it is still under warranty (expires 4-7-10). Tech support (very hard to understand) said I would need to buy a new printhead to confirm that the problem was not the printer itself. When I asked about this, they cut me off.
Posted on Sep 25, 2009
Printer showing error code 3802
To resolve the error:
  1. Upgrade your printer firmware to the latest version:
    1. Locate and select the firmware for your printer.
    2. Follow the instructions to install the firmware.
  2. If your printer firmware is already up-to-date:
    1. Press the On/Off button on your printer control panel.
    2. Disconnect the power cable from the back of the printer.
    3. Wait 10 seconds to allow the printer to reset.
    4. Connect the power cable to the printer.
    5. Turn the printer on by pressing the On/Off button.
  3. If the error continues:
    1. Open the printer access door.
    2. Remove and install the printhead.
    3. Close the printer access door.
    4. Follow the on-screen instructions to calibrate the printhead.
      NOTE: If you are not prompted to calibrate the printhead, turn off the printer, wait 10 seconds, then turn on the printer
Feb 03, 2015 | Kodak Esp 3250 All-in-one Inkjet Printer
The printer works OK but it prints two lines clearly but every third is feint almost half the writing is ommitted
Set the print quality to normal or best.
Clean the printhead
Run a calibration.
The Kodak EasyShare AiO performs a calibration every time you install or replace a printhead. However, you can run a calibration if you are seeing changes in the image quality. Calibration aligns the printheads and performs a nozzle health check to enable high-quality prints.
1 Load the main tray or photo tray with photo paper.
IMPORTANT: If you don't have any photo paper, you can use plain paper, but photo paper is highly recommended for calibrations.
2 Press and hold Photo and Cancel together to make a calibration print.
3 Follow the instructions on the calibration print to calibrate the printer.
Feb 11, 2011 | Kodak EASYSHARE 5100 All-In-One Printer
Just installed new printhead and new black and colored ink cartridges. I do not have a calibration calibration sheet any longer. This is for Kodak easyshare 5300 printer.RAU
When you install new printhead in the printer, you will get a message" New printhead detected ,load papers in paper tray and press start. If u do not get this message,that means you have not installed printhead properly. Visit www.kodak.com/go/printheadsupport and click on 3 rd link installing or replacing a printhead to see how to install printhead correctly
Dec 03, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
How do I change the print head on a Xerox 8500?
How to remove a printhead
  1. Press the on-line / off-line key on the printer operator panel to set the printer off-line.
  2. Use the upper softkeys to scroll to the 'Replace printhead' card
  3. Press the softkey below the 'Replace printhead' card to enter the wizard.
    An introduction screen displays the message 'Use this wizard to replace printheads. A roll is needed for calibration.'
  4. Press the key for 'Next'.
    The screen displays the message 'Select roll to use'.
    The system does a calibration at the end of the wizard. You can only calibrate on the defined media types. When calibration is not possible with the media available on the printer, the system asks you to load the correct media. When calibration is possible with one of the rolls, the system automatically uses the correct media roll. When calibration is possible with both rolls, use the lower softkeys to select the roll to use.
  5. Press the key for 'Next'.
    The screen displays the message 'Carriage moving to centre position...' while the carriage moves to the centre.
    The screen displays 'Open top cover.'
  6. Open the top cover. The screen displays the message 'Replace printheads' and the printheads that you must replace. Find the correct printhead number on the printhead carriage.
  7. Press the front of the printhead cover to unlock the cover.
  8. Open the printhead cover.
  9. Pull out the printhead and remove it.
How to place a printhead
  1. Remove the protective tape from the new printhead.
    Do not touch the contact and nozzle areas of the printhead after you remove the protective tape.
  2. Place the new printhead in the printhead holder.
    The printhead only fits in one way.
  3. Close the printhead cover.
  4. After you replaced the defective printhead, press the softkey for 'Next'
  5. The screen displays the message 'Make sure that all head covers are properly positioned.'
    Press the key for 'Done'.
    The screen displays the message 'Close top cover.'
  6. Close the top cover.
    The screen displays the message 'Carriage moving to home position...'
  7. The screen displays 'Calibrating...'.
    The calibration process takes several minutes.
    You can stop the calibration process at any time. Press the key for 'Cancel' to stop the calibration process.
Regards,
Anirban Mazumdar
http://www.ikarmatech.com
Sep 08, 2009 | Xerox Phaser 8550DX Laser Printer
I replaced the printer head but it won't calibrate
Press menu.
Press �� until Calibrate Printer is selected.
Press OK. A new screen appears with Print Calibration Page selected.
Press Start and follow the instructions on the LCD screen to complete the calibration.
If you want to clean them...
Press Menu to display the Main Menu.
Press �� until Clean Printhead is selected.
Press OK to go to the Clean Printhead menu.
Press OK to perform a Basic Clean.
Regards.
Apr 11, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
How do I calibrate the printhead
you should et a message, if you dont push menu and look for printhead alignment or something like that
Jan 23, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
Printing quality
Printing quality on this printers is great, yet there are some trouble with older printheads.
You should follow this in order to fix the problem:
- Remove both ink cartridges
- Remove printhead (press release button on the inner left corner of the printhead, above where the black ink cartridge goes)
- Close the cover and wait until it tells you that the printhead is missing. When it does, open the cover again and place the printhead inside (put it in and press towards the back of the printer, make sure it makes a loud snap).
- place both ink cartridges in
If the printer says "press start to copy", press the menu button and select calibrate printer, and then select "print calibration sheet".
If it just tells you that there is a new printhead detected and calibration is requiered, follow the instructions it will give you.
Once you calibrate the printer,
- Press menu, scroll down to "clean printhead" and select "deep clean"
Once that is completed, go ahead and print.
If it is still not working, you got a defective printhead and you need to replace it.
You will need to go to kodak.com/go/itg for additionl troubleshooting and the replacing of your printhead, or you should just call 1 800 421 6699 and have then replace the printhead for you. This is free of charge.
Dec 18, 2008 | Kodak EASYSHARE 5500 All-In-One InkJet...
Will not print red
K...Trust the solution. Try these steps. Open the printer, remove the ink and remove the printhead (See User's guide). Reseat the printhead and the ink cartridges. The printer will come up with an error message that requires calibration. Do the calibration and scan the sheet that prints right after by pushing the start button. In the menu options, clean the printhead. Do one basic and one deep. Print a demo sheet (another menu option) to see if the quality has gotten better. If it has not call Kodak AiO Tech support. You will need a replacement printhead.
Jul 12, 2008 | Kodak EASYSHARE 5300 All-In-One InkJet...
Pictures
Apr 26, 2008 | Kodak EASYSHARE 5300 All-In-One InkJet...
Printer
HP OfficeJet 7110 All-In-One Thermal Printer Logo
128 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
