Question about Kenmore Washing Machines
Washer model 11023822100 won't go into spin cycle
Kenmore Washer model 11023822100 won't go into spin cycle on any setting, Fills okay.
    President:
  • 2,923 Answers
A no-spin condition on this washer, the top-loading direct drive washer is almost always a sure sign of a bad lid switch.
You may also want to check and clear the bolt underneath the agitator cap.
You may check the link below and check some information:
http://fixitnow.com/2003/08/mailbag-opening-whirlpool-or-kenmore.htm
Hope it helps and have a great day!
Posted on Jun 26, 2009
Kenmore washer mod.11023822100 fills with water drains water will not wash or spin
Your washing machine has a transmission and a electronic clutch your clutch is bad it is not engaging to let the motor turn your transmission. Please go to Sears Parts Store near you and ask them for a clutch for your kenmore washer model# 11023822100. Then tell them to print you out a diagram to show you how to replace it. Thanks
Aug 23, 2010 | Kenmore Washing Machines
Washer won;t drain or start spinning
check the lid switch if its ok
you have a problem with the timer
replace it
Jul 05, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore 80 Series washer wont spin or drain at end of cycle
POST ME THE MODEL NUMBER. AND ALWAYS POST MODEL NUMBERS WHEN NEEDING ASSISTANCE PLEASE:)))
Apr 17, 2009 | Washing Machines
Washer fills with water and just sets there spin cycle works
The timer is failed in this case.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Mar 17, 2009 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Kenmore cycles not working
Agitating as it fills, definitely sounds like a timer problem. The contacts inside the timer have likely shorted and fused together.
Replacing the timer will fix it and it's not too difficult do replace yourself.
Depending on your model, you can try removing the timer and opening it up. Once opened, use a small screwdriver to gently pry the shorted contacts apart. This may work for a while but once the contacts have shorted, it will possibly happen again.
Post your model number and I'll try to assist you if you need more help.
Mar 14, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore front-load washer stops at rinse cycle
When the washer initially fills for the wash, is it only hot water entering the drum? Try switching the water temperature between hot and cold as it fills. If any of them show little or no water getting through, it sounds too easy but check to make sure water supply taps are on, and that the cold/hot fill hoses aren't reversed. Remove the fill hoses and check any of the screen filters for blockage (in the hoses and in the inlet water valve). When the machine stops and waits to fill but all you hear is a hum, it sounds like there is power going to the valve but water is not able to get through it.
Mar 03, 2009 | Kenmore 43142 Front Load Washer
98702 Washer Drain/Spin Dead.
My Kenmore 98702 washer Fills and agitates as expected but stops at the end of cycle failing to drain or spin
Dec 05, 2007 | Kenmore 98702 Stacked Washer/Dryer
Washing Machines Logo
101 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
