Question about Whirlpool GT4185SK Microwave Oven
Arcing at door
There is arcing at the lower corner of the door
  • Whirlpool Master
  • 9,098 Answers
The area will first have to be sanded smooth and cleaned and dried thoroughly.
If the cavity metal of the oven is cracked or split, you can use a small amount of steel-based epoxy such as JB-WELD to patch the crack or hole.
Once that dries thoroughly, you can sand it very smooth.
Then you can apply some high-temperature appliance paint, available from places like Wal-Mart, Lowe's or Builder's Square.
Posted on Jun 28, 2009
Bosch microwave door sags. It's difficult to open, close or start. Can it be adjusted?HMB5050/01 Photo is of right lower corner of door showing the misalignment
Any microwave with a mis-aligned or loose door is probably leaking excessive microwave energy, and should not be operated unless a leak test is conducted using a calibrated meter.
Unless you own such a meter, the oven should be inspected and repaired by a qualified technician.
Jul 26, 2016 | Bosch Microwave Ovens
The unit started arching inside the front panel on the upper left corner.
Arcing Inside the Microwave - Martin Microwave Inc.
microwaveglasstrays.com/shop/articles-arcing.html
Microwave Glass Trays, : Arcing Inside the Microwave - Microwave Glass Trays ...glass tray, microwave plate, glass trays, turntable, microwave oven, carousel, ...microwave energy, and will eventually it will start producing arcs and put out one heck... the damage is non-repairable and the unit should no longer be operated.
Notes on the Troubleshooting and Repair of Microwave Ovens
www.repairfaq.org/REPAIR/F_micfaq3.html
Microwave oven does not respond to START button. First ..... but with the leakage from the spot welded waveguide inside the unit. ... My clue in was a spark between the waveguide and the case, when I was messing with the Controller PCB.) ...
MICROWAVE OVEN ARCING ' MICROWAVE OVENS
Dec 15, 2015 | Microwave Ovens
Unit sparking near door corner
That is likely to be the Wave Guide Cover that need to be replaced. It is held in with either a plastic clip or a single screw and are available through your local repair dealer.
Jan 19, 2011 | Amana Microwave Ovens
While cooking in our Whirlpool GH5184 microwave an arcing appeared near the L/H lower corner of the unit. After shutting it off we observed a black arc mark on the inside of the door and a small hole from...
This is caused by either carbon arcing from carbonated food deposits or metal dish or bowl being used inside the machine causing a track. Even a recycled paper towel can cause it as the towels have metal traces in them.
Dec 13, 2010 | Whirlpool GH5184XPQ Microwave Oven
Broken door opener button
sounds like the door latch hook is broken you will have to seek a repair man for this
Feb 12, 2010 | Whirlpool GT4185SK Microwave Oven
The microwave model is Kenmore 721.62464201. It's arcing.
This is usually caused by grease or food debris.
First these areas
should be cleaned with a mild, non-ammonia cleaner on a soft cloth. You can use a grille brush if it's stubborn.
Any metal chipped or charred metal will have to be sanded smooth and clean.
Then you should apply some high-temperature appliance paint, available from places like Wal-Mart or Lowe's.
You can find handy exploded views and order any needed parts at the Sears Parts Site.
Nov 29, 2009 | Kenmore Microwave Ovens
Everything works on my microwave oven but it doesn't heat the food
Check the door safety interlock switches ...
Remove the cover and find the switches opposite the hinges. Check with a contunity meter.
If you open the door while the oven is cooking these switches arc. Enough arcing and they burn. When they are burned, they cannot tell the oven that the door is closed. When the oven thinks the door is open, it will not turn on the heat.
Oct 09, 2009 | Whirlpool GH4155XP Microwave Oven
Need to replace the handle of a ge jvm1340, the top screw is easy, but the bottom screw seems unaccessible, can you help thanks, JG
There is a piece of trim on the inside of the door.
This trim is rectangular, about 1/2" wide, and goes around the outside of the glass. the trim has rounded corners. Take a knife and gently insert at a rounded corner, prying the trim out. Once you can put a finger behind the trim, you'll find it comes off easily, revealing the lower handle screw.
Jul 26, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
XL1800 Microwave Problem
A LOUD ticking sound could very well be a High Voltage Arc. This is usually caused by a breakdown of insulation on High Voltage Wires, or components. It can also be arcing between the door frame and the cavity. Usually where the bottom of the cavity floor meets the door frame. Indication of this will be small areas on the door where it looks like the paint has been chipped off, but if you look close you will see it is small burned marks. Another area is the Splatter Shield located inside and at the top. It looks like a Plastic Cover. It is not plastic, but a fiber material. Grease, and food will get trapped on and under this Splatter Shield. Over a period of time the grease and food particles will break down from being cooked over and over again. They will then form Carbon. Which will Arc when Microwaves are present. Remove Push-Pins holding Splatter Shield. Clean by washing with dish detergent . If burned (arc) spots are still present after washing, replace Splatter Shield or arcing will continue. Once Carbon has burned through, it will continue to burn.
Jan 21, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Whirlpool GT4185SK Microwave Oven Logo
125 people viewed this question
Top Whirlpool Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Whirlpool Microwave Oven Expert? Answer questions, earn points and help others
