Question about Intermatic & Indoor/Outdoor Rain Tight Timer
My intermatic timer won't trip back on
I have just replaced my old timer with a new 240 volt intermatic 24 hr timer. When I set the timer the clock will run and the off tripper will trip the clock off but the clock will stop running.When I reset the time and set the pump on off with 1/2 hour to the on tripper,the tripper will get to the lever but it won't trip it on,like it oesn't have enough force.
  • manny4acura Jun 26, 2009
    What i meant it's that is 240 out of my panel but it splits to 2 120 volts loads at the timer. I also used the correct off and on trippers. My timer runs my pool pump and its a 207 volt 277 volts timer.
  • Anonymous Mar 21, 2014
    insert the trippers to desired time (ON and OFF) but did not work.
    President:
  • 1,723 Answers
I don't think the timer runs on 240 volts does it? You can switch 240, but the timer uses 120 volts to run. You might check the connections and timer clock rating more closely. Also, the 'off' & 'on' trippers are different, make sure you use the right one.
Posted on Jun 26, 2009
  • Craig Butler
    Craig Butler Jun 27, 2009
    I am having a bit of trouble understanding your issue but I think your problem is this: You're trying to switch 240 or 208 volts to the pool pump right? You need a 'double pole' timer. It can switch both the hot wires to the pump. Or you can switch one of the hot wires to the pump and the other hot just goes straight to the pump. Wire nut straight through the timer. Make sense?
I have the Paragon 4001-00 timer. The timer seems to be working okay as far as time and trippers are tripping however it doesnt seem to be engaging our secutiy door lock for the night. Could the conrt
Does the manual override lever move back and forth as trippers pass? If NO, then trippers are bad
http://waterheatertimer.org/Paragon-timers-and-manuals.html#4000
http://www.amazon.com/dp/B00441YVCO/?tag=waterheaterti-20
120 Volt timer.
When timer is ON, test across terminals 2 and 3 for 120 Volt
If 2 and 3 show 120 volt, then timer is delivering power on schedule. Look for loose connections. Loose wire nuts.
If 2 and 3 do not show 120 Volt, then timer has failed.
Suggest buy T101 as replacement for durability and generic replacement parts.
http://waterheatertimer.org/Buy-T100-series-timers.html
Crossover wiring from Paragon 4001-00 to Intermatic T101
Paragon 1 to Intermatic 1, Paragon 2 to Intermatic 2, paragon 3 to Intermatic A
Nov 05, 2014 | Paragon 4001-00 24-hr Timer Control 120v...
My Intermatic T101 has power going to it and the clock works normally. But when the clock trips the switching lever to ON or I manually turn it to on, it does not put out power. Is there any sort of fuse...
There is no fuse inside the T101.
If timer clock motor is working correctly, then 120Volt circuit is fine up to the timer.
Unknown if this is new installation , or old installation that stopped working.
Wiring might be bad, such that line and load wires are reversed.
Or light bulb might be bad.
Copy following links to help narrow down problem:
http://waterheatertimer.org/How-to-wire-T104-Intermatic-timer.html
http://waterheatertimer.org/How-to-troubleshoot-Intermatic-timers.html
Dec 13, 2011 | Intermatic T101 - 24 Hr. Dial Time Switch...
Hi - My Intermatic T101P3 timer motor stops after it turns off the pool pump. I have one start and one stop time in a 24 hr period. I have to manually start the pump at the timer in the morning,...
Sounds like the clock leads are on the wrong posts, or at least the hot one is. If if was moved to the load side then manually starting the timer will also power up the clock motor. As soon as the clock trips the off timer, the pump and the clock motor are both off. Examine the clock leads to the wiring diagram inside the clock box cover to ensure they are connected correctly. I bet you'll find one of the wires is misplaced.
John
Aug 31, 2011 | Intermatic T101P3 Pool Timer IndoorOutdoor...
Hi, I have few quick questions regarding the Intermatic HB114C 240 Volt, I would appreciate if you can answer my questions 1. Does this unit have Internal Built in Clock to set up the Clock or does...
HB114C timer likely will not work in India.
Contact Intermatic: http://www.intermatic.com/customer%20service.aspx
Plug type is different than found in India.
India power generation is 50 Hz, so timer might not keep time even with plug adapter.
US power grid is 60Hz, so US-sold products are 60Hz.
Some timers are both 50Hz and 60Hz, but spec sheet usually shows that information.
HB114C spec sheet does not show Hz.
http://www.intermatic.com/~/media/files/intermatic/products/fact%20sheets/timers/hb114c.ashx
http://users.telenet.be/worldstandards/electricity.htm
HB114C is analog appliance timer with clock motor that rotates dial once every 24 hours.
The timer does not have a countdown feature.
Trippers are placed on dial.
As dial rotates, trippers move small switch that opens and closes circuit to load.
Current time is set by manually rotating clock dial until current time lines up with arrow located on inner dial.
After power failure, current time must be reset.
There is no way to install a battery back-up inside the timer.
To see images
http://waterheatertimer.org/Intermatic-timers-and-manuals.html#appliance
Aug 15, 2011 | Intermatic HB114C Heavy-Duty Timer
I just replace a T101 with the same timer. The old one stopped turning. The new one has the same problem. It is getting power because I can manually switch on the pool pump. The timer just won't...
The switch for the pool pump does not necessarily run from the same power as the timer motor...
Check for timer motor rated power on the first two terminals that run the timer motor...you may not have proper power there...you may have 120v but not 240 volt...
heatman101
Aug 12, 2011 | Intermatic T101 - 24 Hr. Dial Time Switch...
I think I have My T101 time switch wired wrong I have nothing under terminal A ! side of my whit to terminial 1 and the other side of my white to terminal 2 which feeds my water heater and the blacks tied...
The timer that you have is a 120 volt timer. You are only breaking 1 leg of electricity which means in the off postion you still have 120 volts going to the heater. Also the clock will not function because you do not have a neutral going to the A terminal. You will need to replace time clock with a 240 volt clock T 104
Sep 24, 2010 | Intermatic T101 - 24 Hr. Dial Time Switch...
I set my T104R3 on and off clips to desired times and turned the timer on. At set time the timer went off, but the clock stops and does not continue and turn on at the desired time.
The T104 timer is miswired when it does things like that. The 240 volt clock motor is internally connected at the factory to terminals 1 and 3. That means that one of the incoming (line) 240 volt wires (pick one) _must_ be connected to terminal #1 and the other _must_ be connected to terminal #3.
The outgoing (load) 240 volt wires are connected to terminals 2 and 4.
The Intermatic wiring diagrams leave a lot to be desired. I wrote the following tip to help clarify intermatic T103 and T104 timer wiring, I hope it helps:
http://www.fixya.com/support/r3734548-wire_intermatic_t103_t104_timers
Feb 27, 2010 | RTO Intermatic T104R3 Timer Switch 220V -...
How do you wire a model GMXST-1-240-M Intermatic timer
There are many ways to wire the Intermatic GMXST-1-240-M timer. If it is not wired correctly you can permanently damage the timer.
For "regular" use, if all you want to do is turn a 240 volt load ON and OFF with the 7-day timer, and you are _very_ sure that you have a 240 volt timer (they can be 120 volt or 240 volt), here is how to wire it:
LINE connections:
The first incoming LINE (L1) 240 volt wire (pick one) is connected to terminal #1. A jumper (same wire size) is then installed from terminal #1 to terminal #3 [(COM) or (Common)].
The other incoming LINE (L2) 240 volt wire is connected to terminal #2.
LOAD connections:
The first outgoing (LOAD) 240 volt wire (pick one) is connected to terminal #2 _also_.
The other outgoing (LOAD) 240 volt wire is connected to terminal #4 [(NO) or (Normally Open)].
Again, while this is still just a basic timer there are at least 10 different ways to wire it depending on what kind of equipment is used, how one wants to control the equipment (using the Normally Open or Normally Closed contacts) or (HI or LOW speed for a 2 speed fan), the clock voltages (120v or 240v), and the load voltages (24 volt to 240 volt).
If you are not sure how to wire this timer after reading this post, I highly recommend posting back with very specific information or calling a _qualified_ electrician, as mis-wiring this timer can permanently damage the timer, connected equipment, and/or personnel (that means you).
Here is the wiring diagram:
http://www.intermatic.com/~/media/files/intermatic/products/instructions/grasslin/gmxst-i-240%20-%20english.ashx
Feb 27, 2010 | Intermatic & Indoor/Outdoor Rain Tight...
Intermatic model T1O4R stopped working. time dial does not move
Can you turn the load ON and OFF with the manual switch? If not, the circuit breaker supplying the timer has probably tripped. Turn the breaker OFF, then back ON. Sometimes a breaker will trip, but it looks like it's still ON.
If you are getting 240 volts at the timer from the breaker, and if you can also manually turn the clock dial, then the timer motor is bad.
Dec 26, 2009 | Intermatic & Indoor/Outdoor Rain Tight...
Intermatic & Indoor/Outdoor Rain Tight Timer  Logo
546 people viewed this question
Top Intermatic Hardware & Accessories Experts
Craig Butler
Craig Butler
Gene Haynes
Jay Finke
Jay Finke
Are you an Intermatic Hardware and Accessory Expert? Answer questions, earn points and help others
