SOURCE: Renault Kangoo Van ( Diesel ) Occassionaly the van
sounds like a fuel isue have you changed your fuel filter lately and have you used any gasline antifreez
SOURCE: renault kangoo 1.9 diesel glow plug light comes on
p100d error code is due to fault in EGR Valve.The EGR valve shuts off to when 3000rpm is exceeded.so the EGR Valve needs to be checked and replaced.
Thanks. you can rate this solution and show your appreciation.
SOURCE: renault kangoo 1.9 deisel smoking bad diesel
classic symptoms of petrol in diesel ,but with these engines their is no keyway on the timing belt sprockets and its not unusual for the sprocket to move if a new timing belt has been fitted ,Now their is a special tool for alignment of the crank to tdc ,on the front of the engine level with the crank right hand side about 2 inches from the bell housing is a bolt ,this comes out and a special tool is inserted to locate TDC its like a long pin ,then crank is locked into this position with another special tool that locks the starter ring gear .and the cams are locked with another special tool .also its a common rail and to locate a injection fault then this vehicle uses encrypted software that can only be read by the dealer over an internet connection with renault thats well secure as it calls back the dealer to confirm caller ID then the operator has to put his finger print into the computer to open the connection.Check the fuel first and see if it smells of petrol ??
SOURCE: losing power when I accelerate my renault scenic, elecronic fault
I took my car to a Renault dealer and they solved the same problem by replacing the non-standard 4 prong spark plugs that the previous owner had in the car with the standard 2 prong spark plugs Renault recommends. My water pump also needed to be replaced (different issue, and was identified with a mechanical noise). I also proactively changed the fuel and oil filters along with new oil.
You might also want to look at getting the coils tested, as these tend to fail often causing loss of power, and a mechanical noise.
In most situations, it is better to take your car to the approved Renault dealer to check the fault. My experience with using other mechanics to fix faults on the car was less than desirable, and ends up costing more.
Renault Kangoo (KC) 1.4 i car bodywork specifications: Renault Kangoo is a minivan with 5 seats and has 4 doors. Dimensions information of car: 3995 mm long, 1827 mm high, 1663 mm wide. Other Renault Kangoo (KC) 1.4 i cars specs: 2600 mm wheelbase, rear track has 1418 mm, front track has 1405 mm, ground clearance - 140 mm. Total car weight is 1155 kg and 1665 kg of maximum weight, cargo capacity (volume) if from 650 to 2600. Tires type for Renault Kangoo (KC) 1.4 i is 165/70 R14 T. Car engine specifications: 1390 cm3 displacement, located front, transverse with in-line cylinders, 75.8 mm bore. Renault Kangoo (KC) 1.4 i has 4 cylinders. More car engine information: 9.5 compression ratio, 77 mm stroke, car has 2 valves per cylinder, distributed injection fuel supply type, engine power 75/5500 hp, engine torque equals 114/4250.
Transmission specifications of Renault Kangoo (KC) 1.4 i wheel drive is front, it has 4 gears of automatic transmission,.
Renault Kangoo (KC) 1.4 i has wheel-rail type of steering. And hydraulic system power steering.
Rear brakes are drum brakes. Front brakes specs: ventilated disc brakes.
Performance Renault Kangoo car data: it takes 17.3 sec. for Renault Kangoo (KC) 1.4 i to get 100 km/h speed. 147 km/h is the max speed. Renault Kangoo gasoline tank has 50 liters capacity. The car consumps 9.5 liters in the city, 6.3 liters on the road.
TMTM
