Question about Panasonic PT-50LC14 50" Rear Projection HDTV-Ready Television
No red I replaced the lamp on my Panasonic PT-50LC14 and the colour is now mostly green. I have tried adjusting color, tint, picmode but cannot get back to the original colours. Any suggestions?
  • 10 more comments
  • richardjg153 Jun 26, 2009
    I got the screen message to change the lamp. I was too busy to do so. After about two weeks with the message, the colour changed to mostly green. I changed the lamp but the colour is still mostly green.
    I bought the replacement lamp through Hy-tech electronics in Mississauga and it appears to be original Panasonic. The lable on the box says Panasonic and the Instruction & Warranty appear to be original Panasonic.
    I did get the Lamp time reset instructions. I tried to follow the instructions but I did not get the response screen "Lamp Time was reset to 0". However, when I turn on the TV, I no longer get the message about "Replace the Lamp....."
    Sorry. I am still getting the "Replace the Lamp" message. I'll try the Lamp time reset procedure again and advise.
    I followed the Lamp time rest procedure but got no reaction. While pressing the VOL button on the unit, I held down the SPLIT/Play button fpr more than 5 seconds. No response.
    I turned off the TV and unplugged it from AC. Waited 5 minutes, turned TV on and pressed VOL while holding SPLIT/PLAY. Still no "Reset" message only the "Replace Lamp" message.
    I confirm that the model is PT-50LC14-K.
    My remote does not have PIP button.
  • richardjg153 Jun 27, 2009
    I have now received the proper "Lamp Time was Reset to 0 message". Thanx, I think that it was waiting until the "Change Lamp" message had gone that made it work.
    Unfortunately, the picture is still mostly green.
    I have tried in the menu:
    Picture then picmode, color, tint. No change from mostly green.
    Is there a menu item for "Factory settings"?
    The whole TV picture is very greenish. I cannot get any real red eg Coca Cola or Tube in You Tube.
    However, I did try the DVD player and it was fine. Therefore, I assume that this means that it is a TV problem with Rogers Cable and that I should try their service department on SAT. Correct?
    Thanks
    TV now fine. As per Rogers Cable, I just had to tighten the connection of the cable into the the cable control box and the greenness disappeared. From the tone of the Rogers technician, this sounds like a fairly common problem.
    Thanx
    Solution was very helpful.
    Step-by-step procedure for resetting the lamp hours was successful.
    Checking the DVD picture to show that it was a cable problem also was successful.
    Thank you.
  • 10,594 Answers
Let me know following info...
Color were fine before Lamp replacement?
Make sure replacement lamp is Panasonic original and it is not aftermarket product.
Thanks.
Posted on Jun 26, 2009
  • 7 more comments
  • Shahid Electronics
    Shahid Electronics Jun 26, 2009
    Thanks for update,
    Did you find instructions in lamp box about how to reset lamp timer in TV?
    If yes, did you reset lamp timer?
    Power off TV, unplug from AC or switch off for couple of minutes, replug back in, power it up and now press and hold volume down button and TV and press Split/ Play button on remote for 5 seconds to see lamp reset message.
    OK, is it Panasonic PT-50LC14 TV? Please confirm model number as other model using same lamp requires some other button to press to reset lamp.
    You can try press and hold Volume Down button on TV and press PIP button on remote for 5 seconds or more to reset lamp.
    Thanks for model info.
    Lamp reset procedure is same as you already have info.
    Power up TV, let lamp reset message goes away. (I think it will go away in couple of minutes or so)
    Press and hold -- Vol button on TV front and press Split/ Play button on remote of TV for more then 5 seconds. You will see Lamp reset display on screen.
    Thanks.
    Shahid Electronics Jun 27, 2009
    Thats good, lamp hours are reset now.
    Please check any option of reset to factory default settings in Menu and reset TV accordingly.
    There is no obvious reason of greenish picture in this TV.
    Thanks.
    There is no factory default settings for user in menu.
    Service manual has service menu for various settings in TV and its for TV tech to do that.
    Do you see little greenish picture or its just greenish.
    Check picture result on other inputs/ video source like dvd player etc.
    Hi again,
    I lost contact to assist you more. Now problem has been fixed as it was related to cable box. Good.
    thanks.
    Now please rate solution.
    thanks.
  • 52 Answers
Tighten the connection of the cable into the the cable control box. This should solve your problem
Posted on Jun 27, 2009
  • 615 Answers
Check the circuit Board for dry joints or soldering..At the time of lamp replacement..chance of dry soldering of other componenets.It is not a major problem....search for glued resistors.
Same problem i am faced for blue color earlier. and solved.
Should I replace my lamp for my Panasonic 1080i htd t.v. pt-50LC14
Replacing a lamp won't work. There is not even one lamp in your TV. I'm afraid the lightening has done more damage than can be repaired. Even when some tech manages to repair te error, the TV can have the next error in days or weeks.
Try reading something about ESD. Electro Static Discharge and what it does to electronics. Electrostatic discharge
Apr 25, 2015 | Panasonic Televison & Video
PT50LC14 Color problem with color too much yellow and green no white or blues can not correct is this the lamp again im on why does it seem that I end up replacing the lamp every year (on number 3 now)....
ok,,your problem is not on the lamp itself.,the problem is on your screen controller.the controller is connected on the plyback you can adjust the screen intensity of the red,green,blue cathode..on your screen adjustment.
May 17, 2010 | Panasonic PT-50LC14 50" Rear Projection...
THEN SEEN HAS A LITE GREEN TINT TO THE BOTTOM PART
Sounds like your main control board or the color wheel.
Dec 29, 2009 | Panasonic PT-50LC14 50" Rear Projection...
Panasonic PT50LC14 Rear projection LCD - too much green
Had the same problem today. Thought is was my bulb. Replaced it but still had the color problem. Replaced the cables between cable box and TV and no more problem!
Jan 22, 2009 | Panasonic PT-50LC14 50" Rear Projection...
PT-50LC14
Hey Beestergirl, I just had my tv fixed for 385.00
Apr 21, 2008 | Panasonic PT-50LC14 50" Rear Projection...
GREEN TINT
It is almost certain that the light engine is your problem.
Dec 14, 2007 | Panasonic PT-50LC14 50" Rear Projection...
Panasonic PT-50L14 50 lamp has no obvious defect
My first step would be to check the owners manual under troubleshooting for the lamp code for blinks green then red. I suspect the problem is in either the ballast that drives the bulb, or the bulb (P/N TY-LA1000) itself - you can't usually tell a bad one from a good one by looking at it. The ballast is difficult to replace, and I would call in a repairman to fix it if a new bulb didn't do the trick.
Dec 08, 2006 | Panasonic PT-50LC14 50" Rear Projection...
Panasonic PT-50LC14 50" Rear Projection HDTV-Ready Television Logo
137 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
