Question about Bosch Classixx WVF 2402 Front Load Washer/Dryer
How to use bosch WFT 2400
I am in france and need simple instructions to use the WFT 2400
3 Suggested Answers
SOURCE:
  • 224 Answers
SOURCE: LOOKING FOR USER MANUAL FOR WFT2400 BOSCH FRONT LOADING WASHING MACHINE
Try this website: www.bshappliancecare.com and I think you might find what you are looking for. Good luck.
Posted on Sep 26, 2008
  • 6277 Answers
SOURCE: Bosch wft 2400 has stopped
I would suggest as a first step that you clean the drain motor lint tray/filter. So many 'faults' are caused by blocked filters. The motor is unable to drain all of the water in the allotted time.
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and held in by a round cover/knob.
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT!
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. If it doesn't work then the motor is malfunctioning!
Hope the filter is the problem and good luck!
John C
Posted on Feb 26, 2011
I would like to download a user manual for Bosch Logixx8 sensitive front loader washing machine. Thank you Mrs Jae Watson
Sorry, this forum is not able to supply any type of manual, installation instructions, electrical or schematic diagrams direct; it's just made up of ordinary guys and gals, probably at home and from all over the world, with experience of addressing problems and giving guidance for free on the web ;-0)
You will need to type into your search engine/web browser '(make model number) washer manual' and you should be presented with a number of sources from which you can either download for free or have to pay a nominal amount.
You could also try the manufacturer's web site direct ;-0)
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C.
Jun 12, 2011 | Bosch Logixx WFT 2806 Front Load...
Bosch wft 2400 has stopped draining water after a cycle. What do i do
John C
Feb 26, 2011 | Bosch Classixx WVF 2402 Front Load...
Bosh wasching machine wfr2830 error code 7 Anybody knows wht's the problem? thanks
I am factory authorized Bosch service and parts supplier and love the Bosch products.
Contact us at:
http://www.fixya.com/repair/d499389-accurate_appliance_repair_service and we will get the correct part out to you asap.
Thanks, Ella
Nov 15, 2009 | Bosch Logixx WFT 2806 Front Load...
Cant disable child lock
The child lock on my Bosch Logixx8 washer has come on and i need to disable it
Apr 21, 2009 | Bosch Logixx WFT 2806 Front Load...
Bosch Logixx vented dryer not working correctly
I had the same problem.
I took of the cover on the back and found the heating element had blown. I just replaced it for a fraction of the cost of a new drier, just unscrewed it and conected the two wires easily.
Jan 25, 2009 | Bosch Logixx WFT 2806 Front Load...
Jul 27, 2008 | Bosch Classixx WVF 2402 Front Load...
WET 2820 programs
I have noticed on bosch website that WFT2806 is exactly the same model and there is a manual to download.
go to http://www.bshappliancecare.com/Bosch/ and select instruction manuals then search for WFT and wait, the page will authomatically redirect you to the manuals for WFT2806GB which I think is the free standing version of the washer.
enjoy.
Jan 04, 2008 | Bosch WET 2820 Front Load Washer / Dryer
Instructions for a washing machine bosh wft 6030
Which machine and model do you have ?
Sep 06, 2007 | Washing Machines
WFT 2800INSTRUCTIONS
http://www.bshappliancecare.com/Bosch/ click "instruction manual download" type WFT in the search box, and you are taken to the downloads page - sorry i couldn't link to it directly. Hope this helps :)
Feb 09, 2007 | Bosch Logixx WFT 2806 Front Load...
Washer dryer
Here is the link for a manual for your washer/dryer if you need it; https://portal.bsh-partner.com/portal(bD1kZSZjPTAwOQ==)/PORTALFRAME.HTM sounds like the heating element has failed, or just possibly the thermostat for the hot air. follow this link for a list of spares if you want to try it yourself, or for bosch repair centre details if not. http://www.bshappliancecare.com/Bosch/boschspares.html ask if you want to do it yourself for any guidance you need. Hope this helps :)
Sep 29, 2006 | Bosch Logixx WFT 2806 Front Load...
Bosch Classixx WVF 2402 Front Load Washer/Dryer Logo
222 people viewed this question
Top Bosch Washing Machines Experts
Marvin
Marvin
Craig Butler
Craig Butler
Carmen Mikulic
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
