Question about Dynex 19 in. LCD Flat-Panel HDTV
How do I connect external speakers to my set.
    Problem Solver:
  • 6 Answers
Look for the audio output connections.Sometimes,it is at the left or right side, top or back of the set.Usually, the color of the terminals are Red and Black & most of the time there is letter R & L beside each one.R stands for right chanel & L for left chanel. Buy the speakers with the same RCA
input terminal connections w/ that of your set Then buy the cables w/ RCA male connectors.Any sales person at Frys Electronics Costco Sears Best Buy will give you the right accessories you need.
Posted on Jun 26, 2009
There are no audio output jacks on this model No way to connect external speakers and the internal speakers are terrible
Posted on Nov 13, 2009
Connecting tv external speakers
If you connected R/W RCA cables to the AUDIO OUT RCA jacks on the rear of the TV and connected the other ends to the TV AUDIO IN jacks on the receiver, you should be able to select an input on the receiver that will deliver sound to the Bose speakers. If you went to TV setup and selected external speakers, you directed output from the TV amplifier to external speakers which is not what you want.
Jan 27, 2014 | Televison & Video
External speakers don't work
If the set has a connection for external speakers they have be the same impedance (ohms) and the set will likely have to be switched from internal to external.
Dec 10, 2012 | Televison & Video
CANT FIND A EXTERNAL SPEAKER SET
before attempting that:
Look in set menu to see if speakers are switched ON or OFF.
Check on SET and a Box if used that sound is not turned off or low.
If set has hookup for external speakers is external or internal selected.
Does the set have sound when a DVD etc. is connected via one of the rear sets of audio/video input jacks?
SD TECH
Apr 24, 2012 | ESA PDP4294LV1 42 in. EDTV-Ready Plasma TV
Connecting external speakers
Hi ,
go into your settings on the tv and see if there is a section on speakers and try to set it to external speackers ,,,,,,,,,,,,,good luck Roy
Feb 18, 2012 | Computers & Internet
Can i cannoct external speakers to my Logik L22DVDB11
THANK YOU EVERYONE!! THE SPEAKERS ARE ****! they fell from just a tiny height aswell#!!! ive just added on external speakers to it using a aux cable sound quality is much better too!!!
Jan 19, 2012 | Televison & Video
Can't turn off internal speakers when i have external speakers connected via headphone socket
First, check if you put the connector for external speakers all the way to the end. Sometimes when the connector isn't fully inside both internal and external speakers will work. After you do that, once you connect the external speakers, go to the sound settings in windows and look for the volume mixer. You can regulate the sound for each type of speaker there.
May 04, 2011 | Computers & Internet
How to connect external speakers to this tv. Only output jacks exist for audio.
Most of the TV's do not have a speaker output and so you will need to open the set and take the speaker connect to be meshed along with a impedance matching.
You can connect with a switch wherein the TV speakers can be switched OFF and the external speaker connected . If not the external speaker if connected in parallel must not bring down the impedance to a lower level not supported by the output IC.
The other option is to use the output AV to connect to an amplifier and speaker. ( Your Audio system)
Feb 08, 2011 | Televison & Video
IBM thinkpad type 2647 - after installing external
Go to control panel / sounds / audio, and see if the boxes have greyed out writing, if so then the driver needs reloading, if they are all good check all settings.
Meant to ask if volume control icon is showing in the right lower task bar.
Dec 22, 2009 | IBM ThinkPad T23 2647 Notebook
Zone 2 connections
go into your amp settings menu then to speaker settings,set zone 2 on and main on, turn up the volume for zone 2 about half way then connect phono cables from zone 2 pre out to a input on the external amp (eg cd input )
never use the phono input this is for turntables,connect this amp to your speaker switch/selector then to speakers.
hope this helps
cable guy.
Jun 04, 2008 | Yamaha RX-V2500 Receiver
Magnavox projection tv hookup to external speakers
The external (audio out) connectors are intended for use with an external amp, not direct speaker connection.
Sep 02, 2017 | Televison & Video
Dynex 19 in. LCD Flat-Panel HDTV Logo
696 people viewed this question
Top Dynex Televison & Video Experts
Jaime Hernandez
Are you a Dynex Televison and Video Expert? Answer questions, earn points and help others
