Question about Dryers
Kenmore 80 series (11076822690) doesn't stop running, with heat
Hello, I have a Kenmore electric dryer (80 Series, Model # 11076822690) the dryer runs in all settings with heat but does not ever stop running. For example, if I set it to dry on medium heat for 30 minutes the timer will only move about a 1/4 of an inch but the dryer will still be running after an hour and a half. The vent and vent pipe to outside are clean and clear. Any help would be greatly appreciated! Thank you kindly!
    Problem Solver:
  • 16 Answers
Its the timer
Posted on Jun 27, 2009
Kenmor 80 series gas dryer model # 11076822695 dryer is heating up for about 2 min then it gose cooled for the rest of the cycle
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Sep 20, 2010 | Kenmore 72802 Gas Dryer
DRYER RUNS, BUT WILL NOT HEAT
Do you have fuses or breaker? If you have fuses one fuse may be burnt out.
Jul 12, 2010 | Kenmore 62822 Electric Dryer
I have a kenmore series 80 electric dryer. It will will run for around a minute and then cut off. seems to be over heating. when I turn the heat setting down to the lowest setting it will run longer. If I...
that sounds like the dryer motor going bad,most of the time they run alittle then stop,or when you push the start button it just buzzes-mike
Mar 02, 2010 | Kenmore Dryers
Kenmore 70 Series Dryer not heating and not cutting off
I had an identical problem to yours this weekend with my Kenmore dryer. There were 2 problems.
1. Timer was broken. Does not advance to "OFF" position on timed dry, however it still works for auto-dry.
2. Thermal fuse was blown. Upon replacing, dryer heated up normally.
I believe when the timer broke, the dryer had kept running and blew the thermal fuse. On Sears' website, thermal fuse is $5.30, timer is roughly $80.
Kenmore 70 Series gas dryer, M# 110.76752500
Jan 01, 2010 | Dryers
Kenmore Series 80 (110.74882401) heat cycles on only for 10 secs
This is a pretty easy fix and I recently had the same problem. I made a quick video about it. The problem was the dryer was run only a few mins then quit. The dryer limit was tripping because the control thermostat was not shutting down the lower safety limit was tripping and the power from the control thermostat was diverted via the orange wire to the timer motor which kinda caused the main motor to stop. When i ran the dryer in NO HEAT the dryer stayed running and that was my clue as to what may of been happening and that was the problem in a nutshell. My video:
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jun 21, 2017 | Kenmore 659 Electric Dryer
Kenmore Dryer 90 Series will start but suddenly stop...
Hello , Sounds like your motor is over heating , it will run until the sensor shuts it down from getting to hot , it is most likley because the motor is covered in lint and needs cleaned. Hope that helps.
Dec 30, 2008 | Dryers
My Kenmore 80 series dryer is shutting down
Please post the complete model number of the appliance.
Possible problems are -
1) Motor bearings are failing (lack of lubrication).
2) Idler roller is failing (lack of lubrication)
3) Blower bearings are failing (lack of lubrication)
Dec 29, 2008 | Kenmore 659 Electric Dryer
Kenmore 80 series runs but dont blow hot air
Where is the location of the heating element for a Kenmore 80 series dryer heavy duty model # 77834795
Dec 09, 2008 | Kenmore 63942 Dryer
Dryers Logo
336 people viewed this question
Top Dryers Experts
Marvin
Marvin
