Question about Sony Playstation 3 (PS3) Console
Green Line While watching movies onmy ps3 there is a green line down the right hand side of the screen but it is only htere when watching movies why is that? Thank you
  • ps3player555 Mar 07, 2009
    i have a green line its bout 3/4 inch thick and it is on the left side its there as a black line when i play nba 2k9
  • 709 Answers
It may be a video setting in the PS3 is not matching the TV. Try this. Turn off your PS3. Then, press the 1/0 button for more than 5 seconds. This should reset your video settings.
Posted on Nov 06, 2007
Thin green line down left hand side of screen about 6" in from left. I watched your tutorial. Would this be T-CON ribbons or T-CON board? I guess I can move the cables between left and right to...
T-Con board is not usually the cause of a vertical line on the screen. It is the screen itself. Do not swap the cables. They are right and left only. If you do.... you will burn a trace on the cable and trash the T-con board.
Feb 17, 2016 | Televison & Video
I have a toshiba 22 inch hd tv, when i go on my ps3 at the start screen there is a thin green line (or different colour line depending on the colour of my theme) down the right hand side of the screen. Any...
Would like to tell you that there is nothing wrong with your PS3, but it's the T.V that is causing the problem.
Unfortuntely, the only thing that will cause a thin line or two is the lcd panel assembly. The cost to replace this would be really high so the best you can do is put up with it as long as you can, then replace the set.
Apologies on the bad news but i must be honest with you. I have seen this with all makes of both lcd and plasma tv's
Mar 19, 2010 | Video Game Consoles & Games
Kyocera Mita Ecosys PS 1010 all prints have thick and thin line down left hand side A little while back the printer started printing completely black sheets. Fixed by turning off and then on again. Since...
Try cleaning the charge wire. Move the lime green plastic handle from one side of the image unit to the other in the groove. If this doesn't work you'll need a new image unit.$$$$$. note: Make sure green handle is moved completely to the right when finished or black line will occur.
Feb 09, 2010 | Office Equipment & Supplies
Single green line spanning across the screen horizontally
I was just watching TV and all of a sudden the screen minimized down to a single green line spanning across the screen horizontally. The label in the back says it was made in 1996 so it is an old tv. Can anyone help?
Apr 08, 2009 | Mitsubishi CS-27205 TV
Sony Bravia KDL-46Z4100
if the line is in the same place all the time im afraid to say that is a pixel problem on your display contact sony they may offer you a replacement display or altleast a way of changing the set.
Mar 10, 2009 | Sony BRAVIA XBR KDL-V26XBR1 26 in. LCD...
Convergence issue
try fixing the convergence 2 after your've aligned the convergence 1 - the second (accessed via the set up control) let's you adjust on 9 different axis to align the red and blue tubes to the green. you select which + sign you want to adust by pressing the corresponding number for the + ie 1 for the top left, and 9 for the lower right corner.
good luck (note - you cant change the green only the red and blue, if the whole edge is a mess try moving the image (you need to be in zoom mode, and then access the position adjustment via the pitcure set up screen.
Nov 05, 2008 | Panasonic PT-47WX49 47" Rear Projection...
Philips plasma tv. has green line on left side of screen.
Using your TV's remote control press the right cursor button three times and it will adjust the Screen to the right and the green line will disappear. Use the left button if your green line is on the left.
Thanks to:
Oct 16, 2008 | Philips 50PF7320A 50 in. Plasma HDTV
PS3 60GB
Contact sony @ 1-877-253-SONY(7669) for a replacement unit
Sep 04, 2008 | Sony Playstation 3 (PS3) Console
Infocus lite pro 720
Sounds like the LCD inside is dying and you're losing pixels. Bummer.
Aug 31, 2008 | InFocus LP70+ Multimedia Projector
Green line down left side and geen snow
Horizontal or vertical bars on the screen could be from an ac line interference, adjacent magnetic field, bad input wire connections.....especially HDMI connector cables. A bad HDMI cable causes all kinds of unwanted picture interference. Check the conditon of all connection wires for proper fit and function. Keep in mind the method in which you connect your tv will result how the tv performs. As well this line problem could be a circuit issue too, requiring a technician to look at it.
Jul 23, 2008 | Samsung LE32R73BD 32 in. HD-Ready LCD...
Sony Playstation 3 (PS3) Console Logo
308 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
