Question about Brother MFC 8440 All-In-One Laser Printer
Brother MFC-8440 Check Originals
I can print from my computer, but can't make copies. It has an error message "check originals" but I have taken the originals out. The rollers are very noisy on the top feeder, I've cleaned them with alchohol, and that didn't help. Any other suggestions? The drum unit is fine, it was recently replaced.
  • 630 Answers
Check original normally means that there isn't an original in to copy. If it says that when there is an original it probably means that the paper sensor is jammed in some way.
Posted on Jun 26, 2009
WHEN I TURN ON MY MACHINE BROTHER MFC 8440 I SEE ON THE SCREEN ERROR MACHINE 6A I NEED A SOLUTION
Error factor: Heater warming-up timeout error.
(Heater does not reach 60°C within 11 sec.)
Check: • Thermistor ASSY
• Halogen lamp
Jan 08, 2011 | Brother MFC-8440 All-In-One Laser Printer
Machine error 6F on a brother mfc-8440
first what is the message???? i will try and help you whenn you let me know the problem or the error message
Dec 10, 2008 | Brother MFC-8440 All-In-One Laser Printer
Brother MFC-8440 will not print or copy
YOU HAVE TO RESET.
TURN OFF THEN PRESS THE STOP /CLEAR BUTTOM THEN TURN ON KEEP PRESS ABOUT 10 SECOND THEN IT WORK .
Oct 15, 2008 | Brother MFC-8440 All-In-One Laser Printer
Replacing Toner
How to tell on brother mfc-8440 or mfc-9440cn , the total copies printed so far
Sep 07, 2008 | Brother MFC-9440CN Laser Printer
Brother mfc 8440
This is commonly a problem with the left hinge being broken on the lid where the adf is. Check that and if it is broken i can give you a part number.
Sep 03, 2008 | Brother MFC8440 Remanufactured Laser...
Not printing, says check original
Can be a document feeder jam.
Also can be that you are trying to copy an odd size original that it doesn't have the paper-stock for. in that printer it can be caused by not having the paper trays set correctly or using the menu to force it to try printing on something like legal size paper when it only has 8.5/11
Try resetting the printer with a power off and make sure the paper try is set to 8.5/11
Apr 24, 2008 | Brother MFC-8440 All-In-One Laser Printer
Brother mfc 8440
menu * 2 8 6 4 super quick then 01, is full reset... warning all settings will be lost
Nov 28, 2007 | Brother MFC-8440 All-In-One Laser Printer
Printing and copying almost blank pages
Ussally drum/toner would fix, will not be fuser, I would suspect Hi voltage board or laser unit, In australia these machines carry a 2 year return to base warranty.
Try reseting the drum counter, this also resets Bias voltage, might be your problem. open front cover with power on and press set, arrow to change drom and select yes.
Otherwise it would be a high voltage board problem, possibility alsoexist that it could be laser unit
Check status page for "71" errors, menu * 2 8 6 4 very very fast, machine will beep "maintence displays" then 77 to print out status page, 99 to return to normal.
Nov 26, 2007 | Brother MFC-8440 All-In-One Laser Printer
Brother mfc 8440 "printing" problems
Hi
I recently had this problem - tested fuser and all sensors.
The fix is to reset the memory.
To do this, enter the Maintenance mode. Menu, * 2864
(enter the number quickly)
then type 01 ( zero one ), this will reset all memory including the user settings.
Finally type 99 to exit Maintenance mode.
The printer will restart and the error will be gone. Test out with copy and printer reports
Hoping this fixes your problem
Regards
Lindsay
Nov 15, 2007 | Brother MFC-8440 All-In-One Laser Printer
Brother mfc 8440
Printer thinks its out of paper when its not. Displays messsage "Check Paper - Reload Paper." Have emptied and replaced paper stack several times. No visible jam. Have shut down and restarted. Still not fixed.
Oct 30, 2007 | Brother MFC-8440 All-In-One Laser Printer
Brother MFC 8440 All-In-One Laser Printer Logo
476 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
