Question about Daewoo DTQ-13P3FC 13" TV
Antenna/Cable Connector partially ripped... Hi, everybody. Does anyone know how to fix a ripped antenna/cable connection? Thanks for the help. My TV Model is a Daewoo DTQ-13P3FC 13" TV for more details. Thanks in advance.
  • bigben2020 Jun 27, 2009
    Is it called "Panel-Mount F-61 Jack"?
    If so, I found one, but I have to buy a soldering iron to solder on the part.
  • 34 Answers
The cheapest way i can think of is open the tv and solder the ripped peice back on. That should work. If not you can go to radio shack and buy a new peice for it and install it by soldering the connections back on. Hope I could help.
Wayne
Posted on Jun 26, 2009
How can I connect a normal antenna or a cable to my TV?
sadly without knowing the MAKE /model . we can only guess but in over 50 years I never saw one that did not have an antenna in jack . satellite service usually goes into the same place when the antenna is disconnected .
Dec 27, 2015 | Televison & Video
WE DISCONNECT OUR SATELITE hOW DO WE GET REGULAR TV
You must have these first.
1. Aerial antenna - buy this at your local home depot. Any aerial antenna available will be fine. Please see the sample picture.
2. Antenna wire (RG-6 cable wire) - connect one end of this wire to your aerial antenna and then the other end to your tv.
3. RG-6 connector - other end of the cable wire must have a this connector to attached it securely to your TV.
Some Aerial antenna has a cable wire packaged, this is much better than to assemble #2 and #3.
After the connection had been done, go to the menu on the tv, scroll down to antenna connection and then press auto tunning to saved all the viewable channel in your area.
Let me know if you need further assistance.
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
Jdvillanueva
Jun 21, 2011 | Hisense LHD3204US 32 in. LCD HDTV
My proscan 32LB30QD won't power up. It worked
try this first:
Setup and Connection
The TV won't turn on Check your power cable connection.
• t can't view the Basic channels. Check the connection of the antenna cable
• t want to view cable channels. Register with your local cable company then connect their receiver to your TV.
• t want to view satellite channels. Setup your Satellite parabola antenna then connect your satellite receiver to the TV.
• Digital broadcasting is not functioning Check your antenna cable connection. Check if the digital channel selection is correctly
connected to your antenna cable.
Jun 15, 2010 | Proscan 32LB30QD 32 in. LCD TV
HOW TO HOOK UP A ANTENNAE
Well you can follow the below steps -
1. Inspect the antenna for any signs of damage. Identify and examine the power adapter cord and the coaxial antenna cable for any rips tears or other defects.
2. Plug the adapter into the antenna's power adapter socket. It will be labeled "12V DC/Adapter". If you are using an antenna that does not require power, such as rabbit ears, you may skip this step.
3. Next connect the antenna cable to the television using the TV's "Antenna In/75 Ohm" input jack. Make sure the antenna connector is twisted tightly into place. Place the antenna on a sturdy surface such as the top of an entertainment center. If you have an older analog TV that is a non high definition ready/capable display and are using a digital to analog converter box, generally, the antenna will plug into the input of the converter and the output of the converter will plug into the antenna input of your TV.
4. Plug the antenna's power supply into a 120V AC wall outlet. This will turn the antenna on. If you are using the "rabbit ears" style antenna, make sure that the each section of the antenna is fully extended. This will give you the best reception.
5. Turn on the TV and check for digital reception. You will know that you are receiving digital signals because the picture will be clear and free of any analog "snow" or other artifacts. Digital TV channels have DVD quality picture and sound.
Follow the below link for more help -
http://www.wonderhowto.com/how-to-hook-tv-antenna-094240/
Good Luck!!
Mar 26, 2010 | Akai PDP4273M Television
Need to know how to go cable free. Have TERK digital antenna
Shouldn't do, just connect the antennas into the Belling-Lee TV antenna socket at rear of set, tune channels. If you antenna won't fit, you may need an "F" connector to "Belling-Lee" converter plug. You will need an "Ordinary" Yagi VHF/UHF antenna installed though. Is that what that digital one is?
Feb 14, 2010 | Hitachi 51G500 51" Rear Projection...
My 13" 2001 CRT Daewoo TV cable connection got loose
Yes you can buy the connector at radio shack and I do believe it requires a little bit of soldering but not much , the same thing happened to my tv and we fixed it up no problem.
Wayne
Jun 26, 2009 | Sanyo DS25390 TV
Replacement antenna and flat cable for Nuvi 370
The flat antenna flex cable is attached to the main PCB and receiver board by connectors. The top of each connector has a flap, which you pry up with a very small screw driver. This allows you to slide the cable out. To put it back in, you slide the cable into the connector and push the flap down on the connector to lock it in place. The cable will not go back in unless you lift the flap. Trying to insert it into the connector without lifting the flat probably caused the cable to flex and crack.
You're best bet is to buy an AS-IS unit on eBay that is dead or has a defective LCD screen and use it for parts to fix yours. Stay away from any units that claim to have antenna problem. I know you can buy replacement screens for the Nuvi on eBay but I haven't seen replacement flex cables.
Please let me know if I can be of further assistance to you.
Good Luck!
- Jim
Jul 22, 2008 | Garmin Nuvi 370
Quasar VV-2001 TV/VCR combo - msg: Check Antenna Cable Connection
Check first the antenna using another TV. If there is no other TV available, check using an ohmeter. If you are 100% sure tha the antenna is ok then the antenna connector on your Tv is not making a good connection to the antenna plug.
May 24, 2007 | Quasar VV-2001 20 in. Combo
Need an antenna block for a Sanyo DS25390
Was the block a cube about 1" ? You should be able to salvage one from an old tv. This block is used to isolate the antenna/cable from the "hot" chassis inside your tv. If you should find a used block ,make sure it does this. If you get one that gives you a direct connection to the chassis, your antenna/cable connector would give you a shock and probably burn out something in your tv when the cable is connected. Some of the Sanyo's have this connector made on to the tuner. If this is the case you'd have to either put a new coax connector in the tuner OR replace the tuner. Stargazer
Jan 23, 2007 | Sanyo DS25390 TV
Color fades in and out of picture
The first thing I would check is the antenna or cable connection into the set. When an analog TV signal is weak, the first thing to go is the color, then the picture, then the sound. If you have another TV, connect it to the very same cable or antenna connection and see if it fails the same way, too. Make sure you just disconnect the cable end right where it goes into the failing TV and connect it to the other TV - don't disconnect the antenna cable from the wall for this check. If the second set does not fail, gently pull on the antenna wire - not too hard, you just want to put a little tension on it to see if it makes the color cut out. Reconnect the first one and try again. If it's fine now, the connection was loose. If not, it has a tuner problem that must be repaired. Also, when you look at the end of a TV connector, the center wire should stick out just a little bit, like in the attached photo. If it doesn't stick out as bit, it won't make good contact, and will result in a weak signal. I appreciate your rating if you find this helpful.
Nov 13, 2006 | Philips 27PT643R 27" TV
Daewoo DTQ-13P3FC 13" TV Logo
157 people viewed this question
Top Daewoo Televison & Video Experts
 Grubhead
Grubhead
Are you a Daewoo Televison and Video Expert? Answer questions, earn points and help others
