Question about Sharp R-220HW Microwave Oven
Power failure During the night electric power was cut off (no storm).  In the morning, I tried to set the time and nothing happened.  Since this problem, I tried to find the ceramic fuse(s) for replacing them.  After opening the cover, I have not located where the fuse(s) are.  I have the manual which does cover this problem.
    Problem Solver:
  • 17 Answers
The fuse will not be on the circuit board.Try looking around where the door switches are, or back around the fan area.If you still can't find it, trace from the powercord coming in and follow were both wires go.
Posted on Nov 07, 2007
My Oster microwave. Last night we had a pretty big storm, this mourning I tried to use my microwave, No power. I switch plug in outlet ...Nothing happens. How do I get the power back on ?
Depends on what blew, if ti is a power surge is will blow out the low voltage transformer on the main board before it will blow the fuse in the unit, so Probably will need new main board. Problem will be finding someone who carries parts for Oster Microwvaes.
Oct 05, 2017 | Oster Microwave Ovens
I have a GE profile spacemaker xl 1800 microwave. I used it once this morning but then upon a second use some time after, there was nothing on the display, as if power was lost on it. I opened the door and...
The door switch may have become defective, cutting off power completely. When the oven restarts, it prompts you to set the clock just as it would if there had been a power interruption. It is possible that something has failed in the control logic and that probably will require attention from a repair technician.
Oct 31, 2013 | Microwave Ovens
I have a Panasonci NN-SD686S and after a power cut last night, the microwave is now in demo mode. After power cuts previously this has never happened, and I can't find anything in my manual to...
To set Demonstration Mode: press micro power once, then press Stop/Cancel 4 times. To cancel Demonstration Mode press Micro power once, then press Stop/Cancel 4 times.
Sep 09, 2011 | Panasonic NN-C994S Convection/Microwave...
Microwave not heating
it can be saved but get a quote from the shop first before proceeding and always evaluate it against the cost of a new one,
it could be the power supply has shorted but check it out.
Jul 29, 2010 | Daewoo KOG-867T Microwave Oven
I have the Kenmoore Microwave Hood 721.80402. During this last wave of storms, I was without power for 2 days. Once the power was restored, the microwave will not work. Everything is plugged in and the...
You might try pulling the plug on the unit and leaving it overnight. The electronics may have locked up due to irregular voltage during the failure. There may also be a GFI (ground fault interrupter) on that circuit that has tripped for the same reason. Check the kitchen outlets for a tripped GFI.
Feb 14, 2010 | Kenmore 62622 Microwave Oven
11-30-2010 I need the user manual of Amana Mictowave model RS560W . Kindly assist. Thanks. Rgds Alon Felz The real problem: After heating the food (in a certain time selected), a beep sound should be heard...
In order to solve the problem this is what I did (with a help of Mr. Hilik
1. Unplug the power cable 220Vac from the wall outlet.
2. Make sure or the clock led is "off" and screen is dark
3. Plug again the power cable 220Vac
4. Nothing comes "on" on the led screen
5. press on the digit "zero" (0) and you hear a beep signal
6. Take a glass filled with water press on the digits "1" and then "0" and
then "start"
7. After 10 seconds the beep signal will come on again.
8. Note: this kind a phenomena appears after voltage cut off when there
is a need to lift up again the handle on the voltage breakers . FYI.
Jan 30, 2010 | Microwave Ovens
Microwave beeping and F2 error code
The F2 code is a keyboard failure. Since it's intermittent I would check for a loose wire/connection. open the control panel and reset the ribbon cable on the circuit board....
thank you,
vijay (vote for me)
Sep 23, 2009 | KitchenAid KHMS155LSS 1000 Watts Microwave...
GE Advantium Oven - LED lights went out.
if anything like my own it is the led blub thats blowen - major hasel to change out - get some one who knows these cookers/ovens...
Aug 07, 2009 | GE Monogram ZE2160SF Convection /...
Power cuts out after about 5 seconds
Hi try unplugging form mains for an hour this will reset any settings back to factory settings let me know what happens after doing this then i can assist you further ok
Mar 19, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Whirlpool Microwave Model MH3184XP will not power up after power failure
The first thing to try is a "hard reset". Unplug it from the power line for a few minutes, plug it back in, set the clock, then try again. Let us know if the hard reset doesn't fix it.
If not, then you may have a problem is on the control panel, which we repair nationwide for $39.95 postpaid.
We have full details, plus *critical* safety, disassembly, and troubleshooting info at our site. You'll find a link to our site in our
listing here on FixYa:
We're happy to help and we appreciate your thoughtful rating of our answer.
Feb 11, 2008 | Microwave Ovens
Sharp R-220HW Microwave Oven Logo
61 people viewed this question
Top Sharp Microwave Ovens Experts
William Miller
William Miller
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
