Question about GE Refrigerators
My GE GSS22WGPJ side by side freezer not cold enough
My GE GSS22WGPJ side by side freezer has recently stopped cooling sufficiently. It reaches only about 25 degrees F on the coldest setting. It has been doing this for about a week. The fridge is only pulling 1 AMP of power from the wall. The compressor is running almost continuously and hot, but the coils are only slightly warm. Only the bottom 4 freezer frosting coils are frosted (the upper 10 or so are not). I have been having an intermittent whirring noise for the past few months and heard that it was related to a energy saving problem that many of the GE fridge's have (the fridge is not currently whirring). The fridge is 3.5 years old. Any ideas? I figured it is either a refrigerant leak or something to do with the energy saving issue. Any ideas would be appreciated.
Oceti
  • 51 Answers
SOURCE: Frigidaire model # FRS26ZNHB2 side by side not cooling
T
From your description, you have a bad evaporator fan motor. The part number for a replacement motor is #5304445861.This is not a direct replacement but is more reliable.Remove everything in the freezer, take off the back panels and you will see the fan.
If there is a large frost buildup on the coils and the fan is turning you have a defrost problem. If that is the case, please call me at 334-347-0000 and I will walk you through it.
Posted on Jan 14, 2008
  • 13 Answers
SOURCE: GE Profile Refrigerator (Model #20) w/freezer on the bottom
If the problem disappears (for a while) when the freezer reaches 32F, then I know what the problem is.
The GE Profile refrigerators (and likely other models as well) often don't defrost properly, especially in humid climates. So they can develop ice buildup internally, especially if the air vents at the back of the freezer are blocked by frozen food. Once that happens, that ice can interfere with the cold air circulation booster fan that runs when the freezer temperature is too warm. Then you get a LOUD buzzing noise from the fan blades, as they bang into the ice.
The immediate "solution" is to be sure nothing blocks the air vents, and then to melt the ice that interferes with the fan. You can turn the fridge off for a while (with the food removed so it doesn't spoil), and/or get a hair dryer and heat the inside back of the freezer, until the ice melts and falls away from the fan. (Just be careful not to block the nozzle of the hair dryer, or it may burn out from overheating!)
But the ultimate solution is to buy another refrigerator, one that is NOT a GE! And that makes me sad, because GE used to make GREAT refrigerators. My last GE refrigerator is nearly 20 years old, and still works well, and it does so QUIETLY.
Posted on Jan 04, 2009
  • 14 Answers
SOURCE: Refrigerator and freezer running warm
Check and make sure fan in frezer section works properly.you should be able to hear fan slowing down when you open freezer, or find door switch and press and hold..hope it helps you..
Posted on Jul 07, 2009
  • 3600 Answers
SOURCE: Frost forms on seal and edges of
Try Cleaning the seals and the seal surface if the seal is old and cracked it could cause the icing problem. if there is dirt on it it will not allow the door to seal properly and cause this condition, the warm air enters the unit and sucks the moisture out of the air, and since you did not mention a make or model their is nothing I can do to help. You can buy a replacement seal get back with the make and model and I will give you a web site to look for a price for the seal.
Posted on Aug 06, 2009
  • 239 Answers
SOURCE: Frig too warm, freezer works great, but frost on back wall
It sounds like the fridge is not going through the defrost cylce due to a faulty defrost thermostat.
Posted on Aug 29, 2009
Testimonial: "We had a professional fix our refrigerator and he replaced the defrost thermostat and timer. Now the fridge works great. Thank you. "
My GE refrigerator temperature is not cold enough and it's triping water. it's just happen today so what i have to do for that.
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
May 24, 2011 | GE (PSS26MSRSS) Side by Side Refrigerator
Hi my GE side by side fridge is not getting cold enough
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Nov 28, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
My G.E Adora refrigerator freezer is not cold enough. Ice cream is melting and refrigerator is at too cold and is freezing food, It is only 5 years old. It is a side by side. Help!
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
heatman101
Sep 18, 2010 | GE Adora (DSF25KGTBG) Side by Side...
Refrigerator does not get cold - GE side by side
In my GE side-by-side refrigerator (model number GSS20IEMDWW), there is a motor-controlled flapper door between the freezer and fresh food side. Cold air from the freezer side cools the fresh food side when that flapper door is open.
It is located at the top of the fresh food side on the dividing wall between the fresh food side and the freezer. If this is blocked with something (large left-over container, soft drink bottles, etc), it _may_ be enough to prevent sufficient cooling of the fresh food side.
Of course, there may be a more serious problem with the flapper door mechanism or the control unit that signals the flapper door to open/close.
The vegetable and deli drawers may have a small opening (manually controlled with a wheel or a slider of some sort) that connects those drawers to the freezer side, thus explaining how those areas are still functioning as expected.
Jul 27, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
GE Side by Side freezer cold but not freezing, fridge is warm
you might have a defrost problem, timer,heater or bimetal when the coils freez up they dont cool enough .
Jul 09, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Ge side by side tpx24biyaww freezer not cold enough.
hi there,
have check the current rating,this can determine if your freezer is under charge,use a clamp ammeter hook it up on common line of compressor,set ampere on tester to 50 amper so you can read clearly,compare this on rated current on manuals or theres a description tag on backside of your freezer look for rated amperes .this should be done by aircon / ref technician if you can't do this,have check also the leak , have a nice day don't forget to rate me,thank's
May 01, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
GE Side By Side top portion of fridge and freezer not cooling
heatman101
Jan 28, 2009 | GE Hotpoint Top-Freezer Refrigerator
Refrigerators Logo
131 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
