Question about Car Audio & Video
Cd player in my 1996 pontiac sunfire dont work but the radio does
I own a 1996 pontiac sunfire and every time i put in a cd it will try to read it and then the display will say: ''E20'' and then the cd will eject.... can you help me?
My husband's 96 sunfire did the same thing as well. We tried everything to fix it, right down to opening it up and checking it. They just burn out over time. Unfortunately there's not much you can do, and to have it replaced by the dealer will cost more than your car is probably worth, being almost 14 years old. Do yourself a favor, go to your local walmart, you can pick up a decent CD player (with an mp3 player input, so no FM transmitter!) for about 50 bucks, and they are easy to install. It's the only thing that worked for us. Sorry I couldn't be of more assistance!
Posted on Jun 28, 2009
How do I fix the clock display on my 1999 Pontiac Sunfire?
It appears to be that the radio clock display has malfunctioned, and is due for a replacement radio, which could be an aftermarket or oem radio, maybe found at a junk yard.
Tools required for oem replacement radio, torx keys set.
Before working on the radio or other electronics, disconnect the battery cables with 8mm wrench.
Replacing the oem radio is much easier, if you obtain oem radio, compared to aftermarket radio, due to being direct fit.
The radio is same for 1995 to 1999 Pontiac Sunfire and the Chevy Cavalier, regardless of sub models, such as SE,GT, VL,VLX,Z24. etc.
Parts needed for the the aftermarket radio install :Stereo assembly, stereo wiring harness adapter, radio antenna adapter, and dash install kit.wiring diagram for the wire colors / functions, along with tools, such as torx key set, screwdrivers,wire crimper, wire stripper, double ended wiring connectors, hair dryer.
The oem stereo removal video is for the 2000 to 2005 Sunfire / Cavalier, but are the same or very similar procedures.
Link to oem stereo removal procedures.
Pontiac Sunfire Radio Repair and Removal 2000 2005
Link to aftermarket stereo install / connect procedures. ( Sunfire Video )
HOW TO INSTALL AFTERMARKET STEREO PONTIAC SUNFIRE
Link to aftermarket stereo install / connect procedures. ( General Video )
How To Install Car Stereo Single Double DIN Car Audio 101
Have a nice day.
May 12, 2015 | 1999 Pontiac Sunfire
My cd player wont work but my radio does in my pontiac 2006 sunfire. Is it the fuse?
Absolutely not. The cd mech is damaged. If it makes a clicking sound when you press eject, it has a cracked gear retainer. If it just plain doesn't read discs or says ERR, it has a bad laser, which means it's time for a new radio. If you need to replace the radio, consider an aftermarket option such as Kenwood, Pioneer, Alpine, etc... It will often cost far less than a factory unit from the dealership and outperform it significantly (as well as offer better features like MP3 inputs).
Jul 03, 2011 | Car Audio & Video
Cd player sunfire error 20 wat is probleme
focusing lens problem. tried cleaning kit wouldn't work had to take apart an clean wit alcohol
Nov 09, 2009 | 1996 Pontiac Sunfire
Cd player will not play the cd but the radio does
that happens frequently, cd player can quit working but the radio will still work. time to switch it out
Oct 14, 2009 | 2001 Pontiac Sunfire
What does E20 code means on a delco cd player?
Hi E20 mean's
The CD player cannot focus on the disc or there is an internal focus problem.
try a known good CD and if it still displays E20 then you will have take it to a radio repair shop
May 10, 2009 | 1997 Pontiac Sunfire
Radio on loc
You need the radio code. Try the internet and if that doesn't work you will have to pay the dealer for it.
Mar 13, 2009 | 1996 Pontiac Sunfire
Error on cd
Could be a number of things. Some of the older GM CD players don't work too well in very cold weather. Also, some of the older CD players won't play burned CD's. If it's not cold weather related, and you're using a regular production store-bought CD, then it is most likely an internal radio problem. Cheapest solution is to buy a cheap aftermarket player.
Mar 11, 2009 | 1999 Pontiac Sunfire
Pontiac sunfire 2000
You might want to test your alternator and check your power connections to make sure they are tight and don't have corrosion.
Thanks,
Lee
Jun 17, 2008 | 2000 Pontiac Sunfire
Car Audio & Video Logo
199 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
