Question about Nikon Coolpix 5900 Digital Camera
Digital camera battery draining
My nikon coolpix 5900 digital camera has suddenly started to drain the Lithium Ion battery very fast. I'v had the camera for about 2 yrs and have not had this problem before. I bought 2 new batteries to make sure it was not a problem with the old battery. Same problem with the new batteries. The batteries are dead within 1 day of no use of the camera.
Is this a problem that can be fixed?
Phil
    Sergeant:
  • 89 Answers
jackboy
  • 2985 Answers
SOURCE: Auto-focus isn't working
Focus motor stalled- check the web site for a repair quote - you may not like the answer.
Posted on Sep 23, 2007
Black Pearl
  • 3 Answers
SOURCE: Nikon Coolpix L3 thinks batteries are dead
I think this was a firmware fault on some cameras. Check with Nikon to see if there is a new firmware for your particular camera. This can be downloaded free of charge and uploaded to the camera via USB.
Posted on Jan 24, 2008
SOURCE: Batteries die
Hello; Same as tbeartusk on my coolpix L3 Nikon
Batts exhausted within 30 Min. and screen says Batteries "exhausted"
Posted on Jun 10, 2008
  • 3 Answers
SOURCE: Nikon Coolpix 775 autos off within 10 seconds
This is either due to one of two problems.
I will start with the simple 1 first.
Go to the menu settings, and select the "S" page, at the bottom is selection for AutoOff, check the settings for this. I would suggest 1 min being about average for most users.
Come out of the menu settings, and leave the camera for 1 min it should auto power down in about that time give or take a few seconds.
If this works then that is the problem solved.
The more complex issue is, that if you camera still is affected by short auto shut downs, then you need to buy a new battery. I paid about £5 for one of ebay, so they are available.
Hope this helps
Matt4666
Posted on Feb 07, 2009
  • 3 Answers
SOURCE: Won't turn on.
I have run across situations where the camera has gotten some dirt or grit in the lens area and causes your described problem. The lens shutter tries to open or the lens tries to come out but is blocked by this dirt. This could be like a grain of sand or such. Have it professionally cleaned and while in the shop have the flash capacitor circuit and the battery charge circuit checked. This all will skirt the cost of a new camera so ask for an estimate before proceeding.
Posted on May 18, 2010
Testimonial: "Thanx."
What kind of battery do i need for a Nikon Coolpix s570 ??
The camera originally comes with a Nikon EN-EL10 Lithium-ion Battery.
You can find out more details about its features here if you have further questions:
http://www.dpreview.com/reviews/specs/Nikon/nikon_cps570.asp
Hope this helped. Please leave feedback.
Mar 18, 2011 | Nikon COOLPIX S570 Digital Camera
Tip
Nikon Coolpix keep resetting Time and Date and menu settings.
Hi.
I am listing this tip for the Nikon Coolpix 995, but the tip is valid for all Nikon Coolpix models.
The Nikon cool pix settings are saved into an internal memory.
The internal memory is maintained by an internal rechargeable battery, that is recharged from the main Li-Ion battery.
If you leave your Nikon overnight with no main battery, or if the Li-Ion batteries have drained, then the internal battery will also drain , resetting the clock and other settings, saved on the internal memory. The camera may even drain in about 6 hours depending on the camera, normally it takes at least 12 hrs to drain the clock battery.
If the internal battery is resetting immediately, after you set the clock, or just after few minutes, then the clock battery must be replaced.
The camera must be disassembled completely to replace the battery located on one of the two main internal boards.
Nikon says that the clock battery loosing charge is normal. I quote what they say on the publication titled " The Nikon Guide to digital photography with Coolpix"
"Backup battery of the clock
The clock-calendar is powered by a separate rechargeable battery, which is charged as necessary when the main battery is installed. If the camera has been stored with the main battery removed for a long period of time, the clock may need to be reset. Once the main battery has been reinserted, the clock battery will recharge in several hours, during which time the main battery should be left in the camera."
Original file: Download here
If the clock does not work at all, and is resetting immediately, even though the Li-Ion batteries are fully charged, then the best thing to do is calling Nikon, at the number listed on the owners manual, telling them that you did not do any improper use of the camera, and trying to get the fault repaired as factory defect. That is not always possible, and the decision depends on Nikon customer service.
See also: Nikon | Contacts
Ginko.
on Feb 05, 2010 | Nikon Coolpix 995 Digital Camera
Tip
Stick with the lithium batteries, and other will drain too fast.
Many digital cameras (eg Samsung D53, Nikon 2100) have extremely poor battery life with alkaline batteries (under 20 shots!). Sometimes they won't even take a single picture.
Try using rechargeable batteries or "oxyride" disposable batteries. They perform infinately better.
on Apr 19, 2008 | Samsung Digimax D53 Digital Camera
My camera is showing battery exhausted when i turn on the nikon camera i purchased a new battery and am still getting the same problem
You can try using Lithium batteries (Energizer Ultimate Lithium) instead of an alkaline battery. If you are using brand new, high-power batteries and are still getting this message, there may be a short or some defect within the camera itself that is causing the batteries to drain unnecessarily fast.
Mar 12, 2011 | Nikon Coolpix 3200 Digital Camera
Tip
I am a semi-pro, long-time photographer and I just learned from a long-time pro...
on Feb 01, 2008 | Samsung Digimax D53 Digital Camera
Battery life on coolpix L100 is very short. Any way to fix this
The life span of a Lithium-ion battery is about three years almost regardless of the number of recharges.
I'm afraid that only way to fix your problem is to get new battery.
May 22, 2010 | Nikon COOLPIX L100 Digital Camera
Nikon Coolpix 5900/4 GB Kingston SD Card
The 5900 uses SD cards. The 4GB card you have is actually an SDHC card and will not work in the 5900. You'll have to stay with cards 2GB and smaller.
May 19, 2010 | Nikon Coolpix S210 Digital Camera
My camera will not hold a battery chard, it last
How old is your camera already? Electronic gadgets powered by lithium ion batteries dies over time. if you had your camera and battery for over quite some time now say like a year or so, maybe the cells were drained dead and uncapable of holding electrical charge anymore. If that is the case you might consider replacing your camera battery with a fresh one.
Apr 28, 2010 | Nikon COOLPIX L100 Digital Camera
Nikon D40x indicate battary low
Rechargeable Lithium-ion 7.4V 1000mAh Nikon D40x battery for sale,20% off! Full one year warranty! For more info visit: http://www.nikon-coolpix-replacement-battery.com/d40x.htm
May 13, 2009 | Nikon D40x Digital Camera
Nikon Coolpix 5900 Digital Camera Logo
78 people viewed this question
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
