Question about Nokia N95 Cellular Phone
Nokia N95 is not starting up
My Nokia N95 is not starting up...
The startup screen just comes up with "Nokia" on the screen when I switch the phone on....Please help
  • 21 Answers
Your phone has Start up failure problem. You have to flash your phone and then install new firmware of your phone. There is just software problem with your phone.
Posted on Dec 27, 2009
When i plug the charger in my Nokia N95, the white (screen is dim) startup screen with the word "Nokia" will appear, then after about 5 seconds the screen will go black and will not charge. This has...
you bought a fake battery or the battery terminal are bad and are having poor contact with the battery.remove the battery and try to clean the three golden panels that come in contact with the battery
Sep 23, 2010 | Nokia N95 Cellular Phone
My n95 nokia all ok but White Screen , Please
You don't need a Nokia N95 diagram.
The white screen means that the ribbon cable that attaches your main phone circuit board and the screen has become damaged or come loose.
A good phone repair shop should be able to repair this for you.
Or if you are brave and don't mind taking a risk of damaging your handset further you can replace it yourself.
I hold no responsibilty for any damage you do to yourself or your handset though.
You can get a ribbon cable and tools to attempt a repair for around £10
Jul 16, 2010 | Nokia N95 Cellular Phone
My nokia n95 dispiay is not working
  1. solved the problem by removing both the data and SIM-card, placing back the battery and booting it. It did start up normally, and pretty fast by the way, after which I returned the SIM-card. Switch off and on and problem is solved. I didn't place back the datacard yet though
  2. I had the same problem as the first two with the startup going straight to the white screen with the nokia logo and then it would turn off and restart in a cycle, taking out the battery would not help. This was after having the phone for only 9 days... took it to the Nokia Care Centre, got them to reflash the phone's firmware and it was fixed. I suggest doing the same, it's a firmare corruption that is causing the startup hang. Hope this helps you... ! :)
Apr 29, 2010 | Nokia N95 Cellular Phone
NOKIA N95 8GB RM17 symatric down load free
due to discunect of strip of Nokia N95 8gb Rm17 pleas provide us strip Shujaat ali C/o Siqlain auto color shop Airport Road GILGIT Pakistan E. Mail sali_884@yahoo.com
Jan 09, 2010 | Nokia N95 Cellular Phone
My N95 kept rebooting itself so i looked around on the net and found that i need to install new firmware. I downloaded nokia software updater and it starting downloading the upgrade. However about 14mins...
You should try to install NOKIA SOFTWARE UPDATE to ur phone to install the new firmware .It is just software problem not any big to worry.You can go to any nokia center to reinstall the firmware and got ur phone A1.
Dec 05, 2009 | Nokia N95 Cellular Phone
I have smashed the screen on my nokia n95,how do i get my numbers onto my pc please help
  1. I solved the problem by removing both the data and SIM-card, placing back the battery and booting it. It did start up normally, and pretty fast by the way, after which I returned the SIM-card. Switch off and on and problem is solved. I didn't place back the datacard yet though
Sep 30, 2009 | Nokia N95 Cellular Phone
MY NOKIA N95 IN CHINISE LANGUAGE AND SWITCHES OFF.
hi there
if you know someone with the same phone in english then you'll be able to change the settings to english on your own phone by following where to go on your friends phone
Jan 09, 2009 | Nokia N95 Cellular Phone
Nokia n95
If the phone does not boot up to startup screen . then definately its a Software problem. You can yourself repair it with the cable and PCsuite provided. You will need to Download the Software upgrade from Nokia.com.
Oct 11, 2008 | Nokia N95 Cellular Phone
N95 startup problem
do not consult a technicition i have had this problem and solved it for my friend, you were trying to update your n95 firmware using nokia software updater then it said please unplug and remove battery you should never touch a mobile during an update... anyway to fix it your n95 thinks its still in a middle of the update so charge your phone for 10 minutes (DONT TURN ON) then connect up to the computer via usb to your n95 then open up software updater and press start update it it says could not find deivce keep retrying it took me 20 minutes but could last up to 1 hour then it willl recognise the phone and continue update and turn itself back on only problem is that your phone will be reset but you still keep your memory card data
post back asap dale goodwin
Jul 22, 2008 | Nokia N95 Cellular Phone
Nokia N95 Wont start up properly
hi to all u wot r having the same problem i email nokia last night they got bk to me with this messege and it workis so do this
• Turn the phone off.
• Remove the battery, SIM card and memory card for at least 15 minutes.
• Reassemble and turn the phone on.
Then, monitor the functionality of your phone.
If your phone is not responding, try to recover the device by formatting it manually:
• Press and hold these keys: [3], call and [*].
• Press the power button for 1 second.
• Continue to hold [3], call and [*] until you hear the start-up tone.
and it works i can use my n95 agen now so give it a tri
Jan 29, 2008 | Nokia N95 Cellular Phone
Nokia N95 Cellular Phone Logo
333 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
