? 2:27
https://www.youtube.com/watch?v=WBWVSpgZkKQ
Dec 27, 2014 - Uploaded by rayray haque
I made this video because I recently had to fix the drive chain on my skid steer. But there were no easily ...
YES, and you set the chain tension with - Countershaft sprocket centerline, the swingarm bolt centerline, and the rear axle nut centerline - ALL THREE IN A STRAIGHT LINE....Use a yardstick to make sure they are IN LINE!!! Have one of your fat buddies sit on it while you adjust the chain. Make sure the chain runs IN A STRAIGHT LINE regardless of the marks on the chain tensioners!!!!!!!! I have always loosened the chain a lot, kicking the tire forward so when I CORRECTLY adjust the chain it is MUCH EASIER to make sure the chain is in straight line (you should remove the chain guard so you can see the chain), do it slowly, rotating the tire while watching the chain, making sure IT RUNS TRUE!! - Forget the alignment marks!!... then slowly get the tension correct (with your fat buddy sitting on it).. remember what 3 things HAVE to be in a straight line... snug the tensioners good - NOW tighten the axle...do not over tighten. THEN finish snugging down the chain tensioners. reinstall the chain guard. Double check the axle nut!!!!
take chain off -- lay on floor --pull taught end to end push together --if it flexes more that one quarter of a inch --chain is worn --replace chain--also see how deep chain sits on sproket--- if sits too deep sprokets are wore and need replacing
The Greenfield clutch (drive belt) is adjusted by spring pressure pulling a long rod that has serations on it. Either the belt has run out of adjustment (= new belt needed) or the adjuster has stuck. Lift up the seat and push the adjusting rod that has a big spring attached to see if you can move it towards the front. Look at the pulley beside the rod, if the belt has stretched too far, the pulley will be hard up against its slot. The pulley moves towards the front to tighten the belt. I just push with my leg to get another "click" out of the adjusting rod. New belts are cheap too.
Loosen the axle nut and the lock nuts for the chain adjusters on each side of the swingarm. Turn the adjuster to move the rear wheel to the rear to tighten the chain.
You want to adjust the chain so that you have 1 inch up and down play in the chain. By this I mean 1/2" above center and 1/2" below center of the chain as it sits on the bike, 1" up and down inclusive. Adjustment should be made at the point where the chain is the tightest. Roll the rear wheel while checking the chain tension. Find the tightest point to make your adjustment.
Move both chain adjusters the same amount to keep wheel straight within the swingarm. Once adjusted, roll the wheel a couple of turns and check the adjustment of the chain again. Once finished, tighten adjuster lock nuts and retorque the axle nut to 50 foot pounds of torque.
Loosen the nut on the axle and adjust the chain adjusters to pull the axle to the rear. Make sure that each adjuster is moved an equal amount and when finished should protrude an equal amount. Retorque axle to 50-60 foot pounds of torque.
1/4" is too tight, you should have one inch minimum. Check it while the bike is upright sitting on the tires. Move the longest part of the chain up and down and you should have one to one and a half inches of play.
As a comparison, my BMW 650 has seven inches of suspension travel at the rear and my spec is 45 to 55mm which is about an inch and 3/4 to two inches.
