Question about Toyotomi TIN/TIG-329D Air Conditioner
Toyo airco is not working
It is precisely as the problem that is described. fan works oke
  • 146 Answers
Well need to check if the condenser is turning on that the part outside. if not you can check fuse next to the unite or the breaker
Posted on Jun 26, 2009
The airco system has completely stop working. The 4 position switch only work on number 4 and bring outside air (not airco) into the cabine
check fuses first - if ok.
check for refrigerant in A/C - if ok.
check switch and wires - it may be bad.
Apr 14, 2011 | 2001 Jeep Cherokee
Dear sir i have an A12AW1 art cool when i use the airco in the winter outsite temp -10 °C the airco somethime stops althow the roomtemperature is not reached. The airco is also outside...
Not sure the specs of 134. But, at 20 to 30 degrees Fahrenheit your heat pump is not going to be working very efficiently. Now, the ice on the coil is another story. Possibly your defrost is not working BUT, you don't have backup heat anyways. Yes, you should have a low pressure error code, I don't think it's a refrigerant issue.
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
May 26, 2017 | LG Heating & Cooling
Ford Taurus 2000 airco and fan works but no air comes inside the air.
have you cleaned or replaced your in cabin air filter? check your owners manual for directions.
Sep 19, 2010 | 2008 Ford Taurus Sedan
TOYO TA-09CHS aircon problem
TOYO mini split air conditioner made in Japan is very very good quality and it can runs for 20 years without any problem. You didn't hire a best ac technician to install your TOYO unit. The tubing connection between indoor unit and outdoor unit is not the right torque and refrigerant leak. Your TOYO unit runs out of refrigerant. You need fix the leak and fully charge the system. You will solve the problem.
Jun 09, 2009 | Toyotomi TIN/TIG-329D Air Conditioner
Toyo Aircon. Starts perfectly. Runs for approx 5 min and then the yellow "timer" light starts flashing and machine stops working. Green power light on...yellow timer light flashing. When you switch unit...
TOYO mini split air conditioner made in Japan is very very good quality and it can runs for 20 years without any problem. You didn't hire a best ac technician to install your TOYO unit. The tubing connection between indoor unit and outdoor unit is not the right torque and refrigerant leak. Your TOYO unit runs out of refrigerant. You need fix the leak and fully charge the system. You will solve the problem. Good luck!
Dec 28, 2008 | Toyotomi TIN/TIG-329D Air Conditioner
Toyotomi TIN/TIG-329D Air Conditioner Logo
365 people viewed this question
Top Toyotomi Heating & Cooling Experts
hmca
Level 1 Expert
Andrew Taylor
Andrew Taylor
Tom Chichester
Are you a Toyotomi Heating and Cooling Expert? Answer questions, earn points and help others
