Question about Dell (PS-5251-2DS) (M0148) 250-Watt Power Supply
I have a Dell PC-5251-2DS power supply. Am getting vertical stripes on the screen and the machine dies. Have a slight burning smell which makes me wonder if its the power supply. Would you concur?
  • rjkahall Jun 28, 2009
    Thank you Th3_uN1Qu3. The video card was a ATI Radeon 128 MB AGP with heat sink and fan. I tested a subsititution with a a nVIDIA AGP video card and all was well. So removed the ATI drivers and installed a new nVIDIA e-GeForce 6200 256MB AGP and it appears to be working well. Its a 5 year old Dell that did not warrant a high cost solution. Thanks again!
    New Friend:
  • 47 Answers
The burning smell could be coming from the video card. Stripes on the screen indicate faulty video memory, shouldn't have anything to do with the power supply.
Posted on Jun 26, 2009
  • Dell Master
  • 5,568 Answers
Have you checked in the rear of the system box to see if there is any perceptible air movement? The power supply is one of the junkiest parts of any system and the fan is the worst part of the power supply. If the fan blades are impeded by dust bunnies or the bearing has failed (very common), the power supply will fairly quickly overheat and will shut down.
I was burning a movie and my computer flash off than on than shut off.. it spelled like electrical wire burning. now it will not even turn on
Sounds like the power supply died. This is where your power cord plugs into the pc. It is a metal box inside the pc. Smell the back of the pc, at the fan opening closest to the power cord. If it smells burnt there, then you need a new power supply.
Hope this helps!
Joe
Apr 08, 2012 | Sony Computers & Internet
Burred smile coming inside the CPU
I believe you are asking about a burned smell coming from your PC case.
Firstly check your power supply as this is where the high voltage power is and therefor the most likely source of the burn smell.
Best wishes,
Graemevm
Jan 06, 2012 | Dell Inspiron 560S Desktop Computer (Intel...
Dell Dimension 4400 NEVER froze (8-9 years old) until a week ago - kept freezing at start-up - - had to interrupt power SEVERAL times to restart - - tried to power up yesterday - - make a slight sound,...
You need a power supply! Go to Amazon and search for one that is the same specs as yours. Fairly easy to replace, don't use your old one anymore, it could be dangerous.
May 05, 2011 | Dell Dimension 4400 Power Supply ** FREE...
My Dell Inpiron 6400 has just died.
Most probably a power unit, mother board or a processor failure. Any of the three can happen. I recommend you to take it to a tech. If there is a Dell service station take it there. If it just shut down while you were working: Have you checked the battery. Have you tried it using the direct power? Any burning marks or smell? Have you checked the Adapter also? Check them. IF you use direct power were you using a surge protector? Have you dropped it? Does the start button work well? Any abnormal thing related to the button? Have you spilt water on the machine? If all are fine then you have to take it to a tech.
May 29, 2010 | Dell Inspiron 6400 Notebook
My Acer Laptop screen fades or goes out when moved
Try reseating the video cable/connector. Also connect an external monitor to the external video port, power up the monitor first then boot up the laptop. The video image should automatically divert to the monitor, if you see a normal video image then the video card is OK and the problem most likely the LCD screen.
Jun 07, 2009 | Ace Computers Computers & Internet
Optiflex GX260 does not power up
any beep codes?? if there isnt any beep codes your power suply probly isnt producing enough power to boot the system you can check for a burnt or hot smell coming from the power supply if you smell burnt pop corn then you need to replace the power supply they make a power supply tester but if your only needing it once not worth 20 dollars to buy it if the power supply is replaced and it still isnt working the mother board is toast
Jun 05, 2009 | Dell OptiPlex GX260 PC Desktop
Dell dimension starts up then shuts down
power supply shot
can get power supply from microcenter
http://www.microcenter.com/single_product_results.phtml?product_id=0293459
or take your out REMEMBER where plugs go and buy a new one cheap
Jun 01, 2009 | Dell Dimension 3000 PC Desktop
LG-PHILIPS 15'' LCD MONITOR WITH BRIGHT STRIPES
Your screen is dieing your need to replace the screen the lamp are not working your screen has been damaged or they died they died ether way. I do refirsbeched LCD montiors and laptop screens.i've seen this before i have three line on my dell 17 i'm waiting for a laptop to come that got a good screen for mine. ou go on line and buy a screen for it shop around you know the drill.
please that me if I helped
Mar 21, 2009 | LG.Philips LCD LP150X05A2 Monitor
Dell 2300 projects verticle stripes accross the projector screen.
this is due to improper power supply or a loose connection inside. the symptoms are of power supply unit inside projector. check out the current and amperes inside the projector on board. sometime the current stable but the ampears are down.also check the switching transistors & filters inside.......
Feb 12, 2008 | Dell 2300MP Multimedia Projector
Shuts down after power up
It is a power supply problem common with these machines. The only solution I have found that works is to replace the power supply.
Sep 23, 2007 | Westinghouse LVM-37w1 37 in. HD-Ready LCD...
Dell (PS-5251-2DS) (M0148) 250-Watt Power Supply Logo
296 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
