Question about IBM 11P836402 for ThinkPad R40 Monitor
The screen is black but the background is there it got coffeed (the coffee went over it)
  • 34 Answers
I would try a solution of CLR and try to wipe the coffee down with a sponge. If that doesnt work I think you might need a new monitor.
Wayne
Posted on Jun 26, 2009
Brand new bunn, can't get it to make coffee
if the coffee pot does not work right, take it back and get another one...
May 11, 2016 | Bunn GRX-B Basic 10-Cup Home Coffee Brewer...
Prime water circuit error gaggia platinum vision coffee maker
The turbine flow meters contacts are corroded, or the turbine itself is broken.
Apr 10, 2014 | Saeco Odea Giro Plus Coffee Maker
Syntia out of service code?
If it is under warranty ,call the manufacturer .There are many causes to the service code , coffee beans ground too fine ,setting for 3 beans may be too much if the beans are small, try setting with one bean...
Valve, round cover , spring loaded , on top of brew group dirty, metal valve pin may be covered with deposits from coffee oils . check manual or call a service center , screen of bottom piston plugged with coffee oils , to silver screen plugged with coffee oils .
none of the super-automatics like oily , shiny or over roasted beans .
Dec 19, 2013 | Saeco Syntia Espresso Machine & Coffee...
What is coffee dispenser, i have a saeco royal coffee machine, its screen keeps telling me "COFFEE DISPENSER BLOCKED", can you share me your information, a picture will be most helpful, thanks a...
The dispenser is the brew unit in the back of the machine above the drain tray, open door and remove the black unit within and check the screen above the red o-ring.
Jul 17, 2011 | Saeco Royal Digital Plus Coffee...
I just have the regular Black & Decker coffee maker and I have the water in it and the filter with coffee, everything you are supposed to do. It used to work just fine and then one day it stopped...
Sounds like you might have coffee oil build up. I would suggest soaking the Brew Head Screen, unscrew from the brew head where the coffee oils come into contact with machine, and filter holder in a coffee oil remover or dezcal.
Remove the screw if your filter basket has one and do not screw too tight when putting back together or it will happen again
Dec 10, 2010 | Black & Decker Coffee Makers & Espresso...
I have a black and decker ODC450 coffee maker where the display went blank and it will not work at all. Any ideas?
This could signify water damage so be careful!!
If the machine smells slightly like burning plastic, DON'T use it. take it in to your local electrician to have a look.
If you think its ok...
Check your house power, Change to another power point, check your house fuse box, if this is not the problem then DISCONNECT the coffee machine from the wall, take off the back cover or bottom and look for a fuse to replace.
Take care
Regards
Ian
Nov 03, 2010 | Black & Decker SpaceMaker ODC150 Coffee...
I have a coffee cup on my screen..what is it?
The coffee cup indicates you have a Java program running. usually this is a game running in the background.
Apr 23, 2009 | Motorola Mobility RAZR V3
Coffee Grinder on the EAM3500
We just went through the same situation. We opened the top the Magnifica to get to the grinder and removed the four screws to seperate the grinding pieces. Inside we discovered two black fosilized beans/stones! We removed those, cleaned out all the bean dust and it is working like new! Took about an hour.
Aug 31, 2008 | DeLonghi EAM3500 Espresso Machine/Coffee...
Computers & Internet Logo
113 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
pankaj rautela
pankaj rautela
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
