Question about Canon Rebel XT / EOS 350D Digital Camera
Canon EOS Xt displays Err 99 how do I fix it.
Will not let me take any pic. displays Err 99
What is Err 99 and how do I fix it?
  • 477 Answers
Change the lens or try cleaning the connector tabs with a eraser.
Posted on Jun 27, 2009
How to solve the err 99 dialog on my canon EOS 400D?
Welcome to Fixya
Err 99 could mean several different things, such as... Memory Card, Lens or Lens contacts....
Here's what you can try:
Remove the memory card an enable "shooting with out memory card" and see if you still get the error. If it works your memory card is bad. Try another lens if you can. Clean the lens contacts with a pencil eraser (be careful not to get eraser dust in the camera body or in the lens). Worst case scenario is, Err 99 could be related to the shutter failing which would mean a trip to Canon.
Thank you!
Apr 13, 2011 | Canon Rebel XT / EOS 350D Digital Camera
After a few shot,my camera show "Err 99"
There's a very comprehensive essay about the various possible causes of Error 99 here (follow link).
Jan 21, 2011 | Canon Rebel XT / EOS 350D Digital Camera
Camera will come on but the lcd wont when i try to take a pic it flashes a busy signal in the veiwfinder
I can help you fix the BUSY Error or Error 99 of your Canon EOS Rebel XS / Canon EOS 1000D.
Installation of this Canon EOS Rebel XS / Canon EOS 1000D firmware version 1.06 update will solve these problems:
  1. Some cameras may exhibit a phenomenon in which the LCD monitor does not display, the shutter does not release, and the BUSY indication remains lit in the viewfinder.
  2. The message, "Err 99 Shooting is not possible. Turn the power switch to<OFF> and <ON> again or re-install the battery", appears on the camera's LCD monitor, and after the above operation is carried out,the LCD monitor displays in a language that is different from the actual language setting.
See the firmware instructions and download the firmware upgrade by following these Fixya Tips :
  1. Follow this link to download a pdf version of the firmware installation instruction guide.
  2. Follow this link to download the Windows Version of the Canon EOS Rebel XS / Canon EOS 1000D firmware version 1.06 update.
  3. Follow this link to download the MAC version of the Canon EOS Rebel XS / Canon EOS 1000D firmware version 1.06 update.
  4. Follow this link to download the Canon EOS Rebel XS / Canon EOS 1000D Instruction Manual.
I hope that helps.
Jan 24, 2010 | Canon EOS Digital Rebel XS / 1000D IS...
I have a new Rebel xs kit, and after 20 shots, I got the err 99. I did all the above, that is from cleaning contacts to everything possible procedure mentioned in this forum. There are few things that I...
I can help you fix the BUSY Error or Error 99 of your Canon EOS Rebel XS.
Installation of this Canon EOS Rebel XS firmware version 1.06 update will solve these problems:
I hope that helps.
Aug 26, 2009 | Canon EOS Digital Rebel XS / 1000D IS...
Err 99 followed by the "Busy" issue in the viewfinder
I hope that helps.
Jul 26, 2009 | Canon Digital Rebel / EOS-300D Digital...
Err 99 on canon rebel xt 350 d
The Err 99 problem occurs due to dirty contacts between the body and the lens. I recommend cleaning the contacts. You can then turn Off the camera and then remove and reinstall the batteries to reset the camera to get the problem fixed.
Jan 15, 2009 | Canon Rebel XT / EOS 350D Digital Camera
Says err 99 in the display. it also seems my pictures are darker and not as clear
This is a problem with the connection between the lens and the camera. See, for example http://www.richardsnotes.org/archives/2005/04/29/50mm-lens-contact-points/ for a lot of info -- in short, you need to make sure the contact points on both the camera and the lens are clean and making contact when you click the lens into place.
Jan 14, 2009 | Canon Rebel XT / EOS 350D Digital Camera
Canon Rebel Xt EOS Err 99
Error 99 is a "catch all" error that has several causes. It could be that your battery is not fully charged, especially if it is a generic, non-Canon battery. Charge for at least over night even if the charger says it's full. If that's not the cause, switches inside the camera will have to be cleaned by a repair shop.
Nov 24, 2008 | Canon Rebel XT / EOS 350D Digital Camera
I have a Canon Rebel XT EOS Every time i take a pic I get an Err 99. I have taken the battery out and memory card for 5 Min. If i do that I can take about 5 or 6 pics before I get that message again. What...
Try the following diagnosis steps: -
To isolate the cause of the issue, do the following: -
1. Turn off the camera.
2. Remove the lens, battery, and CF card.
3. Allow the camera to sit without power for approximately 20 minutes.
4. Insert only a fully charged battery, and turn on the camera.
5. Depress the shutter button as you would to take a picture.
Does the “ERR 99" message appear? If so, the camera may be faulty and requires a service. If it does not, then: -
2. Insert the CF card.
3. Turn on the camera.
4. Format the CF card in the camera.
Does the “ERR 99" message appear? If so, then the CF card is faulty. Try a different card. If the message does not appear: -
2. Clean the gold contacts on the lens by GENTLY rubbing them with a pencil eraser or soft cloth. Keeping the camera face pointing down, also clean the gold contacts on the camera, being careful that you do not let any debris fall into the camera body.
3. Reattach your lens.
4. Turn on the camera.
If the “ERR 99" message only appears when one particular lens is attached, then that lens should be examined by a service technician.
If you see the “ERR 99" with a different Canon lens attached, then the camera is faulty and should be serviced.
Err 99
cleaning the contacts ought to be done using a pencil eraser(i am very specific about this)to fix this error
vigorously scrub the lens contacts with an eraser. Then  gently use the eraser to clean the camera contacts (holding the contacts face-down to prevent eraser rubber from falling into the body).Put the lens back on… and the camera shoudl be fixed!
Try this and post back before you rate..
Nov 01, 2007 | Canon Rebel XT / EOS 350D Digital Camera
Canon Rebel XT / EOS 350D Digital Camera Logo
465 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
