Question about Samsung AW1893L Air Conditioner
Ac is not giving sfficient cool air,,, help - Samsung AW1893L Air Conditioner
  • 4 Answers
Your ac is probably low on freon or your filter and evaportator coil are dirty
Posted on Jun 26, 2009
Dawlance split ac
My guess is compressor motor overtemp cutout. So why is the motor overheating? Possibles: Needs bearing oil, bad bearings, compressor too much pressure, overfull with freon, mechanical friction, cooling fan not turning.
Suggest set thermostat to demand less cooling, see if compressor stays on longer.
--Gil
May 25, 2014 | Haier 18000 Btu Air Conditioner Heat Pump...
Ac thermostat WHAT IS THE PROBLEM WITH IT
you can order in a new thermostat module and have it changed but it might also be the logic board that is giving trouble .The proper thing to do is replace the whole logic board together with the sensors.That will definitely work .There are also after marker universal boards that come with their own remotes and everything but you will have to custom wire it back into the evaporator
Apr 27, 2014 | Hitachi Heating & Cooling
A local garage mechanic says the clutch has stopped working on ac that is why it blows hot air instead of cool says it will cost $900. to fix cause I have to buy the whole ac unit does this sound correct?...
have you tried charging the ac system? most ac compressors have a pressure switch that will not allow the relay to engage the clutch if the coolant pressure is low. $15 can of r134a and maybe a $20 Haynes manual is well worth the price difference, eh?
Jun 07, 2011 | 2004 Kia Sedona
Danby DPAC8399 Portable Air Conditioner no Cool air
You possibly might have a bad switch or have a dirty ac unit.Try 1st turning off the unit and cleaning the inside ...
May 27, 2010 | Danby DPAC8020 Air Conditioner
Fan Runs, AC Doesnt, Blinks 5 times
Need to look around and should have an error code and give more detail of what the problem is. If you post that i can maybe help you more. I need to know......
Aug 19, 2009 | Dometic Rooftop RV Air Conditioner
Ac system does not get cold
you should go to a mechanic and check the A/C if the freon id low it won't cool , some time at mornig it give you the semsation that is cooling but probably not..
Aug 01, 2009 | 1999 Volkswagen Cabrio
Ac not blowing cold after outside temp reaches 98 degrees
Sounds like you have dirty condenser coils. Remove the upper shroud and check the condenser for clean. Take a water hose and gently spray out the coils paying special attention not to bend the coils over with too much pressure. This will allow more air movement through the coils and give you better cooling efficiency.
Hope this helps,
Jeff
Jun 29, 2009 | Dometic Rooftop RV Air Conditioner
My AC is not cooling the air
Hello
Welcome to fixya.
I'm Huuum and happy to assist you,
You said, it is not blowing cool air after you emptied the tank.
Turn the unit off and unplug it for 5 minutes.............
Then back in with the plug and turn it on max cool.
Give it 5 or 10 minutes to get cold, and we will see if this procedure has reset the system.
Then get back to me and let me know it's working!
How old is the unit?
Please remember to leave a rating before you go!
Thank you Huuum
Aug 04, 2008 | DeLonghi Pinguino PACL90 Portable Air...
AC not cooling
It is possible that either the AC pump is not working at all, or that the refrigerant has leaked completely.
Both can be tested by an engineer, who will give you a quote on repairs needed.
Hope this helps.
Jun 11, 2008 | Heating & Cooling
Samsung AW1893L Air Conditioner Logo
255 people viewed this question
Top Samsung Heating & Cooling Experts
gbob59
billconfused
Are you a Samsung Heating and Cooling Expert? Answer questions, earn points and help others
