Question about LG 42PX5D 42 in. Plasma HDTV
No Picture on LG 42PX5D
Just watching the TV when w e had a loud pop then no picture. Removed back, checked fuses - mains OK, but left hand of 2 fuses on panel next to one with mains fuse was blown. Replaced fuse and turned on, then another loud pop. This time both fuses still OK but no picture. Any thoughts?
  • LG Master
  • 458 Answers
You will have either a fault with the Y-Sustain board (this I would assume from your description is the board you changed the fuses on) or the buffer board which is the long panel to the left of this board. It is probable one of the drive ICs on this board has blown & a replacement board is the best solution.
Posted on Jun 30, 2009
I have a 42" LG
It can't be fix by replacing the fuse alone because the IC's and other parts are already faulty. You need to replaced the entire Y-sustain board. Try this LINK or obtain it from your local LG Service Centers.
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
Jdvillanueva
Jul 05, 2011 | LG 42PX5D 42 in. Plasma HDTV
I have a LG plasma 42PC1DG, watching tv loud pop then no picture but still have sound, left tv unplugged for a while still no picture?
probably the pop was a fuse blowing inside that only controls the lamp should be an easy fix but open the tv at your own risk
Dec 06, 2010 | LG 42PC1D 42 in. Plasma Television
Tv made a loud pop sound then the picture went bad. next mornting when turned on the tv has black stuff in it that slowling melted away then the picture was still bad
Hi
A common problem for these is bad capacitors in the power supply, Remove the back from your TV and look at the power supply on the left hand side.
You will see roughly around 9 x capacitors that are bulged / domed shaped on top usually these are valued at 3300uf 10V any that have bulged or leaked a brown like substance should be changed.
This will cure the problem as they overheat being sat next to a heatsink that gets very hot!
Try and change them for the same 3300uf but a higher voltage.
Hope this helps
Jun 19, 2010 | LG 42PX5D 42 in. Plasma HDTV
Loud bang, then audio only from my tv
YES YOUR YSUS PANNEL HAS JUST POPPED CHECK OUT EBAY FOR REPLACEMENT,,
6871QYH053B
IS THE MODEL BOARD U REQUIRE,,
THERE WAS A GUY ON EBAY 64.99 AND 12£ POSTAGE AS LONG AS YOU STILL HAVE SOUND AND NO PICTURE,, YOUR PSU SHOULD BE FINE,,
Feb 11, 2010 | LG 42PX5D 42 in. Plasma HDTV
Lost all picture. Began with pinkish hue then a small pop and now no picture
Unplug the tv from the mains, take the back cover off, they will be a few screws in take out and the cover should gently prise away Once the cover is removed check the boards for fuses 1 of them is probably blown, use a multimetre with continuity capabilities to test the fuse, if blown it will need to be replaced, you can buy them in most electronic stores ie Maplins.
If the fuses are fine and still a problem check the capacitors on the power board, they are barrel shaped componants with a silver top, check for any brown liquid resadue on the board surrounding the componants or on the caps themselves, also check that the tops of the capacitors are completly flat, if not and there is a slight dome or pretrusion they will need to be changed. Good luck and post back your findings. cheers.
Jan 29, 2010 | LG 42PX5D 42 in. Plasma HDTV
Loud Pop, no more picture
sounds like a large capacitor has gone on main board
check for swelling or bulge/can be square blue in colour
Jan 05, 2010 | LG 42PX5D 42 in. Plasma HDTV
Pop and no Picture
If you are not getting sound nor picture, it could be fuse or power supply.
If it is just the picture, it is a burn capacitor or main board problem.
Jun 30, 2009 | LG 42PX5D 42 in. Plasma HDTV
Loud pop Blank screen 42 inch Viore Plasma
Unfortunately, that board is the inverter board. And for this model the inverter board is only supplied with the the PDP panel. The panel is quite expensive, here's a link if needed:
LG 42PX5D Replacement Part PDP Plasma Display Panel
Dec 26, 2008 | LG 42PX5D 42 in. Plasma HDTV
42 inch LG Plasma TV - Lost picture
Our LG 50" plasma tv screen went black after a popping noise but still had sound, after great diliberations decided to take the back off and have a peek!
We unplugged the tv and tested the fuses (there were three we could see) one had blown, the one on the left as you look at the back of the tv it also has one above it. We wrote the code/seriel number down and took the fuse to the electrical wholesalers Maplin and bought a pack of 10 fuses for £1.29 replaced the fuse in the tv and everything now fine!!!!!!
Hope this might be of use to anyone whose lost the picture after a loud popping/snacking noise but still has sound.
Dec 31, 2007 | LG RU-42PX10 42 in. HD-Ready Plasma...
LG 42PX5D 42 in. Plasma HDTV Logo
605 people viewed this question
Computer Repairing
Computer Repairing
