Question about Envision L19W761 19 in. LCD TV
Envision L19W761 LCD TV - VGA mode failure.
In vga mode it fails to show computer data once windows boots up. It shows the dos startup then the WinXP logo, then when it goes to boot into windows it states "VGA mode not support"
  • dcorales Jun 27, 2009
    Thanks Th3_uN1Qu3! It worked like a charm...I always wondered why someone would use the "Enable VGA" whilst in safe mode on WinXP, and now I know why.
    New Friend:
  • 47 Answers
The resolution or refresh rate of the computer is not compatible with the TV. Before the computer starts loading Windows, start tapping F8 and select "Enable VGA Mode" from the menu that appears, this will set your computer to a very low resolution (640x480). I believe the option is actually called "Enable low resolution video" on Vista, it's VGA mode in XP. Now you should get a picture on the TV, work your way up from there.
Posted on Jun 26, 2009
Why a black screen on xps l701x w7 i7 1.73
Black screen - no flashing white cursor in the upper left corner - no picture at all, i.e. the initial Dell start-up screen doesn't show up either:
- LCD is dead or isn't getting a signal - not an easy fix; or
- the LCD isn't being sent a signal - holding down the function [Fn] key and press display Function key to toggle through its settings (LCD panel only, Rear VGA output only, both LCD and VGA output)
Black screen - flashing white cursor in the upper left corner - the screen goes black after the windows loading screens come up but before the windows login screen comes up - it is probably a windows video driver problem. Try starting in Windows Safe Mode with VGA. Press [F8] after the Dell startup screen disappears to access the windows startup menu
Oct 19, 2014 | Dell XPS Computers & Internet
I get a message out of range.
your resolution is set too high.. change to VGA and move out from there. if the computer is set too high and you can not see boot into safe mode which should be VGA and set accordingly.
Nov 06, 2013 | Envision G22LWK 22" LCD Monitor
Startup
Restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer
Windows Advanced Options Menu
Please select an option:
Safe Mode
Safe Mode with Networking
Safe Mode with Command Prompt
Enable Boot Logging
Enable VGA mode
Last Known Good Configuration (your most recent settings that worked)
Directory Services Restore Mode (Windows domain controllers only)
Debugging Mode
Start Windows Normally
Reboot
Return to OS Choices Menu
Use the up and down arrow keys to move the highlight to your choice
select safe mode with command prompt
Click start run type cmd press Enter
black screen should open DOS mode
this will vary depending on your operating system
type in net user username
For eg. If you want to change administrator password , type net user Administrator
It will prompt you to enter the new password.
Enter the new password and the password is changed
http://wiki.ljackson.us/Control_Userpasswords2
if this fails you will need to
Select safe mode with networking to download
you could download all of these or just one save them to a usb drive for later use if one fails to remove the password
Windows Password Recovery Basic
http://majorgeeks.com/CmosPwd_d239.html
A CMOS BIOS password recovery tool
Editors note: This tool should only be used by experienced computer users.
Please see the enclosed read me if you would like to run it from Windows.
Failure to follow instructions (from Windows) will cause your anti-virus to flag this as a virus.
Jul 16, 2013 | Acer Aspire 5050-3242 Notebook
At startup askes for password that i never had. F2,F8,F12 nothing works
restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer
Safe Mode
Enable Boot Logging
Enable VGA mode
Debugging Mode
Reboot
it will prompt you to enter the new password
enter the new password and the password is changed
Editors note: This tool should only be used by experienced computer users. Please see the enclosed read me if you would like to run it from Windows. Failure to follow instructions (from Windows) will cause your anti-virus to flag this as a virus.
http://majorgeeks.com/Dr._Freeware_System_Utilities_d6416.html Dr.Freeware System Utilities which includes data recovery software, data backup, password reset tools for Windows helps you to maintain your system. Dr.Freeware is freeware, you can download and use it for free.
hope this helps
Nov 10, 2012 | Dell Dimension 3000® Pentium® 4...
My computer fails to boot several times and when it does finally get to the desktop, it freezes and then goes off into power saver mode. how do I fix that?
Try running the Check Disk Utility.
To run the check disk utility you will need a repair disc ora operating system disc. Put the disc in the cd drive and boot fromit. You want to get to the Dos Command Prompt (Black screen with whiteletters) and type the following command: chkdsk /r
Check disk will run well over an hour or two and you will notice thepercentages going from high to low, this is normal. Let it run tocompletion. Then reboot machine.
If check disk fails to solve your problem you might have to reinstall windows.Try doing a Repair Install that way you don't loose your data, documents,music, pictures, videos or programs.
In windows xp you get to the dos command prompt by selecting R for repair whenthe options appear.
In Vista and Windows 7 you want to get to the recoveryconsole and look down at the bottom of the window for the Dos Command.
May 04, 2012 | Dell OptiPlex 360 Desktop Computer
My monitor wont show picture and if it does it has a sing saying vga blinking what do i do please help
Check all your cables and in a worst case senario use another monitor or select vga mode, by pressing f8 before booting into windows.
Aug 02, 2010 | Gateway FPD2275W LCD Monitor
Our acer 19in LCD monitor goes blank after initial startup and msg "Input not Supported" appears. Startup msgs are shown but once Windows XP starts, this error appears
Your resolution is set above what the monitor supports.
when computer is first starting up hit f8 to get to boot modes.
choose Enable VGA Mode: This option starts Windows in 640 x 480 mode by using the current video driver (not Vga.sys). This mode is useful if the display is configured for a setting that the monitor cannot display.
When you are booted into windows you can then set your resolution to the highest that the monitor supports which is 1440x900
Let me know if this helps.
Mar 16, 2010 | Acer AL1916W 19" LCD Monitor
Display off
Boot into safemode. push F8 on startup until safemode option appears. If computer displays windows there, then it's most likley your resolution or your monitor frequenzy set to high/low.
change the resolution in safe mode, and the the frequenzy to 65 then restart your computer in normal mode.
Dec 21, 2008 | Computers & Internet
Blank Monitor
Start pressing F8 at boot
When the Windows Startup menu appears, select ENABLE VGA MODE
This will boot the system in 640 x 480 resolution but the video driver will be installed. Once at the desktop, either reset the display to the normal resolution settings or reinstall the video driver.
Aug 06, 2008 | Relisys RLT1720 17" LCD Monitor
Envision L19W761 19 in. LCD TV Logo
856 people viewed this question
Top Envision Televison & Video Experts
matt martin
matt martin
Are you an Envision Televison and Video Expert? Answer questions, earn points and help others
