Question about HP Compaq nc6120 Notebook PC
I am repairing purson in pakistan. and my client laptop have a problem in his charging side, when we connect the New adoptor to charge the Battery of Laptop after some time the power adoptor goeing to burnt. I replace Qty:2 of HP Oregnal Power adoptors & Batery, Problem Same , I am very thank full to you if you give me the Proper solution.
  • 674 Answers
Shortage you need to change the dc jack connector... because is chortage that one if did not replace the dc jact connector.. the same at all even you use the original adaptop or battery
Posted on Jun 26, 2009
E6410 does not charge the battery
Check if in starting it is giving any error for the adoptor? if it is giving then it is adoptor issue other wise it is battery issue. May be it is also cause for M/b, so tell me exjact problem so that i can give you the solution
Jan 14, 2013 | Dell Latitude E6410 Laptop
Battery on HP nc6400 does not charge - new battery from hp - what could be the problem
CHARGING IC PROBLEM bq 24703 ITS CHARGING IC NUMBER .........THIS IS BURN OR BAD CONNECTION ......
GO TO TECHNICIAN AND REPLACED THIS IC ....
CH.OWAIS SHER
SENIOR TECHNICIAN IN PARADISE COMPUTERS (LAHORE) PAKISTAN
Mar 24, 2010 | HP Compaq NC6400 Business Notebook
Dell latitude d610 not charging battery, I bought a new replacement battery thinking the old battery was the problem.
See the Adoptor status in the bios, if it is not detecting it the adoptor fault otherwise you have mentioned above you have already replaced the battery then it is m/b issue
Dec 28, 2009 | Dell Latitude C640 Notebook
I have a Gateway 4525GZ power problem
your ac adoptor is not correct it is low amh
please check for original adoptor
Jul 30, 2009 | Gateway 4525GZ Notebook
I have acer power and chaarging problems anyone can help me plzzzzzzzz
you can try one step if that doesnt work contact MFG ... remove the battery and disconnect the power adoptor and hold down the power button for 10 seconds and than connect everything back and try charging it
Feb 20, 2009 | Acer Aspire 5315 Notebook
LI 6000 2-way charging base does not charge- no indicator light
Dear sir,
It seems that ur adoptor is not ok , u can save the money by purchasing any 9 V adoptor, It available for less than 1 USD in our country ..& cut the wires of ur budled adoptor & fix them in correct polarity with the wire connecting the charger base ..( before doing this proces check voltage output from adoptor by using a multimetre.)
Regards
Raj
Jan 12, 2009 | Cobra Li 6000-2 WX VP GMRS/FRS Two-Way...
Laptop wont turn on anymore.
poncha,
Your battery might be dead and it might cause problem to boot.
  • Remove battery, insert A/C adoptor and try to boot normally, if success then you should change your battery and all will be fine. If no success then try next step.
  • Remove battery, remove A/C adoptor. Press and hold power button abt 10 seconds then insert A/C adoptor holding the power button on. Keep holding for 30-45 seconds. If still no success then have a tour to the service centre.
Thanks & Good Luck
Iqbal
May 18, 2008 | Dell Inspiron B120 Notebook
Laptop not holding charge
remove the battery and pluged in the power suply throu adoptor.
And boot your lap, if its work then changing your battery will fix the problem...........
Thanks
Iqbal
Apr 01, 2008 | Computers & Internet
Sony vaio Adopter is beeps when i connect to power supply
I think ur adapter have some problem.Better to change ur laptop adapter and check it.whether it give same problem.Then please contact nearest service center.
Thanks
Feb 26, 2008 | Sony VAIO VGN-N130G/W Notebook
HP Compaq nc6120 Notebook PC Logo
46 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
