Question about Sanyo DS25390 TV
My 13" 2001 CRT Daewoo TV cable connection got loose
My 13" Daewoo TV cable connector almost ripped out of the TV, and now, the thing is loose. Whenever I move the cable, the whole thing moves. Is there a way I can buy a part for the TV? If so, does it requiring soldering? I cannot afford to get the TV fixed, or a new one. Plus, I might as well buy an HDTV for my Xbox 360, and an antenna, and coaxial cable as well...thanks
  • 34 Answers
Yes you can buy the connector at radio shack and I do believe it requires a little bit of soldering but not much , the same thing happened to my tv and we fixed it up no problem.
Wayne
Posted on Jun 26, 2009
The menu does not have a choice to change from antena to cable how do I get it on cable
Typically, your cable box will have two inputs & one output that goes either thru your VCR for recording puposes or just direct to the TV. Your switching will happen thru your cable box, like an A/B switch, designed so that when cable is down, you can switch over to locally broadcasted TV stations. With DTV now in play in most areas, you will want to connect the antenna's connector to your DTV box, then connect it to your cable box for switching back and forth. The new flat panel TVs already have a digital receiver built-in, so in that case you would eliminate the DTV box.
Nov 08, 2013 | Daewoo DVN-14F6N 13" TV
I have a Daewoo DTQ-13Z5SC trying to run sega genesis on it, how do I get the av to work? don't have manual since I bought tv second hand at a thrift store
Hello
If the game box have AV out on it, you can connect it to tVs AV in by using an AV connector wire.This is the pircure of the AV cable that should connected in between TV and game box. You must select the input to TV as AV.3_4_2012_1_36_06_pm.jpg
Mar 04, 2012 | Daewoo DTQ-13Z5SC 13" TV
I have a 13 inch Daewoo color TV model, DTQ-14P1FC I want to connect a Dvd player to it but I don't see any place on the back for video connection. Is there a way to connect a Dvd player to this t.v.?
you need rca connectors or hdmi connectors. if you only have the round cable tv style connector, you will need a modulator to connect to first
Jul 31, 2010 | Daewoo DTQ-14P1FC TV
Cable connector is loose in TV I am getting a fuzzy picture because I do not have a good cable connection
connector needs to be resoldered. it is soldered to the board and to the tin tuner housing. Most likely it is loose from the housing which is making it move around and not alowing it to get a good ground.
Sep 25, 2009 | Televison & Video
Antenna/Cable Connector partially ripped... Hi, everybody. Does anyone know how to fix a ripped antenna/cable connection? Thanks for the help. My TV Model is a Daewoo DTQ-13P3FC 13" TV for more details....
The cheapest way i can think of is open the tv and solder the ripped peice back on. That should work. If not you can go to radio shack and buy a new peice for it and install it by soldering the connections back on. Hope I could help.
Wayne
Jun 26, 2009 | Daewoo DTQ-13P3FC 13" TV
Problem getting cable to tune in to Daewoo TV
you need to get back origenial daewoo remote control to do the setup input & output. good luck!
Mar 02, 2008 | Daewoo DTQ-20U4SC 20" TV
Cable TV connection
Hi, A couple of possibilities: 1. Line loss, some of the cables might be too long, shorted, loose ground, not connected right; 2. Splitter - passive splitter, you might be better off using a distribution amplifies (with gain control pref); 3. RFI - TV interference from external sources. Hope this be of some help/idea. Post back how things are or should you need further information. Good luck and kind regards.
Sep 02, 2007 | Televison & Video
Tv problem
Mine (2005 vintage) is doing the same thing. Wiggling the connector at the rear of the set cures the issue. however, it must be a loose connection inside. How about soldering the connector?
Any other ideas on how best to handle the soldering of the connector inside the set?
May 12, 2007 | Sanyo DS24425 24" TV
Black and White !!!!!!!!!! aaaahhhhhh
As ther is no color & every thing normal. you have checked most of the things from outside. solution please check loose contact near chroma ic. check connector for loose. parts related to chroma section. finally chroma ic. good luck
Nov 24, 2006 | LG RU-27FB30C TV
Televison & Video Logo
90 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
