Zenith C27A24T 27" TV
Problem for Zenith C27A24T 27" TV
White lines across screen and color faded.
By riko_bite_me on Jun 26, 2009
I went to turn on my tv after hooking up a audio/video adapter and the screen had crooked horizontal lines across it and the color was faded to gray. Nothing had happened to the tv since my vcr died which was like 3 weeks ago, so I have no idea what could be wrong with it.
Best Solution
posted on Jun 26, 2009
Very Helpful)
Th3_uN1Qu3
Rank: Wiz
Rating: 92%, 30 votes
Those lines are called vertical retrace lines. They appear when the G2 (screen) voltage is set too high, or when the video amplifier fails or lacks the high voltage supply (200v).
Have you got any electronics experience? You will need a multimeter and soldering skills.
If you do or know someone who does, take the set apart, look at the video amplifier IC (it is on the board at the back of the tube), get its model and download the datasheet. Find the pin that is labeled "high voltage supply" and with the set turned on measure it against the one that says "ground". You should have somewhere between 180-210v there. If that voltage reads zero or a very low value, the amplifier circuit is shorted or the power supply is not working properly. Unsolder the video amplifier and measure again, if the voltage comes up then buy a new amplifier IC, if it doesn't it's time to check the power supply. I believe you can find a service manual easily, follow the directions there.
Safety precautions: Do not under any circumstances touch the leads of any capacitors, and stay away from the big fat wire going to the top of the tube. Do not do anything inside the TV while it is plugged in (except measurements), and always use well-insulated tools. The high voltage section of the TV does not pose any health danger, however the shock it can give you will make you jump back, possibly into something sharp.
Was this helpful?
Yes
No
1 person thought this was helpful
Popular Solutions for Zenith C27A24T 27" TV
Questions and Unsolved Problems for Zenith C27A24T 27" TV
Do you recommend Zenith C27A24T 27" TV?
Answer
Answer
I have a older Zenith TV, Model # C25A24TF. The original remote will not work. I have digital cable... (More)
Answer
i can't get my tv to go up & down with the remote
Answer
my silver Zenith wont turn on at all but the red power light is on when plugged in
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Standard... Experts
Top TV Repairmen
in , OH
(316) 283-8873
(316) 838-0811
Authorized Warranty On Rca,Integrity In Sales...
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
