Question about Canon PowerShot S2 IS Digital Camera
In am getting an E18 message on the screen and the lense doesn't come out
  • Canon Master
  • 4,738 Answers
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Posted on Jul 10, 2009
  • 477 Answers
This issue is because the camera ultra sonic motor went out the cost 95.00 to replace.
Posted on Jun 27, 2009
Camera powered on, lenses extended, then got an E18 error message. Won't take pics, lenses won't retract. Tried charging battery, no difference. Powers up, powers off, that's it.
Canon E18 error happens when the lens gets stuck while trying to extend.
There is a step-by-step tutorial (with pictures) for fixing this yourself on this website, which is too long to re-post here.
You can also try tapping the USB port lightly against a hard surface, and using compressed air to blow out the area between the camera body and the lens turret.
If you can't fix it yourself and decide to send the camera back for repair, be warned that Canon has horrible customer support and response time. You might want to consider replacing the camera instead.
Oct 25, 2009 | Canon PowerShot S410 / IXUS 430 Digital...
E18 message come up on screen and then the powers off
FOR CAMERAS THAT USE BATTERY: U ARE POSSIBLY OUT OF BATTERY
FOR OTHER CAMERAS: YOUR CAMERA CAN NOT TAKE A PICTURE FOR SOME REASON. IT MIGHT BE FROM SMASHING OR YOUR POWER BOARD OF YOUR CAMERA IS NOT WORKING WELL. CHECK TO SEE IF THEIR IS ANTHING WRONG WITH IT (EX MAJOUR SCRATHES CMERA LENSE BROKEN ETC)
I HOPE THAT HELPED IF ALL ELSE FAILED RETURN IMMEDIATLY!!
Sep 19, 2009 | Canon PowerShot A95 Digital Camera
Dropped my cano a520 with lense out and now I get
E18 error is common error if the lens is broken already
bring your camera to the nearest repair center
Aug 21, 2009 | Canon Cameras
Canon G7 lense does not extend fully but it is NOT e18
Maybe lens needs adjustment. The info on this page may help. Copy and paste this link for more info.
http://www.fixya.com/PostAnswer.aspx?thid=1841738&prdid=447928&ctgid=67
Mar 22, 2009 | Canon PowerShot SD500 / IXUS 700 Digital...
E18 error message on the Canon A400
The solution for your problem is too much to type here. So, I'm going to give you a link that explains many problems with lenses and how you can correct issues. Please note that some of these can and might cause your camera harm, and should only be tried if you can't pay for a repair, and/or ready to junk it. But it just may help you.
Good Luck,
Rob
Mar 09, 2009 | Canon Cameras
When I try to zoom, screen goes black and "E18" appears in bottom corner
I won't say this is a solution but to prevent the lens retraction E18 message which seems to be common with Canon zoom lenses, I put the extension tube on mine. Sometimes I put a polarizer lens on it but usually I just leave it on to protect the lens when it is on. I have dropped it (on the carpeting at home) and never had a problem. If you have a Canon with a zoom lens, get a lens hood for it ASAP!! My wife's A520 has one on hers too. No problems.
There are lots of other places on the web with suggested fixes. Keep looking and keep enjoying this camera. Merry Christmas all.
Oct 31, 2008 | Canon PowerShot S2 IS Digital Camera
E18 lens will not come out
E18 Error Fixed Canon PowerShot A520 My lense would not come out and would give me the E18 error and shut down.
I just pressed the power button on and held it down while extending the telescopic zoom lense. It made a horrible sound but the next thing I knew the lense extended out and the camera worked again!
Apr 07, 2008 | Canon PowerShot SD200 / IXUS 30 Digital...
After E18 fixes...lense got in..but does not come out
You can just head to darntoothysam.com and search for "E:18" without the quotes. You won't see your model listed, but you can buy any one of those model repairs and follow the steps to get your A510 fixed.
Feb 26, 2008 | Canon PowerShot A510 Digital Camera
E18 Message - Beeping.
The E18 error message relates to a problem with the zooming mechanism (lens would not retract or extended) Press the power button on and hold it down while extending and twisting the telescopic zoom lens. It might fix your problem. In any case it could not make it worse Good luck!
Sep 13, 2007 | Canon PowerShot A520 Digital Camera
E18
This error is cause by a few things. First you need better power, how old is the unit? The battery pack may need replaced, the lens mechanism draws alot of power and sometimes if the flash is charging and the lenses are moving it struggles for power and shuts down. Another thing that can cause this error is jammed gears in the lens. This can be cause from an impact (dropped unit) or debris in the lens mechanism (sand, dirt, dust) the gears are so small and as is dust anything can blow in there and get jammed in the unit to jam it. I have got units to function again by tapping on the front of the lens while repeatedly tapping on the front of the lens. The idea is to work the jam out and free the lens. The E18 means a stuck lens but the reason its stuck i canot tell with out looking at it. Tap on the front of the lens (the part that moves in and out like a telescope) or try and tap on the side while powering it on. If you know some one with a unit like yours try their battery before you get a new one. They are very power hungry and if your unit is a few years old it may be time for a new battery.
Apr 03, 2006 | Canon PowerShot S400 / IXUS 400 Digital...
Canon PowerShot S2 IS Digital Camera Logo
107 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
