Question about Apple iPhone Smartphone
Iphone touchscreen control not workinng.i can get to turn on in manually but in touchscreen only turn off working
  • 129 Answers
Try resetting the phone. With the iPhone turned on, press and hold the square key and the power key until the phone turns off, then turns on. Release the keys when you see the apple appear on the screen.
Posted on Jun 26, 2009
I dropped my model No. A1241 phone and the touch screen doesn't work but it has no cracks. how can I fix it?
not having a crack on the screen doesnt mean your touchscreen will work. you said you drop your phone, it has a great possibility that it cause an internal damage to some of the microchip inside your phone that controls the sensors of your touchscreen.need to reheat the microchip inside it. open your phone and try to check for the microchip near the flex from the board of your phone going to your screen. then reheat it, but dont move it.
Jul 10, 2011 | Skque SILICONE SKIN CASE FOR APPLE iPHONE...
Iphone touch screen is not working. Restored the phone from backup succesfully, but screen still doesn't work. Phone receives calls, etc., but can't unlock or answer calls because screen doesn't respond to...
Even though the iPhonemag-glass_10x10.gif is a device that is extremely convenient to have, it still can cause frustrations. Specifically, there may be times when the touch screen does not work properly.
There are various problems the iPhone touch screen could encounter. Although there are times when the screen does not work altogether, there are other situations when certain portions of the screen work and others don't. Of course, it is possible that the entire screen works, but is simply slow. Regardless of the exact problem, there are ways to troubleshoot the iPhone to diagnose the real problem.
  1. tep 1 Remove the wiping cloth that came in the small black envelope along with the iPhone. Wipe the smudges or dust off the screen with this cloth. It is best to wipe in a circular motion.
  2. Step 2 Do not put lotion on your hands and do not touch the screen if your hands are wet. Any kind of moisture can affect the way the touchscreen operates. Moisture sometimes slows the response time from the screen to the operating systemmag-glass_10x10.gif.
  3. Step 3 Check for a protective sheet on the screen. If there is some kind of a film or sheet on the touchscreen, the screen is likely not able to react to all of the sensitivities of the touch of a finger as it normally would.
  4. Step 4 If there is an application open and the touchscreen seems to not be working, simply close the application and retry it. A frozen application can usually be closed by pressing and holding on the circular button located just below the touchscreen.
  5. Step 5 Press and hold the home button as well as the reset button on the top of the phone to turn the iPhone off. A red slider will appear. Slide it to the right to turn the phone off. Press again on the "Reset" button on the top to turn the phone back on.
  6. Step 6 Completely reset the iPhone by holding the "Home" button and the "Reset" button for a full 10 seconds until the phone resets and the Apple logo appears on the phone.
    • If you are using the iPhone in cold weather and wearing gloves, the iPhone will not react to the gloves as it will to the touch of a finger.
    • If the touchscreen is dirty, do not run the iPhone under water. Doing this will likely ruin the phone, but even if it doesn't, it will possibly make the phone run slower.
Nov 15, 2009 | Apple iPhone Smartphone
Right side of i touch screen non-reactive
Perform the under given steps to troubleshoot the issue:
(i) Clean the iPhone screen with the cleaning cloth that came in the box with the iPhone.
(ii) If you have a protective plastic sheet or film on the touchscreen, try removing it because it may be preventing the touchscreen from working properly.
(iii) The current application may not be responding (frozen), press and hold the Home button below the screen for at least 30 seconds, until the application you were using quits.
(iv) If that doesn't work, turn the iPhone off and turn it on again. Press and hold the Sleep/Wake button on the top of the iPhone for 30 seconds until a red slider appears, and then slide the slider. Then press and hold the Sleep/Wake button until the Apple logo appears.
(v) If the iPhone did not turn off, reset the iPhone. Press and hold the Sleep/Wake button and the Home button at the same time for a least 30 seconds, until the Apple logo appears.
If the issue persists then service will be required.
Sep 08, 2009 | Apple iPod touch
Iphone keypad not working
First try a hard reset. Hold down the power and home button simultaneously for 10 seconds until the iPhone reboots.
If that doesn't work you need a new digitizer. If it's a 3G I would advise replacing the digitizer. If it's a 2G I would not advise replacing the digitizer b/c you would have to replace the LCD, Digitizer, and the Glass Panel and the cost would exceed $100.
You could also consider selling your iPhone AS IS for parts or repair on eBay, Craigslist, BuyMyTronics.com or I could make you an offer.
Hope this helps, Rate me please!
Jun 17, 2009 | Apple iPhone Smartphone
I replaced the touchscreen and now does not turn
sir please visit your nearest mobile repaire shoppe
Jun 06, 2009 | Apple iPhone Smartphone
Touchscreen
go to i and rre to tweersion "that happend to me"
Jun 07, 2008 | Apple iPhone Smartphone
Touchscreen and buttons stopped working
u dropped it and spoilt it or either restore it and then unlok it
enjoy
May 22, 2008 | Apple iPhone Smartphone
Iphone touchscreen
Best bet would be to call Apple, especially if it has warranty. They will be able to tell you if it is software or hardware. They will probably have a reset technique to assist you.
Apr 23, 2008 | Apple iPhone Smartphone
Iphone touchscreen not working
try fully charging the battery
Apr 15, 2008 | Apple iPhone Smartphone
Iphone touchscreen not working:(
I think my solution for my Viewty will work for the iPhone
I found a solution for the LG KU990 Viewty touchscreen not responding problem. After thinking about twisting my phone, I came up with another solution which actually works every time. The touchscreen works via layers of plastic that when contact is made, a signal is triggered from the coordinates of the contact. However, when the phone has pressure, these layers of plastic stick together somehow. So, to fix it.... Get a small strip of adhesive tape that will not leave a sticky residue on your screen. Apply that tape in several spots on the surface of the screen, and lift it away from the phone with light pressure. Repeat this in several areas of the screen. That's it. You're done. Your screen should function properly. Simply recalibrate the touchscreen at this point in your settings menu. I hope it helps everyone with any type of touchscreen. I know it helped me. The touchscreen phones are totally useless using only the hard keys!
Kenny N
Jan 12, 2008 | Apple iPhone Smartphone
Apple iPhone Smartphone Logo
144 people viewed this question
Top Apple Cell Phones Experts
David
Marvin
Marvin
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
