Question about Zanussi ZSS7 / 5W Compact Refrigerator
Zanussi Z25/4W compressor very hot. Fridge and
Zanussi Z25/4W compressor very hot. Fridge not cold and freezer not freezing
  • 236 Answers
SOURCE: Zanussi fridge freezer
sounds like the freezer evaporator has iced /frosted up and you will not get cold airflow through it. try a 24 hour defrost to clear it. then check fridge cooling.
Posted on Jun 04, 2007
eagle338
  • 4889 Answers
SOURCE: Zanussi fridge freezer - fridge not working
The defrost cycle is not happening like it should, that's what causes the block of ice (and poor air flow). If you have all that defrosted look at the defrost bi-metal, it usually is a small round disk with a couple wires coming out of it and it's clipped on the coils. When it's cold enough, it passes electricity to the heat elements, when it gets hot enough it "opens" and kills power to the heat elements. If that is bad (swollen cracked or bloated) and not passing electricity to the elements that's the problem. Another item would be the defrost timer itself, if it doesn't work (no clock motor turning) then it will never go into defrost. And the last and usually least expected failure would be the heat element themselves not working
Posted on Oct 09, 2007
MATRIX_MMX
  • 209 Answers
SOURCE: zanussi fridge freezer
dear plapy
This to me sounds as if either your gas is not circulating through the refrigeration system, or you have a problem with thermostat. If you have recently physically moved the fridge and then powered the appliance up on the mains without letting the gas settle, then you could have damaged the fridge. And there is not really a lot you can do about this, unless you want to call out a refrigeration engineer to re-gas your fridge and assess the circulation of the pumped cold air flow.
Other problems aside of gas and thermostat could be associated with the pump (if your model has one fitted), and with this in mind, i have a good mind to have a look at the SIOS (spares, Information, Ordering, System) disc for zanussi vendored models and then get back to you once i have a further solution for you. However, I will need your make and model of zanussi fridge, so if you have this to hand it will be most appreciated. In the sad event that you dont have the paperwork/ manual for the fridge, then you can find the manufacturers model details on the rear of the fridge. however, when you move the fridge, you will need to let it stand again before powering up the unit after repair, and this should be done for a period of no less than 24 hrs, and no less than 28hrs if your appliance is a fridge freezer combi.
So once again, when i recieve further information regarding your make and model of refrigerator, then i will be able to fully investigate this matter for you, and try to come up with your most appropriate solution..
In the mean time, i bid you take care, and hope to hear from you soon
Yours sincerely
oz
Posted on Apr 11, 2008
SOURCE: refrigerator not that cold and freezer not freezing well
dirty coils underneath the fridge, or the fan in the bottom (to cool the compressor) is not working.
Posted on Aug 07, 2008
SOURCE: I have a zanussu fridge
Re. Zanussi ZK87/46EFS Fridge Freezer
The same symptom occurred in our fridge freezer. The fridge compartment warmed up whilst the freezer compartment continued to keep temperature.
The cause of our problem was diagnosed as a frozen sensor that controls a flap, that controls the flow of cold air from the freezer compartment up into the fridge compartment. We were advised to power off the fridge freezer (removing all food and trays from the freezer unit first), and to leave it to defrost for 24hrs. We needed to place a few towels on the floor of the freezer compartment to soak up the melt water. After 24hrs we followed the power up instructions in the manual (versions are available online if you have lost yours). Within a few minutes it was obvious that the fridge compartment was being cooled – Problem solved :)
Posted on Nov 01, 2008
My KTM3900WB fridge/freezer is not freezing and cooling in the fridge. The light goes and can hear the motor is running.
You are either low on freon refrigerant, or your compressor is frozen (usually due to low freon) or your compressor is bad. the motor will cycle on and off even though the compressor is not working. the refrigerator away from the wall and look compressor will be a nerf football sizedand usually black cylinder. It could be very hot or cold/frozen. can also unplug the refrigerator leave it for a few hours and plug it back in if it work you are low on freon. You need a repairman
Jan 04, 2015 | Refrigerators
Samsung rs2630sh not cooling or freezing
If it has fan to deliver cold air, and it is not working, cold air is stuck on the begining. So your fan could be dead. And I suppose, that compressor is running all the time. Even compressor could stert freezing if fan does not deliver cold air in fridge. The other option is, that there is not enough gas in the compressor. In this case compressor vould not be freezing, but line, going out of compressor has to be hot, if it is not, there is no gas.
Dec 02, 2017 | Samsung RS2630WW Side by Side Refrigerator
I have zanussi zx99/5w and fridge not working and freezer cold but not freezing
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Oct 17, 2010 | Zanussi ZX99 / 5 Bottom Freezer...
Fridge warm. lights up. turned it off for a bit then back on any clues to get it back to cold. freezer waming too
Do you hear the compressor running? If so you may have a bad defrost timer, causing the evaporator to freeze up, and therefore your poor cooling. If you do not hear the compressor coming on then it could still be a defrost timer issue (stuck in defrost) or it could be a more serious problem that will need to be tackled with a voltmeter and a clamp on amp meter. (checking @ compressor)
Hope this helps
Oct 05, 2009 | Zanussi 5.30 cu. ft. / 150 liter Upright...
The fridge is cold but the freezer won't freeze
The grill being the condenser coil- The sealed system is low on freon or the compressor isn't working correctly.
Jul 01, 2009 | Frigidaire FRS3R5EMB Side by Side...
Zanussi ZFC 45/30 SS is hot at front between the doors..
This is normal. This is a defroster to keep moisture from condensation from freezing the doors shut.
Jun 30, 2009 | Refrigerators
Freezer not freezing food and fridge not staying cold enough
Check the compressor with a volt meter, if the compressor is getting proper voltage then check the relay. But this sounds like a problem with the compressor
Feb 12, 2009 | Whirlpool GB9SHKXL Bottom Freezer...
Refrigerator not that cold and freezer not freezing well
between the door and freezer is very hot, and the refrigerator is not that cold and the freezing is freezing but not that well, ice cream is soft but meat freeze and ice is not melting. Also behind the fridge at the bottom is very hot.
Jun 05, 2008 | Kenmore 64802 Top Freezer Refrigerator
Zanussi ZSS7 / 5W Compact Refrigerator Logo
308 people viewed this question
Top Zanussi Refrigerators Experts
Charles T Nevin
Charles T Nevin
Colin Stickland
Colin Stickland
Dan Webster
Dan Webster
Are you a Zanussi Refrigerator Expert? Answer questions, earn points and help others
