Question about OKI B4200 Led Printer
The error lights on the oki B4200
What do the error lights on the oki B4200 mean. Especially the last one on the right flashing?
PRINT SPOLLER SERVICE NOT WORKING
If you are having issues with your system's print spooling services. You can try this steps:
Click here: PRINT SPOOLING
Hope this helps!
Good Luck!
Mar 14, 2011 | OKI B4200 Led Printer
There is a yellow light flashing which i think is stopping my printer from working.it is the symbol furtherst to the right out of the 4 symbols any ideas
The rightmost LED is the Error light. How fast is it flashing?
If the light is flashing 1 long flash every 4 seconds (no other lights flashing), then either the image drum needs to be changed or the toner is low.
If the flash is one blink a second, then you have a paper problem or a cover open.
If you installed the OKI software with the driver, you can use the Printer Status monitor to identify the problem and order the consumables if you have a slow blink error. (Open the printer control panel (Start >Programs > Status monitor) and Maximize the window to see the Printer status.
You can find the manual for the OKI B4100 here: http://my.okidata.com/PP-B4100.nsf?opendatabase . View all manuals on the right. If that link doesn't work, see the support site: http://my.okidata.com/Home.nsf/Welcome?OpenFrameSet and select the B4100 in the Color/Mono Page Printer drop down menu.
I hope this helps.
Feb 14, 2011 | OKI B4100 Laser Printer
OKI c3200n "COMMUNICATION ERROR"
try switch off, unplug, hold up and down & reset button at the back, swith on
Jan 30, 2009 | OKI C3200n Led Printer
BJC55 Printer not printing
There are some possibilities due to the above phenomena. Let's discuss about it:
1) If the POWER light is flashing green, then your printer is now warming up or performing maintenance procedure (replacing cartridge/tank) or cleaning print head, just wait a few seconds till the light stop flash. Also if the last page of a print job not done, this POWER light flashing green.
2) If the CHARGE/ERROR light is flashing orange with beep 3 times, it mean your cartridge need to be install (especially the 1st time turn on printer) or cartridge being replaced, just install the cartridge and press RESUME to continue.
3) If both POWER light is flashing green and CHARGE/ERROR light is flashing orange with beep 3 times, then your printer may facing a very serious error and maybe need a replacement.
Hope these help.
YBC (/\)
Nov 01, 2008 | Canon BJC 55 InkJet Printer
Oki 5521 alarm light flashing. No other lights flashing. Nothing in manual.
You have a fatal error, what kind of error is specified by led combination of PRINT QUALITY and CHARACTER PITCH.
Oct 07, 2008 | OKI Office Equipment & Supplies
Error light on my oki c3300 is flashing new ink and everything looks ok
I had a paper jam on my Oki C3300 and after putting back all the cartridges it flashes green revs up and then goes to error. Also where will I find the error code?
Jun 10, 2008 | Office Equipment & Supplies
Service Call 020 Fatal Error
Error 020 is a ROM dimm error, could be as simple as reseating/replacing Rom Dimm or a expensive main PCB, you need to get hold of a oki dealer, contact oki to find closest OKI repair agent.
www.oki.com
Jan 08, 2008 | OKI C9300 Led Printer
Problems with Oki Printer and Toner Sensing
Yup Dodgy refill cart without require chip to identify itself to the printer or cart not suited to b4200/4250 , get a real oki toner from your country that suits exact model.
here is code for required product
OKTCOB4200
Oct 31, 2007 | OKI B4250n Laser Printer
There is a red light flashing
From the OKI site, I found this information. My problem is a Flash 2 Blink, which is a problem with the cover or minor error, whatever that means. I can't figure out how to fix it. Any suggestions greatly appreciated!
Flash type Ready LED (Green) Manual feed LED (Amber) Error LED (Amber) Meaning Flash 1 -- slow blink X ecblank.gif ecblank.gif The printer is processing data when printing has been suspended. ecblank.gif ecblank.gif ecblank.gif X The image drum required changing or toner is low. Flash 2 -- blink X ecblank.gif ecblank.gif The printer is receiving and processing data during printing or the printer is resetting itself. ecblank.gif ecblank.gif X ecblank.gif The printer is requesting manual paper feed. ecblank.gif ecblank.gif ecblank.gif X There is a printing error, problem with paper or a cover open. ecblank.gif X X X There is a minor error with the printer. Flash 3 -- rapid blink X X X There is a major error with the printer.
Oct 27, 2007 | OKI B4250 Led Printer
ICONS
Install the status monitor (download from oki or from your disks) to enable computer to tell you, and read the manual
Oct 25, 2007 | OKI C3100 Led Printer
OKI B4200 Led Printer Logo
341 people viewed this question
Top OKI Office Equipment & Supplies Experts
Jimbras
Level 1 Expert
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
