Question about Poulan/Weed Eater #Wt200 711724 24cc Gas Blower/Vac
Will start but when placed on run mode shuts off
  • 1,041 Answers
Check the fuel lines for cracks/breaks. If they are o.k., then:
You will need to disassemble the carburetor and spray with carb.cleaner. Make sure the small screen is free of debris.(Should be able to see daylight through it.)
Use a Den Tek Brush, (http://www.drugstore.com/products/prod.asp?pid=165357&catid=1152),to clean the small portals in carb. These portals can become blocked. Reassemble and start.
If the carb. parts are more than 4 years old, you may have to replace them.
If you need further assistance, just let me know.
Jim
Posted on Jun 27, 2009
  • Jim Parker
    Jim Parker Jul 01, 2009
    Did this solution solve the problem?
    Jim
Acer Aspire 7560 wont restart
Before shutting down your system click on any programs still running and shut them down. This will cut the time for normal shut down to take place.
You could also run a hard drive diagnostic to see if it has any errors. There might be some if you don't let the computer shut down itself. Restarting can also cause the programs to become corrupt, if they didn't shut down right. Running a defrag on the drive will also help it shut down quicker.
Look on the net also for information on getting your PC to shut down quicker.
Oct 18, 2014 | Acer Aspire Computers & Internet
I have a whirlpool electric dryer and the automatic sensor mode is not working. In the automatic sensor mode it drys the clothes but will run forever. The timed mode works by drying the clothes and...
I wonder if maybe your wire is attached to the sensors? If it vibrated off the connection that could be the problem. Here is a video I made which shows how to connect the wire:
Oct 16, 2013 | Dryers
My friend has a 80g ps3 and they upgraded the software to inclued the 3d play, but since then their ps will not boot up. It starts to boot but before it finishes booting the screen goes pixalated and then...
You can try doing a restore in safe mode. If that doesn't work and it shuts off before you can get safe mode to work it could be caused by the system overheating.
SAFE MODE:
1. Place you finger on the on/off sensor leave it their until you console turns off then take you finger off the sensor.
2. Place your finger back on the on/off sensor leave it their until you hear 2 consecutive beeps then take your finger off.
3. Once the safe mode screen comes on select the option PS3 SYSTEM RESTORE.
NOTE: A PS3 system restore will delete all data except the OS. I recommend backing up your console onto a USB flash drive if possible.
Good Luck!
Mar 08, 2011 | Sony Playstation 3 (PS3) Console
Cant turn on computer starts up but then immediatley shuts down
Try F8 at boot to make it boot into Safe Mode. If it runs okay in Safe Mode and the device manager shows no issues, then Windows may need a repair/restore run on it. If it still shuts in safe mode, it may be a power supply/battery issue.
Sep 02, 2010 | HP Pavilion dv6000z Notebook
New motherboard put in my hp pavillion dv6262 in January when computer wasnt even 2 years old. Computer is trying to start up showing a black screen and within a few seconds shutting back down again. Is...
I have reviewed your problem and have the fallowing items for you to check and or try.
Try booting into safe mode and see if the same thing happens.
( F-8 )
Choose safe mode with network configuration installed.
If the unit runs without shutting down, it is a program conflict and not a hardware issue.
Run this safe mode start up, with no external devices connected.
Note... Remove any Flash Cards or USB devices, CD or DVD's .
If the unit runs without shutting down in safe mode, you may want to run a complete restoration of software.
Hope this helps.
Oct 23, 2009 | HP Computers & Internet
Constantly runs but does not heat
The circuit board is faulty. It should be covered under the warranty. Call GE or the place of purchase.
May 17, 2009 | GE Microwave Ovens
Sansa express - turn on, "building database", then shuts off
Put In A Micro SD Card
Start It Up
It Should Work
You Can Now Safely Remove The Micro SD Card And It Should Start Up Fine
Mar 22, 2009 | SanDisk Sansa MP3 Player
GENERATOR WILL RUN ABOUT TEN MINS WITH LOAD THEN QUITS
You may have a 'TEST" mode on your Generator. Ten Minutes is usually the duration of the 'Exercise' function of most units, so I'd like to determine what mode you are starting your generator in. Please comment.
Mar 18, 2009 | Electronics - Others
Compaq Presario SR1123WM PC Desktop will not start up.
try starting it in safe mode, when click the power bottom press f8 repetitively then select safe mode. then restart it again.
Dec 03, 2008 | HP Compaq Presario SR1123WM PC Desktop
Screen black
Are any USB device connected to it? If so, disconnect them.
Try to start now, if this does not work:
When the system boots up, try hitting the F8 Key and see if you get a Windows menu? If so, try and start in Safe Mode. If this works, you have a hardware failure and you will not need to look for the problem. First place to start is reboot and F8 again and this time go in VGA mode. If this works, Run Windows update and this should replace any drivers that are not good, including video. If you cannot get in VGA mode, you know your problem, the video adapter or drivers. Remove them in Safe mode and run Windows Update.
If you need any additional assistance just click "ASL ME"
Please remember to rate this solution
Sep 25, 2008 | Toshiba Satellite A135-S4527 Notebook
Poulan/Weed Eater #Wt200 711724 24cc Gas Blower/Vac Logo
196 people viewed this question
Top Poulan Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
