Question about Dell Dimension 4300 PC Desktop
I HAVE A PROBLEM WIT THE FAX INSTALLATION. THERE ARE TWO(2)PLACES ON THE BACK OF THE DIMENSION 4300 FOR THE INSERTION OF TELEPHONE JACKS. IM HAVE A LAND LINE JACK INSERTED IN THE TEL SPOT. I HAVE NO JACK INSERTED IN THE MODEM SPOT. WHAT LINE SHOULD BE INSERTED IN THE MODEM SPOT AND WHERE DOES IT GO ON THE OTHER END. THE TEL LINE IS A DEDICATED FAX LINE WITH THE ABILITY FOR VOICE CALL OUT BUT NO VOICE CALL IN. PRESENTLY, I CAN RECEIVE AND SEND FAXES BUT THE PHONE DOES NOT RING FOR FAX RECEIVE NOR DO I GET A DEIAL TONE WHEN LIFTING THE HAND SET
    President:
  • 1,383 Answers
Connect your phone line main cable which is from exchange to line1 and connect from your phone to "phone" on modem of computer.
Posted on Jun 26, 2009
To fix the fax lines
Hi Ronald,
There should be two phone jacks on the back of the fax machine, one marked "Line" and one either with an image of a telephone or marked "phone". The cord from the wall jack plugs into the fax at the "line", and a telephone line can be used from the "phone" jack to a telephone if you choose. ;)
Feb 24, 2015 | Office Equipment & Supplies
HP 4300 officejet fax mode to print mode
Hello etilton
Are you trying to print from a pc or do a copy?
Button 11 Fax: Places the HP All-in-One in fax mode and presents the Fax Menu. Press Fax
repeatedly to scroll through the options in the Fax Menu.
Button 12 Scan: Places the HP All-in-One in scan mode and presents the Scan To menu for
selecting a scan destination.
Button 13 Copy: Places the HP All-in-One in copy mode and presents the Copy Menu.
Press Copy repeatedly to scroll through the options in the Copy Menu.
heres the rest of the manual pdf reader required
http://h10032.www1.hp.com/ctg/Manual/c00644922.pdf
If this solution was any help at all please press accept or ask more questions with the other button.
And if you need anything else let me know, you can ask me 24/7 by clicking
on the ask me button, I will ansver in most cases within 24hours.
Thanks and good luck!
May 04, 2008 | Office Equipment & Supplies
Need to set up fax
check back side two telephone female jacks, indicated phone(extension) & wall socket symbols.. Give telephone line input in the socket which symbol indicates wall socket. once its plug in normally we can use it. If you want customized setting like ring to answer,silent detection etc..choose in fax function setting...once connected with tele line you can get faxes automatically..
Jan 31, 2012 | HP Officejet 5610 All-In-One InkJet...
Cannot connect to my Internet. On my 2Wire modem at home, The Power LED light is solid green, the Ethernet LED light is green, the DSL LED light is continually flashing, and there is NO Internet LED...
With the DSL light always flashing, it means that either the ADSL signal (synchronization) does not reach your modem, or your modem cannot 'read' the signal.
You need to determine if the problem is from one of the following places :
  • outside of your house (your land line or ISP equipment) or from the modem;
  • your telephone-cable inside your house or
  • one of your equipment;
Try the following manipulations to determine from where the default comes :
  1. Determine if the problem is in your house or on the land line
    • Unplug each and every equipment which is connected to your telephonic installation (Fax, phones, answering machines etc);
    • Using the shortest telephone cable (RJ11) you possess, plug only your modem to the main telephone jack of your house.
    • If the DSL LED still flashes continuously, the problem is somewhere between your ISP's equipment and your house. You should call them and expose the situation. At this stage, you can't do much else.
  2. Determine if the problem is in your house installation
    If the DSL LED lights up when it is plugged to the main telephone jack, then it is either one of your equipment which is at fault, or the house installation. To pinpoint the problem, do the following :
    • With all the other equipment still unplugged, try the modem on all the other telephone jacks you have around the house.
    • If the DSL flashes continuously on one of the jacks, you will have found the source of your miseries. Depending on your ISP's terms and conditions, you will either have to call them of call for the services of a third-party technician to solve the problem.
    • If the DSL lights up correctly on all the telephone jacks, then your house telephone installation is good. Proceed to the next series of tests.
  3. Determine which equipment is at fault
    • Plus your modem to one telephone jack and wait for the DSL line to light solid.
    • Use a splitter (ADSL filter) to plug the equipments you possess (telephone, fax etc) one by one. Verify each time if the DSL LED is still lit or flashes continuously.
    • If one of the equipment causes the DSL LED to flash, it is that equipment which causes your problem.
    • If every equipment causes the DSL LED to flash, the it is the splitter (ADSL filter) which is causing the problem. You can confirm this hypothesis by testing each and every ADSL filter you have in your possession.
    • Replace any faulty equipment and you should have eliminated the problem.
If nothing of this solves your problem, you won't have any choice but call you ISP. Don't hesitate to tell them all tests you will have done.
May I also make some recommendations :
  1. Use a power surge protector (not a UPS though) to plug your modem to the electric outlet BUT plug it directly to the telephone jack;
  2. Make sure your modem is plugged in as far as possible from UPS, television, etc.;
  3. If possible, don't plug the modem in the same electric outlet as other equipments;
  4. Don't use any telephone extension cable to plug your modem to the telephone jack.
Hope this helps you. Let me know what happens next.
May 11, 2011 | 2wire (1000-000057-000) Modem
I am not able to send fax from this printer.
Did you connect an external telephone to your machine? If not, please check the lower left side when the back faces you and there are two telephone jacks. the one is to connect to the telephone line and another to an external telephone unit. after connecting the two lines, you should be able to get a dial tone when you lift the telephone's handset. I dont personally use the numbers in the machine but I use the telephone I connected to the machine when sending fax. Just start dialing using the phone and send the fax/ send button when fax tone is heard. hope this works.
Jan 26, 2011 | HP LaserJet 3015 All-In-One Printer
Hooking up cables and phone line to use the Fax on the P3150
Find a telephone wall-jack.
Buy a 1-to-2 telephone-splitter -- one end plugs into the wall-jack, and the other end provides 2 telephone-jacks.
Connect your telephone to one of those 2 jacks.
Connect your All-In-One to the other of those 2 jacks.
Be sure to use a 4-wire telephone-cable, not an 8-wire network-cable.
Feb 03, 2010 | Lexmark P3150 All-In-One InkJet Printer
How can I get connected the fax line? What are to
On the back of the unit you'll see 2 rj11 jacks. Those are the standard telephone jacks. Use a standard telephone cable (male rj11 on each end. Put one end in the lower jack and the end into the wall jack for your FAX line.
Jun 11, 2009 | Canon PIXMA MP780 All-In-One InkJet...
Im trying to add memory to my dell dim, 4300 desktop!!
That should work without any problems since the chips are 256. You can either try a bios update or clearing the cmos before trying to boot.
Let me know what happens after you try the above.
Mar 09, 2009 | Dell Dimension 4300 PC Desktop
Telephone line connection
Two options:
1) Pick up a phone line splitter (Radio Shack or just about any other retailer has them) that has a plug on one side and two jacks on the other. Plug this into the phone jack where the line to your computer is connected. Plug the cord to the computer back into one jack on the splitter and plug the line to the fax machine into the other jack. (If it will physically fit into the space on the back of the computer, you can just plug the splitter into the modem connector, plug the line cord into one jack and the fax cord into the other.)
2) (Useful if the phone jack is behind furniture or just hard to get at.) Get a phone line splitter with all jacks (two on one side, on on the other). Unplug the line cord from the computer and plug it into the single jack on one side of the splitter. Then run a new line cord from one of the two jacks on the other side back to your computer. Plug the cord to the fax machine into the other jack.
Jan 27, 2009 | Dell A940 All-In-One InkJet Printer
Dell Dimension 4300 PC Desktop Logo
Alun Cox
